Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Merc Mountaineer leaf springs
Reply
Thread Tools
Old 04-08-2012, 11:10 AM   #21
GuardianSport
Lindsay, ON
'00 Sport 4x4 - '98 EB
Vehicle Specs
No, springs.
It is my understanding that one is better off getting shackles fabbed, the Ford ones are of rather thin construction.
__________________
________
[_l_|_,\___\,__
l---__---_[=-==-=]
/¯¯\----/¯¯\ - __-¯¯\
()_)'¯¯`()_)--{}--)_)
It was a blast, old girl.
GuardianSport is offline   Reply With Quote
Old 04-08-2012, 11:12 AM   #22
GuardianSport
Lindsay, ON
Vehicle Specs
Quote:
Originally Posted by O.G. View Post
How do suspension shops re-arch the springs?
Weight and heat.
__________________
________
[_l_|_,\___\,__
l---__---_[=-==-=]
Old 04-08-2012, 12:08 PM   #23
JimMadsen
New Britain, CT
2000 Mercury Mountaineer
Vehicle Specs
(Original Poster)
alright it is all back together. i was unable to change them i got the driver side lower bolt out and the passenger side upper bolt out. but the other two bolts are rusted in. sigh
so i put new bolts into the open spots to avoid the problems when i go at it again. i am not sure how to get them out though. they are pretty well seized and i only have a dremel with a cutting wheel, no sawz-all or angle grinder.
at least it is back together though. if anyone is local, i will be willing to pay some to cut those bolts out.
either that, or anyone have any advice? i did discover that with the top bolt out, i can use a scissor jack between the frame and leaf to lower the shackle below the muffler, maling it easier to whack with the sledge!
JimMadsen is offline   Reply With Quote
Old 04-08-2012, 01:38 PM   #24
GuardianSport
Lindsay, ON
Vehicle Specs
Happened to my Sport, though it was the upper so I couldn't swap in the shackles I wanted to, just change the leafs.
__________________
________
[_l_|_,\___\,__
l---__---_[=-==-=]
Old 04-08-2012, 02:03 PM   #25
bluestream1
Waterloo Ontario
2000 XLT 4.0 SOHC 4X4
Vehicle Specs
JIm, consider renting the tools you need to get the job done...
__________________
2000 Ford Explorer SOHC 4X4 249,000KM
2003 Ford Escape 101,000KM
bluestream1 is offline   Reply With Quote
Old 04-08-2012, 04:10 PM   #26
JimMadsen
New Britain, CT
Vehicle Specs
(Original Poster)
what should i rent? just an angle grinder, cut the head of the bolt and whack at it from the opposite side?
one thing i wouldn't mind geyting would be an air hammer to pound it that way. however i only have a one gallon compressor. is there an electric version like there is for impact wrenches? i am familiar with hammer drills, but do not think that would do anything as it is really only adding toruqe.
Old 04-08-2012, 08:44 PM   #27
GuardianSport
Lindsay, ON
Vehicle Specs
A torch to heat up the steel around the shackle/bushing to expand and "crack" the bolt loose. Then a punch and good sized hammer.
__________________
________
[_l_|_,\___\,__
l---__---_[=-==-=]
Old 04-08-2012, 10:03 PM   #28
DieselHilux
Vehicle Specs
I do these all day long, you need an air hammer and heat, that s the ONLY way they will ever come apart.
I do not use a torch however, we have a mini-ductor at work and I use it constantly!!
It is magical there is no other way to describe it, look it up online and it plugs into any standard outlet
DieselHilux is offline   Reply With Quote
Old 04-08-2012, 11:55 PM   #29
GuardianSport
Lindsay, ON
Vehicle Specs
Those look cool, what kind of temperatures are you looking at?
__________________
________
[_l_|_,\___\,__
l---__---_[=-==-=]
Old 04-15-2012, 05:21 PM   #30
JimMadsen
New Britain, CT
Vehicle Specs
(Original Poster)
Alright, I put an add up on craigslist and got a guy to do them for $50 a side. We got the passenger side done (shackle, lower bushing) but had such a hard time replacing the lower bushing, left the top one in place. The driver side was a no go. It does not make any sense, but we could not break the bolt loose. It almost seems as if it is welded on! We talked about just cutting the head off the bolt and torching the bushing to get it out (thats how we got the other one done) but I do not have a upper rubber portion bushing to replace it. So anyone know where to get one? I just got the metal tube bushing for the top, entire piece for lower.
The driver side shackle is in better shape than the passenger, so I will gather the parts I want to replace over the summer (leaf springs, shackle bushing, brake line that is rusted out) and get it all done early fall.
Now onto that pesky ac problem. I will do another post for that one.
Thanks for the help all!
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Wagoneer Springs??? Leaf Spring Sas / Lift Mutineer Modified 1995-2001 Explorers 6 04-04-2008 04:42 PM
3" Mono leaf Vs 2 1/2" 4 leaf springs Larry2010 Modified 1995-2001 Explorers 3 02-16-2006 08:51 PM
Removing the Leaf Springs dutch724 Stock 1991 - 1994 Explorers 2 01-28-2006 10:17 AM
new leaf springs: not so good :( SGR1600 Explorer - Ranger Shocks, Suspensions, Lift Kits 12 11-16-2004 08:17 PM
Squeaky Leaf Springs bmonahan Explorer - Ranger Shocks, Suspensions, Lift Kits 11 05-22-2004 11:27 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
