#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Header panel and turn signal replacent
Reply
Thread Tools
Old 02-20-2012, 08:33 PM   #1
Yerfdog79
Bishopville, MD
2000 Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US Header panel and turn signal replacent
Does anyone have an idea on where I can get the inserts or grommets that go into the header panel to accept the studs from the turn signal assemblies. My current header panel is cracked and a couple of the holes have the grommets "melted" into the panel and some of the studs have thick, black stuff on them. Thanks for any help.
Yerfdog79 is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-21-2012, 01:30 AM   #2
gonenuke
Virginia
1999 Explorer XLT SOHC
Vehicle Specs
Quoted: 0 Post(s)
About $22 for the header panel at Rockauto. Might get the grommets in help section of local auto store.
gonenuke is offline   Reply With Quote
Old 02-21-2012, 06:41 AM   #3
Yerfdog79
Bishopville, MD
2000 Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a replacement. Didn't come with anyhting in the holes. Having it painted at the moment. I will check Napa today. They usually have a good selection. If they don't, do you think maybe finding rubber grommets with a slightly smaller hole than the diameter of the studs would work?
Old 02-21-2012, 11:28 AM   #4
gonenuke
Virginia
Vehicle Specs
Quoted: 0 Post(s)
The grommet is Part # HM1 $6.50 and it is called a grommet. If you go thru Ford have them look at exterior lighting - turn signal assembly part # N81169-S Hope this helps. You might also try Lowes I seem to remember grommets in their specilized hardware section.
Old 02-22-2012, 04:36 PM   #5
Yerfdog79
Bishopville, MD
2000 Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Yup. Looks like gonna be a trip to the ford dealer. Tried the Help! grommet kit. Had to get three packs to get six the correct size. Works ok if you never have to take them back out. Half of them fell out in the process of getting the assemblies in correctly. Thanks for all the help!
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
How To: Install Signal Mirrors On 3rd Gen Ex BigRondo Performance Lighting 94 03-22-2015 06:53 PM
Message center flashing with turn signal idoticsoigpa Stock 1995 - 2001 Explorers 6 01-23-2012 08:51 PM
Signal Mirror Installation aldive Performance Lighting 35 04-24-2010 01:18 PM
Left turn signal forgot how to do it's job? U235 Stock 1995 - 2001 Explorers 4 12-16-2009 12:38 AM
Wierd turn signal problem hmbre97 Stock 1995 - 2001 Explorers 4 07-20-2006 04:37 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
