| New Member Forum The place for new members to introduce themselves to our family of Ford Explorer enthusiasts and to ask any questions about the message board software. Welcome aboard!! |
Thread Tools |
#1 |
Wannabe Elite Explorer
FORD EXPLORER 1966
Ford explorer 1966 transmission problem
Hi i really need some help with mi explorer 1966
i just install the trasmission renew and a use trasfercase about tree months ago and now start lossing power now is not working on drive i need to start on 2 and when get speed i swich to d but is getting worse now |
#2 |
trona calif
1998 sport
ola manual,,, do you mean 1996???these are very knowledable people here but they need more info,, 1996??? engine size, 4.0??? 5.o???
__________________ if my memory was getting shorter would i know??? ![]() |
#3 |
NJ
1996 Ford Explorer
I have the same vehicle, 1996 4.0 Explorer XLT. Been around the block on this problem. The specific physical symptoms are; no 2-3 upshift unless I manually start out in 2nd then shift to Drive a bit late or starting out in Drive, let 2nd run up to 3500 rpm, let off the the gas pedal completely and get back in the gas when I feel it shift.
Electrical symptoms include MIL light and code P0756 and occasionally have the O/D light flashing which indicates the vehicle is in limp mode. So far I have had 2 different valve bodies in it due to what I have seen looking at many forum posts and Ford TSBs, no improvement. Today I got technical on it having purchased a Ford transmission troubleshooting book by Mandy Concepcion. According to the information in the book, the 4R55E trans. shift solenoid combinations are; 1st gear- only Sol. 1 is on 2nd gear- Sols. 1 & 2 are on 3rd gear- All Sols. off 4th gear- only sol. 3 is on The solenoids are supplied Batt. voltage and the PCM supplies ground to activate them. (Shift Sol. 1 = PCM pin 27, 2 = pin 1, 3 = pin 53) looking at the firewall pin 1 is on the bottom left, I back probed it and used my Fluke meter on a drive test (it will read Batt. voltage when off, and around 200 - 300 mv when on) my trans is doing what it is told to, my PCM is not releasing the #2 or B solenoid when it should (since for 3rd gear all solenoids should be off) when I drag 2nd out and release the gas (and wait...) I see the meter go back up to 14V and there's 3rd like it should be. Now the question is, do I need a PCM or is there another reason the (faulty input from another sensor maybe ?) PCM doesn't make the 2 -3 upshift when it should. I checked the TPS with my Fluke 97 scope, tapping the sensor w/screwdriver handle, smooth trace. I will try to find a bone yard PCM to try. I hope this helps, let me know if you need any other info. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1997 Ford Explorer needs your help (transmission problem). | knopp25 | Explorer & Ranger Transmissions, Transfer Cases, & Differentials | 8 | 11-11-2012 08:58 PM |
| Top search phrases for this site | Rick | Suggestion Box - Forum Feedback | 11 | 09-12-2011 09:22 AM |
| Transmission installation problem on a 1998 Ford Explorer. | megadan1111 | Explorer & Ranger Transmissions, Transfer Cases, & Differentials | 38 | 07-14-2011 05:46 PM |
| Found by chance | Ford MasterTech | New Member Forum | 23 | 01-31-2011 01:12 PM |
| What is the BEST transmission fluid for a 2002 Ford Explorer XLT??? | mkewitsch | Stock 2002 - 2005 Explorers | 7 | 07-15-2010 02:56 PM |
| Thread Tools | |
