| 2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Hazleton, IN
2002 Explorer Sport Trac
2002 Sport Trac Transmission Service question
Hey everyone! I have a 02 Sport Trac 4X4 with 82K on it. I want to have the tranny serviced, but am not sure if I should have a standard service done (filter/ fluid) or a flush and service?? I am the second owner, and I don't think the tranny has ever been serviced...expert advice apreciated
#2 |
Maine
2003 ST XLT
A standard service (drop the pan, change filter, refill) doesn't replace all the fluid. The fluid in the torque converter will be untouched.
The flush and refill (when done correctly) should make sure all the old fluid is removed and replaced. I'd suspect you're do for a flush and refill. I'm not 100% on Ford's recommended interval, but the trans shop that did mine said 75K intervals are fine for regular driving. If it's seen a lot of towing knock that down to 40K intervals. |
#3 |
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Complete transmission service at my local Ford dealer $199.95.
Dropped the pan and replaced with an OEM Motorcraft FT filter. Used a BG PF5 flush machine and 20 quarts of Mercon V (10 qt. capacity) Fluid and filter alone $140. A bargain IMO, without the mess and hassle. http://www.bgprod.com/products/transmission.html |
#4 |
Montreal, quebec
2002 sport trac 4x4
A friend of mine is a transmission specialist at my local ford dealer ship and he told me that it is not necessary to do a fluid flush. An other scam from the dealer's
just saying __________________
#5 | |
Kailua-Oahu, Hawaii
Quote:
Similar to draining 1/3 of the motor oil, changing the filter, and topping off. Last edited by swshawaii; 02-29-2012 at 10:28 PM. |
#6 |
Dublin, GA
'01 Sport Trac 4x4
The bold says all we need to know about the value of his opinion.
#7 |
Bay Area CA
03 sport trac XLT
if youre under 100k, i say it wouldnt hurt to start getting into doing it regularly. i just hit 88k on mine and im about to do mine once i get a chance.
#8 |
CINCINNATI, OHIO
01 SPORTTRAC
I don't think it's necc. to drop the pan to replace filter. I would do the trans flush. We had a silverado with about 200k, slipping trans and black fluid come into the shop a couple years ago. We tried a flush to see if it would help before rebuilding trans, it didn't help but when we tore the trans down to overhaul the filter looked brand new.
__________________ '01 Sport Trac stock suspension with 265/70-16 Firestone Destination AT colormatched cladding. |
#9 |
Hazleton, IN
Thanks for all the input guys, I really appreciate it! I think I'll do a filter replacement and flush. I know I'll replace the filter if I replace the fluid
Getting ready to install Scanguage II with a tranny cooler and want to start out fresh
#10 |
Dublin, GA
'01 Sport Trac 4x4
It can't really hurt to change the filter, but I really don't think it's necessary either.
I got an alignment yesterday (we'll leave it at that ) and asked about the tranny flush because I wasn't sure my shop had that capability. They do a true flush and also assured me that they don't do the filter unless requested by the customer as it's usually not necessary. Again, can't hurt, right?
#11 |
Elite Tonka Trac'er
Miami, FL
02 Sport Trac 4x4
With 80k miles I would get the transmission fluid changed soon as possible. Much more mileage then that I would say don't change it at all until the tranny goes out. If I had an auto transmission in my trac, I would change the fluid every 40k.
__________________ 5 Speed Manual 4x4-TT and shackle lift-3" Body Lift-16x8 ProComp 8069 Wheels-Cooper Discoverer STT 305/70/16 MT Tires (33x12)-Yakima Loadwarrior Roof Basket-Aussie Locker-Obnoxious Air Horns. |
#12 |
Hazleton, IN
Well after the Scanguage II install, we headed to St. Louis! Running almost 3 hours solid, the hottest my tranny temp got was 150 F. Today I did a tranny flush (myself), after finding out my local dealer did not use a certified technician to do the work...I am VERY particular about the work done on my vehicles!
So I installed a second auxillary tranny cooler (had a factory aux cooler also) in series, and now I'm all set for pulling the new 7X14 enclosed v-nose trailer in a few days! Total revamp was 1. Wired a factory 7 way/ 4 way combo trailer connector 2. Installed a Prodigy P2 Brake Controller 3. Hooked up a Scanguage II to monitor tranny temp 4. Flushed Tranny & installed secondary auxilary cooler (Derale 13503) Thanks for all the great knowledge from the members on the forum, I couldn't have done it without you
| Tags |
| tranny, transmission filter, transmission fluid |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2007 Explorer Sport Trac 4.0 5 Speed Transmission Rebuild | Ticobird | 2007 - 2010 Explorer Sport Trac | 3 | 04-11-2013 02:32 PM |
| TSB's, Where to get them free? | nevr1zenuf | Under the Hood | 16 | 11-15-2012 01:30 PM |
| EEC-IV 2 and 3 digit trouble codes. | BrooklynBay | EEC IV | 16 | 03-26-2012 09:46 PM |
| 2002 sport trac problems, not sure how to proceed. | Joey P | 2001-2005 Explorer Sport Trac | 12 | 01-24-2009 10:05 PM |
| Questions 2002 Explorer sport manual transmission grinds 3rd when hot | GaryR13G | Explorer & Ranger Transmissions, Transfer Cases, & Differentials | 1 | 01-17-2009 09:39 AM |
| Thread Tools | |
