| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
1996 Ford Explorer
96 Explorer, Please Help
Explorer Specifications:
1996 Ford Explorer XLT 134k miles 4.0L 4X4 Problem: My ford explorer sometimes runs rough and the battery gauge sputters. Sometimes it dies unless I accelerate. When driving it dies at stop signs and check engine comes on, but If I turn it completely off and back on it starts but the battery gauge is still sputtering and dies unless I give it some gas. This problem doesn't occur all the time, which is why the mechanics at the shop cant seem to fix the problem. They say there is no codes coming up and I cant get it there when the problem is occurring. Back about a month ago the AC tilt/pulley locked up, so they put a bypass pulley to fix that problem. It seems that this problem only occurs after driving it for a while and when its relatively warmer out. I've heard that it could be something to do with the ignition module and/or coil pack? Any help would be greatly appreciated!! |
#2 | |
Albany, NY
96 EB V6 OHV 4WD
Quote:
#3 |
1996 Ford Explorer
I've had them check all the electrical components (battery, Alternator, Starter)
and they all came back with normal readings. They've checked the belt twice now too. They told me that they can't solve it unless they can take a look at it when the problems concurring. Thing is twice now when its occurring, I've tried to make it there and as soon as i pull in seems to run fine. Its a curse. Any other things it could be? |
#4 | ||
Albany, NY
96 EB V6 OHV 4WD
Quote:
Quote:
Another problem could be an air leak or vacuum hose, but you would likely have codes. |
#5 |
1996 Ford Explorer
Okay, I've cleaned the IAC. It was really dirty and gunked up in there, hopefully it fixes my problem. Thank you
#6 |
1996 Ford Explorer
Drove it a little today and the problem occurred again. I drove it about 5 miles and let it sit for about 10 minutes, came back and on first & second start up's it died. Third I gave it some gas, and made it home. Battery gauge sputtered and almost died at every stop sign, Made it close to my house and problem stopped, ran fine at idle in my driveway after that.
It was at noon today, and its about 75 degrees out if that matters. ( seems to happen more often on hot days) Can an old fuel filter or old spark plugs cause this kind of problem? |
| Tags |
| 96 explorer, electrical problems, help is needed, running rough, starting problems |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2011 & 2012 Ford Explorer TSB's | JDraper | Stock 2011 - 2014 Ford Explorer Discussion | 0 | 01-20-2012 10:58 AM |
| Top search phrases for this site | Rick | Suggestion Box - Forum Feedback | 11 | 09-12-2011 09:22 AM |
| Help me lift my 96 explorer | explrst4urma | Modified 1995-2001 Explorers | 2 | 01-26-2010 04:46 AM |
| 96 explorer with 98 4x4 trans ? | lots-of-fords | Explorer & Ranger Transmissions, Transfer Cases, & Differentials | 3 | 11-26-2009 08:21 AM |
| Trans swap from 96 explorer to a 96 mustang | seahawksfan | Stock 1995 - 2001 Explorers | 7 | 10-26-2009 01:03 PM |
| Thread Tools | |
