Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Changing serpentine belt on a 4.6
Reply
Thread Tools
Old 03-19-2012, 07:04 AM   #1
zavetsky
'94 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi all
It has been a long time since I have visited as I sold my Explorer a while back.
But a friend of mine has a 2004 Mountaineer with the 4.6 v8....he was looking to change his serpentine belt but it appears to him that the shroud and maybe the fan has to come off. Or that the tensioner has to come off in roder to facilitate.....
Can someone here who has done it post some info or pictures or whatever to help guide him?
Seems to me that something like a serpentine belt should be easy to change.....
Any advice? He is thinking about just going to a stealership to do it.....seems like that is $50 he can save.....
Thanks in advance
__________________
1994 Explorer 4x4: GONE!
Now: 2003 Dodge Durango 4x4!!
zavetsky is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-19-2012, 08:30 AM   #2
esclamada
KCMO
'02 Mountaineer AWD V8
Vehicle Specs
Quoted: 28 Post(s)
you just need to release the tension, space is tight.
http://www.facebook.com/media/set/?s...2348605&type=3
MY MOUNTY
http://www.facebook.com/diyfordexplorer?sk=photos
esclamada is offline   Reply With Quote
Old 03-19-2012, 08:49 AM   #3
Yadkin
The beautiful Yadkin Valley in the Great State of North Carolina
2012 Jeep GCO
Vehicle Specs
Quoted: 0 Post(s)
There is a 3/8" square drive fitting on the tensioner, back side of the pulley (facing the front of the vehicle). Insert your 3/8" drive, use a pipe on the end of the wrench for leverage and turn counterclockwise to increase tension on the tensioner spring (release the tension on the belt).
Yadkin is offline   Reply With Quote
Old 03-19-2012, 10:12 AM   #4
zavetsky
'94 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
So no need to remove any other parts like fans etc?
__________________
Old 03-19-2012, 10:26 AM   #5
esclamada
KCMO
Vehicle Specs
Quoted: 28 Post(s)
You don't need to remove any of the parts, just release the tension and remove the belt. Put in the new belt based on the belt routing guide somewhere on the hood. I have to borrow the serpentine belt tool in Advance Auto because my 3/8 ratchet drive for the tensioner will not fit in (the depth is too wide for the space available). Pull that tool towards you when it's in place. You have to go under to properly put the belts under the crankshaft pulley and A/C. It could be done for less than 10mins.
MY MOUNTY
Old 03-19-2012, 10:57 AM   #6
zavetsky
'94 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Relayed this info to my friend and he replied:
"If i turn counterclockwise, I would increase the pressure on the belt. I would need to go clockwise to release the tension, pushing the pulley down as my belt runs up and over the pulley. Plus, unless I can really really move that pulley, there is no way to slip off the belt past the engine block. "
__________________
Old 03-19-2012, 12:02 PM   #7
esclamada
KCMO
Vehicle Specs
Quoted: 28 Post(s)
use the serpentine belt tool clockwise to release tension. It's easy compared to an oil change.
MY MOUNTY
Old 03-19-2012, 02:04 PM   #8
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 122 Post(s)
Just turn the dang thing the correct way to relieve tension on the belt. It's clockwise if you look one way, counter clockwise if you turn yourself around./.....
imp
imp is offline   Reply With Quote
Old 03-19-2012, 08:48 PM   #9
Yadkin
2012 Jeep GCO
Vehicle Specs
Quoted: 0 Post(s)
I assumed it was the same direction for the 4.6 as my 4.0, apparently not. In any event, turn the wrench so the tensioner pulley makes the belt go slack. Then slip it off the nearest pulley, carefully release the wrench, then slip the belt off.
Old 08-05-2013, 04:24 PM   #10
partybob99
NW Ohio
2003 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
I just changed my belt on a 2003 Ford Explorer Eddie Bauer 4.6L this weekend and I have to get in my two cents.
1) You need a 1/2" drive ratchet or breaker bar to fit into the hole in the belt tensioner. I tried finding a 3/8" breaker bar after reading this thread and it was not the correct size.
2) I ended up using a 1/2" Craftsman ratchet to loosen the tension on the belt, but I accessed the tensioner from the bottom of the vehicle. I was barely able to squeeze the ratchet in there but after playing around with the fan blades it worked. I had someone up top who then pulled the belt off the alternator after I swung the tensioner out of the way.
3) Standing in front of the vehicle with the hood open, feed the new belt between the two idler pulleys and use it to wrap around the AC pulley and then the crank. It is tricky and it took me a while to get it right. I kept referring to the belt diagram repeatedly, but I got it.
4) Make sure the belt is tight around all other pulleys and that the slack is lined up around the alternator. Again, I pulled the tensioner down from the bottom of the vehicle and had my helper slip the belt around the alternator.
I believe it took me over an hour to complete. I thought it was a lot harder than an oil change in my opinion! Good luck
partybob99 is offline   Reply With Quote
Old 08-06-2013, 08:18 AM   #11
JoshMcMadMac
Waynesboro, PA
2002 Mercury Mountaineer
Vehicle Specs
Quoted: 55 Post(s)
Part #2 of this write-up should help visualize the procedure, as well as the belt routing:
http://www.explorerforum.com/forums/...d.php?t=294228
__________________
2002 Mountaineer Premier: Intake, exhaust, under-drive pulleys, electric fan, tune, GF springs, 18's, tint
JoshMcMadMac is offline   Reply With Quote
Old 08-06-2013, 08:52 AM   #12
pet575
Kansas City, MO
2004 Limited
Vehicle Specs
Quoted: 27 Post(s)
I've done this job myself on my own vehicle and it is VERY easy to do as described above. Push clockwise to loosen tension and remove the belt.
pet575 is offline   Reply With Quote
Old 08-06-2013, 09:27 PM   #13
partybob99
NW Ohio
2003 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
Removing the fan shroud in the beginning probably would have made things a lot easier! But I didnt end up doing that. Also I did not have the serpentine belt tool - which would have helped as well because it looks quite a bit thinner than the 1/2" ratchet. I'm not sure moving the idler pulley out of the way from the underside of the vehicle is the easiest method but it does work.
Old 06-05-2014, 01:15 PM   #14
Donystoy
Hamilton, Ontario
02 Eddie Bauer
Vehicle Specs
Quoted: 28 Post(s)
I looked at doing this job today and it sure seems to be a tight spot to work. I ended up using a large pipe wrench to turn the tensioner as I just could not get my 1/2" braker bar into the hole. How do you get the belt around the back of the tensioner? There only seems to be about 1/16" clearance behind the pulley. Does it have to be removed? Sure isn't as easy as working on a Crown Vic.
Update: Got it changed. I did have to remove the complete tensioner and finally was able to use the breaker bar to re-install. Certainly is a knuckle buster though.
Donystoy is offline   Reply With Quote
Old 12-24-2014, 12:19 AM   #15
Mavrick161
Michigan
2001 XLT AWD 5.0
Vehicle Specs
Quoted: 0 Post(s)
Not the worst job ever, but it's a little of a challenge. I got a 1/2" drive into the tensioner on my 2003 Mountaineer 4.6 but it was a tight fit. When you are facing the car from the front, it has to be turned clockwise to loosen the belt.
Mavrick161 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Quick/Dumb Question about Serpentine Belt Installation roblutter Stock 2002 - 2005 Explorers 15 11-04-2010 06:36 PM
Serpentine Belt Question From a Newb pmarsh Stock 1991 - 1994 Explorers 8 08-21-2007 01:59 PM
'94 with serpentine belt problems treeman Stock 1991 - 1994 Explorers 5 08-07-2007 06:56 PM
serpentine belt tensioner beachman Under the Hood 1 02-16-2006 11:40 PM
Serpentine Belt Replacement? firedepot Stock 1995 - 2001 Explorers 2 01-02-2006 11:31 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
