Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Where do you measure the temperature of the trans
Reply
Thread Tools
Old 04-02-2012, 05:05 PM   #1
cr500guy
san diego
1992 prerunner
Vehicle Specs
(Original Poster)
I have a a4ld that I rebuilt, It works great. I installed the electric temp sending unit in the 1/8 pipe hole used for checking the pump pressure. The termp goes to 250 without much load. The question is to the experts in this forum; by measuring the temp at what is basically a dead end hyd circut does that represent the true temp of the trans and if not how much lower would it be if installed in the pan? I must saythat without this forum and the "diary" I never would have attempted my 1st overhaul of an auto trans.
Thanks:rangerred
cr500guy is offline   Reply With Quote
Old 04-05-2012, 09:10 AM   #2
wood1
North of Ottawa
wood1's Avatar
'93 XLT, Cayman Green RIP
Vehicle Specs
Dude 250 sounds very high. Brooklyn has tranny temp charts in his useful threads and it seems that anything over 200 is high. Read them and make up your own mind if you like. Sounds as though there is some slippage but I do not profess to be an expert.
__________________
Ribs. I had ribs for lunch, that's why I'm doing this.
List of useful TTB Threads
wood1 is offline   Reply With Quote
Old 04-05-2012, 09:41 AM   #3
Tbars4
Offroad Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
..Here are a couple of the many threads here worth reading on the subject..
http://www.explorerforum.com/forums/...d.php?t=179884
http://www.explorerforum.com/forums/...d.php?t=225103
..Location does play a major role on where to read temps from..That first link discusses that a number of times..
..However, the A4LD is a hotter running transmission and it is not unusual to see temps in the 190* range in the summer under somewhat of a load..
...I have had mine spike on steep highway hill climbs and actually start to purge out the fill tube on one very steep freeway climb in the summer and the temp shot up to 210*..
..Needless to say I avoid that ridiculously steep section of freeway..
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
a4ld to Manual M50D Swap How-to 94fourdoor Explorer & Ranger Transmissions, Transfer Cases, & Differentials 94 02-04-2013 08:21 PM
Can a trans flush help a problematic trans on '05 Ford Explorer? desertheat Stock 2002 - 2005 Explorers 2 04-22-2011 09:02 PM
A multi-use gauge mod – transmission fluid/engine oil temperature aldive Modified 1995-2001 Explorers 11 03-10-2011 06:33 AM
how too swap engine and trans EddieS Stock 1991 - 1994 Explorers 0 08-06-2010 12:55 PM
Oil Temperature Gauge install - an alternative temperature source Bronco638 Modified 1995-2001 Explorers 15 08-03-2009 11:52 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
