Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2011 - 2014 Ford Explorer 5th Generation Explorer > Stock 2011 - 2014 Ford Explorer Discussion
Notices
Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost.
2011 Explorer Remote start issues
Reply
Thread Tools
Old 02-11-2012, 11:41 PM   #1
TomTomNJ
Toms River, NJ
2011 Limited
Vehicle Specs
(Original Poster)
I have the 2011 Explorer Limited with the remote start. Never had a problem. Now, a year later, I am unable to start my truck on the first go. I hit the same combinations of buttons as I have been for a year, but now I just get the lights to flick on and off (engine does not try to start). The second time I try it, the truck starts up. It's consistently the second or third attempt, never the first. I took it to the dealer who said nothing is wrong and it started up for them. I told them, yes because it's now the second, third, etc. time you are attempting it. Not sure how long the car has to sit, but when it sits for a good amount of time, the first attempt of remotely starting the truck does not work and only the light flick on and off. They changed the battery in both remotes, but still the issue continues. Since it starts the second time around it's not really a big deal, but I'm curious if anyone else is experiencing this issue?
TomTomNJ is offline   Reply With Quote
Old 02-12-2012, 09:01 AM   #2
VinceL
Spring, TX
2013 Explorer Limited
Vehicle Specs
You're just holding it wrong
Hey, it worked for Apple as an excuse, didn't it?
That is a curious problem though. With the lights blinking, the car obviously is getting the command. I assume the manual doesn't say anything about those blinking lights being a code for something? Or have you run a vehicle health report to see if it says anything?
Keep us posted.
__________________
We just bought American!
She got the 2013 Ex
Meet the Gray Ghost HERE
Check out the Gray Ghost on Fuelly.com
Average Mileage: 21.3
Best Tank: 26.5
VinceL is offline   Reply With Quote
Old 02-12-2012, 09:58 AM   #3
bluelion
Spring, TX
2012 EX Limited
Vehicle Specs
i've had a couple of failed attempts to remote start. as you mentioned, it's when the car has been sitting for a while (like during my 10hr work shift)... two days in a row, i went to remote start and the lights blinked but never started....and even when i got closer to try to start it remotely, it didn't do anything. it just honked when i hit the lock button.....it starts right up though when i get in and press brake pedal and push start button....
bluelion is online now   Reply With Quote
Old 02-12-2012, 10:09 AM   #4
peterk9
Toyota Highlander Convert
Ottawa, Ontario area
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
Welcome to the new world of electronic gadgetry!
__________________
Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).
Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds
peterk9 is online now   Reply With Quote
Old 02-12-2012, 11:16 AM   #5
dco43054
cmh
02 XLT, 11 XLT
Vehicle Specs
Which lights are flicking on and off? The vehicle? Or the remote?
dco43054 is offline   Reply With Quote
Old 02-12-2012, 12:00 PM   #6
peterk9
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
Quote:
There are no lights on the OEM key fob with the remore start.
__________________
Old 02-12-2012, 02:57 PM   #7
Bill #4 Explorer
Chicago Area
Vehicle Specs
Been using the remote start for about 1 year now. No issues here. Same batteries, too.
Bill #4 Explorer is offline   Reply With Quote
Old 02-12-2012, 08:08 PM   #8
deewan
Cedar Rapids, IA
2012 Explorer Limited
Vehicle Specs
Might want to try new batteries. I had that problem sometimes with my aftermarket remote start. Once the batteries were weak, the car still got the signal but maybe not the entire signal. Hence the lights blinking but the X not starting. I've had similar issues with the remote for my home audio components. Some buttons worked, some didn't, I replaced those cheap batteries that came with the component and everything worked.
Worth a try anyway since it won't cost much.
deewan is offline   Reply With Quote
Old 02-12-2012, 08:10 PM   #9
TomTomNJ
Toms River, NJ
2011 Limited
Vehicle Specs
(Original Poster)
It's the yellow parking lights that come on and off. The same lights that stay on when the car finally started remotely.
No error message and the dealer said they checked everything out and it looks fine.
oh well. Not a big deal
Old 02-13-2012, 09:35 AM   #10
jeeden
Vehicle Specs
I don't have it in front of me, but the lights do mean something with the honking. After a certain number of failed attempts or something it will blink and then give the honk.
I like the idea above about the battery, first thing I would try. The dealer may not replicate because they are trying it from 5 ft away in the shop and the weak battery is able to work at that range.
jeeden is offline   Reply With Quote
Old 02-13-2012, 10:13 AM   #11
Bill #4 Explorer
Chicago Area
Vehicle Specs
Quote:
You guys need to read better!
Old 02-13-2012, 02:44 PM   #12
TomTomNJ
Toms River, NJ
2011 Limited
Vehicle Specs
(Original Poster)
Yes it's not a batery problem.
Old 04-03-2012, 07:52 PM   #13
janskim
MD
2011 Limited AWD 302A
Vehicle Specs
Mine just developed the problem of not being able to remote start this week. Tried the spare remote and same issue you see the lights blink when it locks and hitting the 2X button twice yields no start with eventually going to a beep. Everything was working for a year just like TomTomNJ case then the system went south.
janskim is offline   Reply With Quote
Old 04-03-2012, 08:22 PM   #14
peterk9
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
Quote:
Did you verify that the remote start option was set to ON in your settings? I've had some setting change on me at times.
__________________
Old 04-03-2012, 08:40 PM   #15
janskim
MD
Vehicle Specs
Yes tried that and everything was set correctly, going to let it sit overnite and try the spare again, hoping its just a battery issue.
Old 04-03-2012, 10:03 PM   #16
TomTomNJ
Toms River, NJ
2011 Limited
Vehicle Specs
(Original Poster)
For some strange reason it's now working fine. Go figure.
Old 04-04-2012, 07:18 PM   #17
janskim
MD
Vehicle Specs
Appears to be battery related, replaced both with fresh set though the spare is never used seems to be working. Suprised these went so quick as I have gotten 2 years out of batteries in other vehicle transmitters with more frequent clicking then this fob gets.
Old 04-05-2012, 03:00 PM   #18
harlenm
Shelton, CT
2013 Limited(lemon swap)
Vehicle Specs
Except this fob is always transmitting so the car can see it when you get close. My old car had a similar key and I had to replace it a little over a year after owning it.
harlenm is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2011 Explorer Incentives - All listed blwnsmoke Stock 2011 - 2014 Ford Explorer Discussion 23 04-13-2011 05:54 PM
1999 Ford Explorer Remote Start jbean8510 Stock 1995 - 2001 Explorers 3 10-13-2010 09:33 PM
2006 Explorer Disable Remote Start fmlman Stock 2006 -2010 Explorers 7 08-19-2010 11:03 PM
2011 Explorer FROM DESERT FLOOR TO MOUNTAIN PEAKS, PROVING FORD EXPLORER CAPABILITY, Rick Stock 2011 - 2014 Ford Explorer Discussion 4 07-27-2010 12:51 PM
Explorer Fuel Issues (Won't Start) tb258 Elite Explorer 911! 3 12-04-2003 01:01 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
