blueoval9erlifer
- January 16, 2012
- OAK HILL, KANSAS
- 04 explorer XLT
Ive got an 04 xlt the toe links are worn out New ones from ford quoted at 175.00 each done some research and found some Moog replacement parts was wondering if anyone had tried to take the factory ends off of the link rod? They are threaded but then Ford in their absolute wisdom then crimps the ends on instead of using a lock nut. if i try to take these ends off will it pull my threads to where i cannot put the new ends on?? tried to set it up as a link on here but not savvy enough i guess to accomplish this. if you google Moog ES800560 and moog es800562 it takes you to the problem solver moog page and shows the ends. I might try to hit the local salvage yard and pick one of these links up to try and tear apart but dont want to spend the money on it if someone else has experienced doing this.
Thanks for the Help
Thanks for the Help
