| Need for Speed! Explorer, Ranger, Mountaineer 4.0 - 4.6 - 5.0 Nitrous, Superchargers, Camshafts, Head Work, Stroker Kits... DRAG RACING. Explorers, Mountaineers and Rangers CAN move! |
Thread Tools |
#101 |
Supercharged OHV
Winnipeg, Manitoba
00 Explorer XLT 4.0 OHV
Thanks! That coil bracket looks pretty intricate. Nice install for sure. I doubt mine will come out anywhere as nice as that. Does help give me ideas though.
__________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#102 |
Wannabe Elite Explorer
96.5
I'll draw you some specs if you want? its not very complicated, unless you get fancy with coil pack tray. Just to let you know, without it I would start to misfire possibly.. after heavy heavy activity which is about 1hr+ of sliding around in a parking lot.
#103 |
Supercharged OHV
Winnipeg, Manitoba
If you have specs, sure!
Then I would have a fighting chance of bending one up. Without them, Id spend endless hours cursing, trying to get it right. __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#104 | |
Resident Gearhead
Lake Villa, Illinois
'03 XLT 4.6
Quote:
__________________ 2003 4.6 V8 XLT Black Explorer, Kenne Bell 2.2 Supercharger, VT Billet bottom end, MPH 2.5 Heads, Blower cams, A1000 custom fuel system, and on and on... 2009 6.6 V8 Pontiac G8 GT, Twin Turbo, 402ci, Turbocam, Circle D Built 6L80E, Circle D 3000 Stall, new fuel system on its way...Shooting for 750+rwhp and easy middle 10's. 2002 4.0 V6 Explorer Sport, CAI, Gibson Exhaust... 2005 3.9 V8 Lincoln LS, KBX Performance Garrett Turbo System...Sold... |
#105 | |
va beach
92 SC
Quote:
__________________ 92 xl 5.5"duff arms,3"BL,PJ 36x14.50,wrapped headers,side dump exhaust,.20 over,HF oil pump,422cam,45cc 95tm p+p 10.67:1 heads,p+p lower manifold,75mm TB,90mm maf,36lbs injectors,P+P GM M90 Supercharged & intercooled!!SCT tuned!!electric fan,4.88s aussie locked front & back!!next NOS&W/M
http://www.explorerforum.com/forums/...=double+vision |
#106 |
Supercharged OHV
Winnipeg, Manitoba
The guys over at SCCOA seem pretty good. I guess we have to remember that these superchargers are from the 1970's. Im glad my postings are helping others from time to time.
Im not going to touch mine porting wise, as I have fear of decreasing performace. Besides, my brain can only handle so much at once. Did you take any pictures of what you changed? Did you have to pull the blades to do the job(What about timing them on re-install?)? Im also not inclined to pull the blades or pull the snout apart unless suddenly there is a new requirement to do so. I'll be away in Florida with the family on Friday, so hopefully when I get back there will be a new tb waiting for me. So Rocket? Whats your plans for the M90? __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#107 | |
Resident Gearhead
'03 XLT 4.6
Quote:
The blower will need to be disassembled before you can port it. The rotors are VERY high tolerance to one another and to the inside of the main rear case so you don't want shavings getting where they shouldn't be. If your rear main case rotor bearings are still good then just tape them up real well so that no shavings get in them while porting. If they are already all messed up then just press them out and press in new ones that cost roughly $20.00. The blower is comprised of 3 main sections. The snout assembly, the middle plate/bearings/rotors, and main rear case. Once you empty the oil from the front gear housing just take all the bolts out holding the 3 pieces together. Then take a rubber mallet and tap the snout housing off. It might take a few good raps so don't be shy. The snout will have a plastic coupler that allows the snout shaft to drive the "driven gear" in the blower. Once that is all out of the way then you will need to tap the middle plate/rotor assembly loose. This can only take a few small raps or it can take some real good ones too. I usually do a few real good taps around the case parting line and then get a flat head screwdriver in there an just lightly pry on each side widening the gap. Make sure not to scratch the mating surfaces between the 3 main sections as these seal either oil in or boost inside the blower. Once you get them apart about 1/4" then you can slowly and gently slide the middle plate and rotors assembly out of the rear case. You will be left with an empty blower case with those bearings I previously mentioned need to be taped up. From here is where you would start porting the blower inlet and outlet. The rotors don't have to be retimed because they never separate from the middle plate and gears since it is all one unit that is pressed together. I have a bit of experience with these blowers so I would prefer to take them all apart to asses any issues before it is all bolted up and even harder to get to; especially considering how old these are and likely how many miles are on them. Rebuild kits go for about $80 for these so I figure that a good refresh is just good preventive maintenance to ensure I shouldn't have to pull the blower again in the future. This stuff goes hand in hand with the porting since the whole thing has to be apart anyways. Still, I can understand if you would rather not chance it. I originally was going to do a custom twin turbo system on my 4.0 X Sport with those twin Garrett T25's that I had rebuilt about a year ago. Then I decided that since I plan to turn this truck into an offroader eventually that it would be more beneficial to have more off-idle torque of a positive displacement blower. Sure, I will probably be giving up 50hp on peak but it is not like I am building a racer anyways. So before I deployed last year I decided to sell those turbos to help fund the Eaton project. Now that I am back in the US I can start piecing things together. This will be a total bare bones build using stuff that I already have and parts that I fabricate to absolutely minimize cost. I will be building all of the manifolds, fuel system, intake system, etc. __________________ 2003 4.6 V8 XLT Black Explorer, Kenne Bell 2.2 Supercharger, VT Billet bottom end, MPH 2.5 Heads, Blower cams, A1000 custom fuel system, and on and on... 2009 6.6 V8 Pontiac G8 GT, Twin Turbo, 402ci, Turbocam, Circle D Built 6L80E, Circle D 3000 Stall, new fuel system on its way...Shooting for 750+rwhp and easy middle 10's. 2002 4.0 V6 Explorer Sport, CAI, Gibson Exhaust... 2005 3.9 V8 Lincoln LS, KBX Performance Garrett Turbo System...Sold... |
#108 |
Supercharged OHV
Winnipeg, Manitoba
Looking forward to seeing what you do with your Sport Rocket. Are you going to do anything to the sohc before you add the fi? It looks like there isn't really much available for those motors in the cam dept unless you go custom.
#109 |
96.5
Alight, seems I can't find the original drawing I had with numbers and such but here is what the just.
The base is cut from the original coil-bracket and welded to heavy gauge sheet. The top mount is easy because it bolts onto the a/c compressor. The mount that goes to the exhaust mani. was guesstimated to about the 3/4 point. To create a second piece was made, bolted to the mani. and then welded the 2 together while in the truck. |
#110 |
Supercharged OHV
Winnipeg, Manitoba
Ugh.
That's the thing for me. No welder, or welding experience. No heavy metal experience either. If I cant cut it with tin snips, and use screws, I don't do it. Yup, I can see my brackets looking like a child made them. __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#111 |
96.5
if I find measurements you can take an old coil bracket to a machine shop and tell them to build to spec. That is what I did for my air filter adapter (modified k&n fipk) to 90mm MAF. Which is just filed and re-drilled holes and the internal diameter bored out to just a tad larger than the MAF.
#112 |
Supercharged OHV
Winnipeg, Manitoba
Maybe I'll swing by the graveyard and get an old bracket off a junker. Then I have a starting point. I don't want to modify any stock parts, just in case I need to put it back to near factory (Never know, might get in an accident, and want the blower back for a new(er) explorer).
Thanks phix, I hadn't put much thought in to the brackets for supporting components till now. __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#113 |
96.5
I have a spare coil pack bracket somewhere from my parts collection. I went your route and didn't modify stock (except for when I tried to dremmel down my stock composite air box) to fit 90mm MAF. needless to say that didn't work out.
#114 |
Resident Gearhead
'03 XLT 4.6
No I am not even bothering with upgrading anything on the stock longblock. Stock pistons, rods, cams, block, and heads. Very cheap build and looking to stay under the $1k mark for the entire supercharger project.
#115 |
Supercharged OHV
Winnipeg, Manitoba
considering the sohc already flows way better than the ohv, I can see why. The sohc gets expensive to add high end parts to the motor. $ per horsepower is by far the greatest going your direction.
I can hardly wait to see what parts you have lying around and how you piece everything together. Today, a bung is getting welded in to my exhaust. I'll then be able to install the wideband O2 sensor and gauge. At least its a start. __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#116 |
96.5
Believe it you could have got away with a wideband in the o2 bung after the cat. James, can tune it out of the PCM.
#117 |
Supercharged OHV
Winnipeg, Manitoba
Interesting. I thought it had to be before cat. After the cat is probably easier. I'll see what the exhaust guy says.
oops......So your saying, just change the O2 sensor that's after the cat to a Wideband O2 sensor? __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#118 |
Resident Gearhead
'03 XLT 4.6
Do it before the cat not after. Putting it afterward can skew the readings a bit. Just keep it simple and have another bung welded in pre-cat like you had already planned.
#119 |
Supercharged OHV
Winnipeg, Manitoba
Done. Leaving right away to have it installed.
#120 | |
Resident Gearhead
'03 XLT 4.6
Quote:
Here are a few pictures of my blower after I disassembled it that should give you a little better idea of how it all goes together. __________________ 2003 4.6 V8 XLT Black Explorer, Kenne Bell 2.2 Supercharger, VT Billet bottom end, MPH 2.5 Heads, Blower cams, A1000 custom fuel system, and on and on... 2009 6.6 V8 Pontiac G8 GT, Twin Turbo, 402ci, Turbocam, Circle D Built 6L80E, Circle D 3000 Stall, new fuel system on its way...Shooting for 750+rwhp and easy middle 10's. 2002 4.0 V6 Explorer Sport, CAI, Gibson Exhaust... 2005 3.9 V8 Lincoln LS, KBX Performance Garrett Turbo System...Sold... |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1999 Ford Explorer 4.0 SOHC swap to 4.0 OHV | Pckid212 | Stock 1995 - 2001 Explorers | 33 | 02-06-2013 03:12 PM |
| Brandon's mild 4.0 OHV build | Brandon96 | Need for Speed! | 633 | 01-23-2012 01:59 AM |
| 98 EGR tube (4.0 V6 OHV) | brukshut | Stock 1995 - 2001 Explorers | 8 | 10-18-2010 06:49 PM |
| Eddie Bauer Question | erixon | Stock 1995 - 2001 Explorers | 9 | 09-08-2009 11:43 PM |
| Tranny code between 95 ohv and 97 ohv. | jasonphan | Stock 1995 - 2001 Explorers | 5 | 08-17-2009 11:06 AM |
| Thread Tools | |
