Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > New Members - Photo Gallery- Explorer Registries - Features - Reviews > New Member Forum
Notices
New Member Forum The place for new members to introduce themselves to our family of Ford Explorer enthusiasts and to ask any questions about the message board software. Welcome aboard!!
map sensor
Reply
Thread Tools
Old 03-24-2012, 08:02 PM   #1
blackrod
California
1997 Ford Explorer 5.0
Vehicle Specs
(Original Poster)
map sensor
I have a 1997 explorer 5.0. Its throwing a code that indicates that the MAP sensor is faulty. I was also under the impression that the 97 has no MAP sensor and that it uses the MAF sensor instead.. Can anyone confirrm or deny this. Also if there is a map sensor where is it? Bow to the experts.. time is of the essence. Thanks
blackrod is offline   Reply With Quote
Old 03-24-2012, 08:19 PM   #2
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
2000 Sport SOHC 2WD
Vehicle Specs
MAF Sensor
You are correct. All of the 2nd generation engines (4.0L OHV & SOHC V6 and 5.0L V8) utilize MAF sensors. What was the specific diagnostic trouble code?
__________________
My Helpful Threads, Registry, 16.4/23 mpg, 3900 lbs, 5R55E, 3.73:1, 175 rwhp, Henson custom tune, CAI, Spectre air filter, Lightning 90mm MAF, 75mm throttle body, A/F ratio meter, synthetic oils, Accusump, 2 row radiator, 3+1 leaf springs, .75 inch drop, Edelbrock IAS lowering shocks, engine oil & ATF temp gauge & remote filters & coolers, remote crank
2000StreetRod is online now   Reply With Quote
Old 03-24-2012, 08:59 PM   #3
blackrod
California
Vehicle Specs
(Original Poster)
I dont know. my brother in law took it in and I forgot to get the paper work.. I will get back to you tomorrow. please keep an eye out for this post. Thanks
Old 03-24-2012, 09:03 PM   #4
blackrod
California
Vehicle Specs
(Original Poster)
So if it says to replace the MAP does it actually mean replace the MAF? The part they quoted is about $260. Sounds darn expensive. What do you think?
Old 03-24-2012, 09:37 PM   #5
2000StreetRod
Greenville, SC
2000 Sport SOHC 2WD
Vehicle Specs
possible DTCs
Here is a list of possible diagnostic trouble codes associated with the MAF/MAP sensor:
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
I would expect to be in the P0100 to P104 range. The MAF sensor is fairly reliable. The first thing I would do is check the electrical connector to make sure it is making a good connection. The sensor element can be contaminated by oil from a new cone style oiled air filter. The sensor can be cleaned with an aerosol specific for MAF sensors that can be purchased from you local autoparts store. Do not touch the sensor as it is fragile. Just spray it and let it air dry. If you clear the DTCs and neither of the above help then check the wiring to the MAF sensor for broken or shorted wires. The last thing to do is purchase another MAF sensor.
__________________
Old 03-24-2012, 10:06 PM   #6
blackrod
California
Vehicle Specs
(Original Poster)
Ford did the diagnostic so I suppose they listed the code. I ll find out tomorrow
Old 03-26-2012, 04:51 PM   #7
blackrod
California
Vehicle Specs
(Original Poster)
Hey streetrod, the code is not any of the ones listed. The code Ford gave me was P0176. I have no idea what that is. Can you help?
Old 03-26-2012, 06:11 PM   #8
2000StreetRod
Greenville, SC
2000 Sport SOHC 2WD
Vehicle Specs
P0176?
Quote:
Are you sure you have the correct DTC? I'm not aware of flex fuel capable Explorers in 1997.
P0176 Fuel Composition Sensor Circuit Malfunction
Fuel Composition Sensors are used to determine the amount of ethanol alcohol in the gasoline. Normally, a gasoline engine should not have more than 10% ethanol alcohol in the fuel for proper operation. Some vehicles have a Flexible Fuel (FF) system on them that allow them to run on up to 85% ethanol alcohol in the fuel. The fuel composition sensor sends a frequency modulated signal to the engine controller which is proportional to the alcohol content of the fuel. The injector pulse width and the ignition timing are modified for the increased alcohol content.
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Elusive Map Sensor Caught on Film- Code 22 Tbars4 Explorer, Ranger - Computers, Chips, Tuning 21 09-14-2011 09:09 PM
96 5.0L P0402 but no DPFE Sensor? cbr rob Stock 1995 - 2001 Explorers 31 09-02-2010 08:32 PM
Pulling a stuck o2 sensor Stick_man Stock 1995 - 2001 Explorers 20 02-14-2010 09:35 AM
MAP SENSOR fire232 Under the Hood 5 04-04-2009 08:15 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
