#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
99 Explorer limited Won't shift into park
Reply
Thread Tools
Old 02-25-2012, 07:17 PM   #1
tjax21
Spokane
1999 explorer limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi, So I was driving around all day and my explorer was doing fine shifting into park. Then I got home and went to shift it into park and it stopped and wouldn't let me. I am able to shift into every other gear perfectly fine. Anybody know whats goin on?
tjax21 is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-26-2012, 07:49 AM   #2
drbenz
High Point, NC
2000 EB 5.0
Vehicle Specs
Quoted: 5 Post(s)
A question, will the prndl pointer not go to park position or is it that the shifter shows park but the truck still rolls?
drbenz is offline   Reply With Quote
Old 02-26-2012, 12:54 PM   #3
tjax21
Spokane
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
the prndl pointer wont go into park. It stops like half way between and i don't want to force it.
Old 02-26-2012, 01:23 PM   #4
yavapaires
Dewey, Az
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Look under the hood for any debris that may have gotten lodged any where around the shift linkage, especially down at the bottom of the transmission.
yavapaires is offline   Reply With Quote
Old 02-26-2012, 01:40 PM   #5
drbenz
High Point, NC
2000 EB 5.0
Vehicle Specs
Quoted: 5 Post(s)
You need to verify what is working correctly and what doesn't, if the transmission goes into park and the truck doesn't roll thats one thing. The shift cable is adjustable at the trans bracket to get the tranny in sync with the stops in the travel of the shift lever on the column, and the little pointer in the cluster has an adjustment thats easy to do under the dash to get it to work with the program. As long as the truck won't roll away on you the other items are small.
Old 02-26-2012, 02:07 PM   #6
tjax21
Spokane
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanks guys. I just took a look under the car and we had alot of ice buildup. I am going to let the car warm up for a while and melt the ice and see what happens. I'll keep you up to date.
Old 02-26-2012, 02:30 PM   #7
tjax21
Spokane
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
hey thanks for the help. We melted the ice off the bottom of the car and opened up the hood. then we got in by the steering colum and made sure there was nothing blocking it. We found ICE. it was blocking the car from shifting into park. we melted it away carefully and now it works! Thanks!
Old 12-20-2013, 06:30 PM   #8
Jerameya
Snohomish, Washington
Jerameya's Avatar
1998 Mounty V8
Vehicle Specs
Quoted: 1 Post(s)
Exact thing happen to me today. I had way too much fun playing in the snow today and built up about 5" of compact snow and ice over the linkage making so I couldnt get into park. Had to bust out the heat gun and a chisel to break the ice. Thank you to this forum for saving my ass on again. Would have never thought of it
Jerameya is offline   Reply With Quote
Old 12-20-2013, 07:22 PM   #9
koda2000
Georgia
2001 Explorer EB 5.0L
Vehicle Specs
Quoted: 1077 Post(s)
the 2 bolts that hold the shifter to the steering column can loosen and even fall out. they are gold colored T50 torx. check them and if they need to be tightened, put some blue thread lock on them. this is a very common problem.
__________________
I reject your reality & substitute my own...
2001 Explorer Eddie Bauer 5.0L V8 2WD
2000 Mountaineer 5.0L 2WD/2000 Expl XLT 5.0L 2WD
2000 Mountaineer 5.0L V8 AWD, 2001 Expl Sport Trac
2001 Explorer XLT 4.0L SOHC V6 auto 2WD (RIP 5/13)
1997 Explorer Sport 4.0L SOHC V6 auto 2WD
koda2000 is online now   Reply With Quote
Reply
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
01 x, 4wd wont engage offrdsnwbrd4 Modified 1995-2001 Explorers 11 12-08-2015 01:22 PM
Ford Explorer & Ranger Solid Axle Swap - SAS - Registry Index Randall Explorer/Ranger Solid Axle Swap Registry 23 07-23-2015 09:04 AM
Explorer Limited '99 Will not lock most times! ಡ_ಡ MightyFrosty Stock 1995 - 2001 Explorers 4 05-10-2011 06:39 PM
99 Explorer Limited AWD Sheriff Stock 1995 - 2001 Explorers 37 03-14-2008 11:52 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
