Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
HELP! low compression on all cylinders
Reply
Thread Tools
Old 03-01-2012, 11:51 PM   #1
1989dangeroustoy
redlands, California
1996 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 96 explorer 4.0 ohv, today I did a compression test and got about 90 psi on all cylinders, I don't know if its bad rings, valves or timing chain, also I think I may have a cracked head, what do you guys think? Also do you think I'd be better off buying a used motor or rebuilding mine, I'd rather not pull the motor out and I definitely do not want to rebuild the bottom end
1989dangeroustoy is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-02-2012, 07:29 AM   #2
Dono
V8 Limited and SC 4.0 OHV
Winnipeg, Manitoba
Dono's Avatar
00 Limited V8
Vehicle Specs
Quoted: 465 Post(s)
Low on all cyl? You sure your compression testers reading right? Run OK? How many miles on the motor? If it's really that low across the board, and mileage is high you might want To consider a complete rebuild or rebuilt motor.
__________________
00 Limited V8 rear mount turbo http://www.explorerforum.com/forums/...d.php?t=388599
and a Rebuilt SC 4.0 OHV.
Dono is offline   Reply With Quote
Old 03-02-2012, 08:48 AM   #3
yavapaires
Dewey, Az
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
My main question is; how did you check the compression? Did you pull all the plugs, or one at a time? Did you hold the throttle open, or closed? Improper procedure can affect the reading. If you have 90psi all cylinders, and the engine is running smooth, with good power, I wouldn't be too worried.
yavapaires is offline   Reply With Quote
Old 03-02-2012, 09:22 AM   #4
my98nnj
Boonton, New Jersey
1998 XLT
Vehicle Specs
Quoted: 71 Post(s)
Ditto above, plus the test is more accurate on a warm engine.
my98nnj is offline   Reply With Quote
Old 03-02-2012, 09:37 AM   #5
DaExplorer
San Diego Ca / Big Bear Ca
DaExplorer's Avatar
97 XLT SOHC 4x4
Vehicle Specs
Quoted: 2 Post(s)
Try testing one cyl and see the read. Then squirt some motor oil into cyl and re test. If pressure goes up I believe that it would indicate rings.
Side note when you do restart it there will be lots of oil smoke. Neighbors won't like it. let it burn off before you hit the road or you could get stopped and cited.
__________________
DaExplorer aka Don
CJExplorer's Dad
White 97 Explorer XLT 4Dr 4WD V6 SOHC,
Almost a twin to CJ's. (Oh, I guess not anymore since he sold it)
White 95 F350 XLT Crew Cab Gas 460
DaExplorer is offline   Reply With Quote
Old 03-02-2012, 01:53 PM   #6
1989dangeroustoy
1996 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I tested. It cold with all the plugs out and throttle
Closed
Old 03-02-2012, 01:54 PM   #7
1989dangeroustoy
1996 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Closed , motor has 143xxx on it
Old 03-02-2012, 01:56 PM   #8
1989dangeroustoy
1996 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
It runs but I have a cylinder 4 misfire
Old 03-02-2012, 02:51 PM   #9
steadyhand
Missouri
99 Mercury Mountaineer
Vehicle Specs
Quoted: 7 Post(s)
You need to check one cylinder at a time. You do not have to pull out all of the spark plugs while you test that one cylinder. Just unplug the coil to prevent the truck from starting. Do what DaExplorer said and put a tablespoon of oil into the cylinder and then immediately retest. IF the compression goes up with the oil in the cylinder, chances are your top oil ring is bad and your losing compression.
__________________
99 Mountaineer 5.0 2WD 4 door
steadyhand is offline   Reply With Quote
Old 03-02-2012, 05:09 PM   #10
yavapaires
Dewey, Az
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
You will not get an accurate reading with pulling one plug at a time. However, I have done that to check a single cylinder. And the top two rings are compression rings. The lowest rings(three piece) are the oil control rings.
Old 03-02-2012, 05:50 PM   #11
1989dangeroustoy
1996 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
OK so I did get a lot better reading with the engine warmed up ,I got around 120 psi, but now I'm stumped. I checked the plug, wire, and coil, has decent compression , and i still have a misfire ,all that's left is the fuel injector or a small pissing coolant leak into the cylinder any other suggestions?
Old 03-02-2012, 08:08 PM   #12
steadyhand
Missouri
Vehicle Specs
Quoted: 7 Post(s)
Quote:
Maybe I'll learn something new here. Why will pulling all the plugs give more of an accurate reading than pulling one plug at a time? Each cylinder is independantly sealed and thus have the potential of giving a different compression reading on each one. How is pulling every plug to do the test going to make it more accurate?
__________________
Old 03-02-2012, 08:37 PM   #13
rjcooperss396
Fontana, CA
'95 XLT
Vehicle Specs
Quoted: 5 Post(s)
It doesn't make it any more accurate. It simply allows the other cylinders to bleed off pressure so that the engine turns faster and the reading is higher. I've never pulled all the plugs nor opened the throttle to do a compression test on any of my vehicles.
The only thing you need to make sure of is that you do the same thing for each cylinder. Don't open the throttle for one but then don't for another. The thing you are checking is if all the cylinders are around the same.
rjcooperss396 is offline   Reply With Quote
Old 03-02-2012, 10:15 PM   #14
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
you probably need to give the forum more info on the misfire and checks that you have performed. Is it during cold starts, warm start, warm runs...etc
further, did you swap plugs (cylinder to cylinder), like-wise wires, like wise coils (side to side)?????
Further, what does the plug from that cylinder look like compared to others?
budwich is offline   Reply With Quote
Old 03-02-2012, 10:34 PM   #15
1989dangeroustoy
1996 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Its a constant misfire from start to operating temp, Cel throws a po304 cylinder 4 misfire, I got all new plugs autolite platinums. I checked the plug wire with a spare plug wire and a spark testing light, I swapped wire 3 and 4 on the coil pack all with no change, compression test was all cylinders around 120 psi, no coolant loss no excessive smoke, slight sweet smell if you put your nose close to the tailpipe but you really have to smell for it! All plugs looked the same and normal
Old 03-04-2012, 12:27 AM   #16
1989dangeroustoy
1996 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Anybody?
Old 03-04-2012, 12:53 AM   #17
bilzy7
MA
98 Explorer XLT
Vehicle Specs
Quoted: 1 Post(s)
I had p0304, it was just a bad plug, coil pack/plugs/wires... Maybe the plug socket(whatever it's called) has a problem. But p0304 is for crap... If I remember right cylinder 4? I know it is on drivers side.
Google that code. I found so many other forums/sites with information on it. Goodluck.
__________________
1998 Explorer XLT 4x4 4.0 SOHC
bilzy7 is offline   Reply With Quote
Old 03-04-2012, 12:54 AM   #18
bilzy7
MA
98 Explorer XLT
Vehicle Specs
Quoted: 1 Post(s)
You confirmed correct gap on all plugs? .054 if I'm not mistaken or is that for the OHV engine...
__________________
Old 03-04-2012, 05:43 AM   #19
gonenuke
Virginia
1999 Explorer XLT SOHC
Vehicle Specs
Quoted: 0 Post(s)
Might be a plug bad out of the box, happens sometimes.
__________________
1999 Explorer XLT 4.0L SOHC 5R55E
Mostly all stock but New Moog ball joints,
02 Sport Thermostat Mod, New Valve Body
gonenuke is offline   Reply With Quote
Old 03-04-2012, 04:40 PM   #20
Dono
Winnipeg, Manitoba
Dono's Avatar
00 Limited V8
Vehicle Specs
Quoted: 465 Post(s)
Well, we have air, gas, compression, and spark to make the cylinder fire.
Clogged injector maybe?
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
OBD-II Diagnostic Trouble Codes (DTCs) BobWiersema EEC V 8 03-26-2013 10:22 PM
2002 Ford Explorer 4X4 low won't engage BlakestaExpo Offroad Drivelines 4 11-23-2009 09:50 PM
Bypass wiring for low range switch? 2wd low! Monz Stock 1991 - 1994 Explorers 9 05-15-2009 11:31 AM
low compression jason bond v6 Stock 1995 - 2001 Explorers 12 03-08-2009 09:39 AM
'4WD Auto' and '4WD Low' lights flash 6 times r37ribution Under the Hood 16 01-14-2005 04:43 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
