#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Stuck in 4wd auto
Reply
Thread Tools
Old 03-03-2012, 05:42 PM   #1
hawkboy
maryland
98 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Unhappy Stuck in 4wd auto
I have a 98 ford explorer XLT, it's stuck in 4wd auto with the dash selector on 2wd, and no 4wd light on the dash. so in neutral feet on brake selecting from 2wd to 4wd auto there is no click and cant hear it switch in the tranfer case but the 4wd auto light cames on. selecting from 4wd auto to 4wd low i hear the click and the shift in the tranfer case, dash 4wd low comes on. When reversing going from 4wd low to 4wd auto hear the click and the transfer case switching and light goes to 4wd auto. selecting 4wd auto to 2wd no click heard or switching of the transfer case and 4wd auto light goes out but is still in 4wd auto.
Tried putting vehicle on jack stands to make sure it was in 4wd or 2wd vehicle is in 4wd auto. checked all fuses.
Removed transfer case motor and left electrical connector in. Tried to shift as above in the first paragraph. Shift motor does not rotate going from 2wd to 4wd auto but rotates going from 4wd atuo to 4wd low.
Any suggestions or other testing i can do or does this mean my transfer case shift motor is bad?
hawkboy is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-04-2012, 07:54 AM   #2
Beargap
Bear Gap, PA
'97 XLT
Vehicle Specs
Quoted: 10 Post(s)
There is no 2WD in a 98 Explorer Control Track. The switch positions are 4WD-Auto, 4WD-Hi, and 4WD-Lo (last 2 lock the transfer case). Perhaps you have a replacement panel from a '95 or '96 Explorer.
=Vic=
Beargap is offline   Reply With Quote
Old 03-04-2012, 08:32 AM   #3
drdoom
VA
2005 Eddie Bauer 4.6L 4X4
Vehicle Specs
Quoted: 308 Post(s)
Sounds fine to me. If you jack up all four wheels, then run in AUTO, yes, your front wheels will be turning. That is AUTO 4x4.
drdoom is offline   Reply With Quote
Old 03-04-2012, 10:16 AM   #4
albi1cnobi1
Elite Mountaineer
South Jersey
albi1cnobi1's Avatar
99 Mountaineer V6 4x4
Vehicle Specs
Quoted: 106 Post(s)
drdoom and Beargap are right. Sounds like someone replaced the radio bezel with one from a 95-96. The control-trac t-case does not move the motor unless you shift to 4lo. 4auto to 4hi just applies the clutch at 100%.
__________________
Al
99 Mountaineer 4.0 SOHC. 2013 F150 SuperCrew 4x4
TT/F-150 Leaf Spring Mod, 2" BL, 32x11.5/15 BFG A/T's, Rancho 5000's, Gibson Catback, Coilover conversion(in process), Electric Fan Conversion, AVM Manual Lockout Hubs, Dual Battery System. EATC Mod. BW1354 swap. My 4405 To 1354 Swap Thread Support your own economy, Buy American, all of our jobs depend on it.
albi1cnobi1 is offline   Reply With Quote
Old 03-04-2012, 02:04 PM   #5
hawkboy
maryland
98 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Stuck in 4wd
I've looked into the awd theroy, if was found that for the 98 ford explorer XLT the only way its a awd is if its a V8 5.0L. I have the V6 4.0L sohv. so come to found out it is stuck in 4wd auto.
Any other suggestions would be helpful. Thanks
Old 03-04-2012, 02:06 PM   #6
hawkboy
maryland
98 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
its couldnt be awd because i have the V6 4.0L sohv. Only the 98 ford explorer with the V8 5.0L has the awd
Old 03-04-2012, 02:26 PM   #7
rickybobby
Battle Creek, mi
'97 XLT
Vehicle Specs
Quoted: 6 Post(s)
yes, but your 98 doesnt have a 2wd option, it has 4auto, 4hi, and 4low
__________________
95 ranger "Wreck It Ranger
97 explorer "Green Bandit"
Quote:
Originally Posted by Joe Dirt View Post
It spatters at both the beginning and end of the stroke. .
Pro, but the dongle I had quit working.
rickybobby is offline   Reply With Quote
Old 03-04-2012, 02:48 PM   #8
albi1cnobi1
Elite Mountaineer
South Jersey
Vehicle Specs
Quoted: 106 Post(s)
You might be confused, I don't think anyone mentioned AWD. You're right, AWD came in the v8 explorers, your v6 has the control-trac auto4wd/4hi/4lo. No 2wd option.
__________________
Al
Old 03-11-2012, 07:28 PM   #9
hawkboy
maryland
98 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
4wd auto
Its believed my 98 explorer V6 4.0L sohc is 4wd auto with control track. I think the dash panel has been replaced with a 96 explorer. Question- should I hear the switching click when switching between 4Auto and 4wd high. or should I just hear it between 4wd high and 4wd low.
Any in sight would be helpful.. thanks
Old 03-11-2012, 08:02 PM   #10
albi1cnobi1
Elite Mountaineer
South Jersey
Vehicle Specs
Quoted: 106 Post(s)
You won't hear any switching of the shift motor between 4auto and 4hi. The only thing you'll hear is between 4hi and 4lo. Auto to 4hi is done electrically, 4hi to 4lo uses the shift motor to mechanically engage the shift collar. That's what you hear.
__________________
Al
Old 03-11-2012, 08:04 PM   #11
my98nnj
Boonton, New Jersey
1998 XLT
Vehicle Specs
Quoted: 71 Post(s)
The unit is always in auto 4wd unless you select otherwise.
I hear no noise (click) when selecting 4H, only when in neutral selecting 4Low.
Your truck seems to be operating correctly.
The owners manual might be a good read for you. If you don't own one, google it.
my98nnj is offline   Reply With Quote
Old 03-11-2012, 08:08 PM   #12
hawkboy
maryland
98 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thank you for all the input. makes me feel a whole lot better. thanks again
Reply
Tags
4wd problems, shift motor, stuck in 4wd auto, transfer case issues, troubleshooting
Similar Threads
Thread Thread Starter Forum Replies Last Post
Are you a redneck? jjue General Topic Polls 132 04-03-2015 08:32 PM
Persian New Year Sams01XplrSprt Exploring every thing under the sun!! 22 04-25-2009 02:12 AM
Boycott Valvoline (Personal Experience) X6StringerX Exploring every thing under the sun!! 11 07-15-2006 01:29 PM
Moab 2004 Registration, Itinerary, and Trail Guide GJarrett Offroad 4x4 Runs Planning and Discussion 2 03-01-2004 10:18 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
