Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
power window relay trouble
Reply
Thread Tools
Old 02-19-2012, 02:20 PM   #1
scattermaster
HOUSTON,TEXAS
'93 EXPLORER
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Help!
My drivers side front window will SOMETIMES go down and wont go back up.
I fiddled with the wiring inside and there is a little black box that seems to be involved. It seems like a relay of some kind.
It's mounted on a clip inside the plastic door panel.
It has a flat plug with 5 pins
There is a ford part number on the case but it's hard to read.
something like:
F20B-14B113-AB
I've searched Google and been to auto parts stores and coming up empty.
Sound familiar?
TIA,
Jim
__________________
'93 v6 4.0 auto 2wdr 110K mi
scattermaster is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-19-2012, 02:46 PM   #2
racer_x_one
PA
'94 XLT
Vehicle Specs
Quoted: 0 Post(s)
The black box is the on touch down module. It could be bad. I'd start with your switchs and go from there.
racer_x_one is offline   Reply With Quote
Old 02-19-2012, 09:53 PM   #3
nexis
Cedar Rapids, IA
93 Limited
Vehicle Specs
Quoted: 0 Post(s)
quick sure fire way to test if its the one touch module, is jam a 25 amp ATC fuse into the 2 larger blade holes. This will bypass the module, and make your windows act like the one touch option was not installed. I've ran my 94 limited for almost 10 years like this. The cause of the problem if it is the module, is failing solder joints inside the module. If you want/need one touch and find a faulty module, A module from any 87-94 ford will fit right in.
nexis is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
how to:fix that power window joe doe Stock 1995 - 2001 Explorers 7 03-24-2015 01:46 PM
Question on Details of Power Window Repair, '91 EB Lee Iaccoca Stock 1991 - 1994 Explorers 25 05-09-2010 01:23 PM
Power window relay location? nscheidl Stock 2002 - 2005 Explorers 4 06-30-2009 07:10 AM
I need some help with power window problem... spotdog14 Stock 1995 - 2001 Explorers 3 12-09-2005 10:36 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
