#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
ROugh idle engine shakes PLEASE HELP
Reply
Thread Tools
Old 02-27-2012, 09:47 AM   #1
02ex121
new york
2002 ford explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
hey guys, i have a 2002 ford explorer xlt 4.0 and i have been expierencing a rough idle at stop lights/signs and in park. i recently brought it to a shop and the mechanic told me that i had a cylinder 1 and 6 misfire reading. He replaced 2 injectors and ran a compression test that passed. After just these two issues he told me it still ran rough and was saying engine is done and asked about buying a used engine to replace it. it has 112000 miles and ran fine prior to this issue. I was going to bring it to another mechanic for a second opinion. was wondering if anyone out there can possiblly help me in any way thanks.....steve
02ex121 is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-27-2012, 06:00 PM   #2
stoogefan
Geneva, IL
2002 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
I believe the most common cause of your symptoms is a dirty IAC valve. You can clean the IAC valve and throttle body for just the cost of a can of throttle body cleaner and a few minuted of your time. You can also get some MAF cleaner and carefully clean the MAF sensor. You should be able to find how-to's on the site. It could be something more serious but try the cheap fixes first!
I just did this on my 2002 XLT 4.0 yesterday since it was just started having trouble idling in the morning. Less than 30 minutes and less than $10 later, it was all fixed.
stoogefan is offline   Reply With Quote
Old 02-27-2012, 06:48 PM   #3
naz123
Fl
2003 explorer lmtd
Vehicle Specs
Quoted: 0 Post(s)
IS it still misfiring?
Does the check engine light appear after a couple of miles?
Possible fuel filter,broken valve spring,check spark plugs.
naz123 is offline   Reply With Quote
Old 02-28-2012, 08:05 PM   #4
SyberTiger
Orlando
2002 Limited 4x4
Vehicle Specs
Quoted: 7 Post(s)
Try out the following two links:
Rough Idle Solution
How to Clean the IAC and MAF Sensor
Most likely a vacuum line leak. Could be the IAC too.
__________________
2002 Ford Explorer 4x4 Limited
P275/45R20 on 20" Rims
SyberTiger is offline   Reply With Quote
Old 03-08-2012, 02:58 AM   #5
Blue Explorer
San Francisco
2005 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
This just happened to me on my 2005 Explorer last month. I had to replace the Harmonic Balancer at 75000 miles. This gave the computer a bunch of different readings that the Ford dealer had trouble shoot. After many disputes with them, one mechanic finally figured it out. Hope this helps.
Blue Explorer is offline   Reply With Quote
Old 03-13-2012, 12:49 AM   #6
pickupman6
jack al
2000 explorer xls 4.0 ohv
Vehicle Specs
Quoted: 1 Post(s)
What about the plugs and wires did he ever check those?
pickupman6 is offline   Reply With Quote
Old 03-14-2012, 01:21 AM   #7
Blue Explorer
San Francisco
2005 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
Quote:
The first couple of solution that the dealer suggested were to change the plugs, wires and Intake Manifold Seals. I'd changed the plugs and wires thinking t it would be the least expensive way to solve the rough idle. Not so. After numerous tests, like replaceing the Intake Manifold Seals, MAS, and the Throttle Body, nothing worked. Actually, the Harmonic Balancer cost the least to replace. However, I did get some money back for the misdiagnosis from the Ford dealer.
Old 03-14-2012, 01:28 AM   #8
pickupman6
jack al
Vehicle Specs
Quoted: 1 Post(s)
What about the pcv elbows they are bad to develope holes and cause a vacuum leak. Sometimes it won't even throw the lean codes, p0171, p0174, which I'm assuming you don't have cause you didn't mention it. Of course they should have noticed that when they changed intake gaskets.
Old 03-14-2012, 02:48 AM   #9
Blue Explorer
San Francisco
2005 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
They checked the pvc elbows first and didn't find any leaks. A propane test on the intake manifold gaskets were performed to see if there were any leaks. They suggested to replace the seals, plugs and wires. It took almost two weeks for them to discover the harmonic balancer was worn.
Old 09-29-2012, 05:43 PM   #10
05explorerXLT
Las Vegas
05 XLT
Vehicle Specs
Quoted: 0 Post(s)
Blue Explorer...was your symptoms a loping rough idle with no check engine light?
05explorerXLT is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
General Maintenance Question stiffaknee Stock 2002 - 2005 Explorers 7 05-14-2014 03:02 PM
rough idle, stalling engine please help drakeguy22 Modified 1995-2001 Explorers 16 11-04-2009 03:38 AM
Rough Idle, Intermitent Check Engine james.oco Stock 1995 - 2001 Explorers 9 01-01-2008 05:01 PM
Rough idle and check engine light RaveOn Stock 1991 - 1994 Explorers 51 09-11-2006 11:46 AM
Rough Idle, Check Engine Light Butcher99 Under the Hood 1 07-27-1999 03:34 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
