Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Clunk in drivetrain
Reply
Thread Tools
Old 03-29-2012, 01:09 PM   #1
klosch80
Baker, NV
1999 Explorer 4.0L 4X4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Clunk in drivetrain
Hey all,
New to the forum here and got some issues.
My 1999 explorer 4.0L 4x4 auto has 172,000k on it. Just drove from Portland to Baker, Nevada and noticed a clunking, almost jerking thing. Its hard to describe but it doesn't feel like the motor is stalling, more like tranny or rear end? It only happens at higher speeds and above 2k RPM. It is not while shifting. It definitely seems worse while pulling hills or any time I put more load on the motor.
I have a check engine light but the code is P0174 which I hear is common on these motors and related to MAS or vacuum leaks and don't believe they are related, but maybe I'm wrong about that.
Any help is appreciated. Thanks
Kevin
klosch80 is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-29-2012, 01:35 PM   #2
masospaghetti
Charlotte, NC
2000 Sport, 5M OHV RWD
Vehicle Specs
Quoted: 148 Post(s)
three common sources of a driveline "clunk" (there may be more, but these are relatively common)
1. BW4405 transfer case output shaft bore becomes elongated
2. Rear driveshaft splined slip-joint is either worn or needs lubricant
3. Worn u-joints
I would try lubricating your slip joint first since that's essentially free. I believe the "right" stuff is a special blue-green Ford grease, but I think a good Moly grease would work fine.
You can check for #1 by grabbing the rear driveshaft, right where it comes out of the transfer case, and feeling for any up-down play.
__________________
2000 Sport, 4.0 OHV, 5M, RWD, 176,000 miles
1996 XLT, 5.0, 4A, AWD, 161,000 miles
1998 XLT, 4.0 OHV, 5M, 4WD, 236,000 miles
masospaghetti is offline   Reply With Quote
Old 03-29-2012, 03:07 PM   #3
klosch80
Baker, NV
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks, I will look at those this evening
Old 03-29-2012, 04:01 PM   #4
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 122 Post(s)
3. Worn u-joints
1., above: I think the output shaft bore is actually the I.D. of the output shaft bearing. In any event, if the bearing is shot, or its locating pocket in the case is wallowed out (unlikely), if sufficient clearance exists to "feel" up-down movement, the seal should already be leaking, or will be, soon.
2. Think wobble at this location will cause vibration, as the driveshaft spins out of "true".
3. A possibility. But since driveshaft revolves VERY fast, "clunk" describes a low-repeat-speed noise, like from something turning much slower, or not turning at all
Easily checked, visual or by wrench: Broken or loose rear transmission mount. Broken or loosened rear axle center-section mounting.
Just a few additional thoughts. imp
imp is offline   Reply With Quote
Old 03-30-2012, 04:01 PM   #5
klosch80
Baker, NV
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ok so last night I crawled underneath to check things out. No play in the rear drive shaft at the transfer case. U joints all look good. I noticed when trying to check for play in the rear driveshaft that I could move the transfer case and transmission, so now I'm thinking about the transmission mount idea.
This truck was laid on its side in the snow this winter. My girlfriend on icy roads :/ I replaced passenger window, checked all fluids, took her for a test drive and everything seemed ok, but now a broken mount could definitely be a possibilty. Not sure I know what is meant by the center mount on the rear axle, but I will look around in that area to see what I can find.
Thanks for the suggestions.
Old 03-31-2012, 01:55 PM   #6
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 122 Post(s)
My error on the center mount: 2nd. gens have solid rear axle, not center frame-mounted differential, my apologies. Broken transmission mount almost always involves failure of the rubber-to-metal bond of the parts, and may not be "seeable" until the engine/transmission assembly is raised slightly to allow removal and inspection of the mount itself. imp
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Stumped by a Transfer Case Engagement Problem- Please Help. 2Explorers Explorer & Ranger Transmissions, Transfer Cases, & Differentials 30 02-27-2011 08:15 AM
Gerald Jarrett - Simpsonville, SC 2nd gen offroad GJarrett Explorer Registry 74 12-25-2009 12:26 PM
Gerald Jarrett's Rubicon Trip Report 2003 GJarrett Offroad 4x4 Runs Planning and Discussion 15 05-22-2007 07:08 PM
This is gross. CADDYBILL Exploring every thing under the sun!! 60 05-30-2003 05:07 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
