| Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories. |
Thread Tools |
#1 |
Elite tree-smasher
Bloomington, Indiana
04 Ranger Edge
2004 Ranger Cylinder 4 misfire
So I recently bought a 2004 Ranger Edge with the 3.0L in it, and for the most part it runs beautifully.
However, I keep getting p0304 (cylinder 4 misfire) and a p0316 (misfire detected on startup) codes along with a slightly rough idle. I was only getting the codes on hot startups, and even then they didn't come around much. The plugs I just replaced with Autolite platinums, the wires test fine, they are fairly new Beldens. I cleaned the MAF with no change. While testing different things, I noticed that when sitting hot and idling for a few minutes, the misfire condition becomes noticeably worse, up to the point where it is a constant misfire and the CEL starts blinking. Rev the motor up for a minute, CEL goes out and it starts running smoother again. It is definitely not a complete miss, but it also isn't firing a strong as the other cylinders. I took it out for a short drive and afterwards the idle was smooth and there was no misfire, until it idled for a bit. This only happens when the truck is warm, it doesn't do it when cold. I checked the upper intake gaskets by spraying carb cleaner around the area but the idle didn't jump. There doesn't seem to be any other vacuum leaks. This truck only has 84,000 on it, and given that for the most part it runs fine I seriously doubt there is anything internal going on, especially because this truck has definitely been taken care of in it's life. Pretty much everything is in perfect shape. Anyways, this is bugging the crap out of me so any suggestions would be appreciated. __________________ Jesse '94 Eddie Bauer DD/Beater "Old Faithful" RIP '04 Ranger Edge DD "Black Knight" You want to see my face? |
#2 |
Offroad Moderator
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
..Just my personal assessment on the 3.0's and this is if they do not even have the other problems that the 3.0 w/ flex fuel has..
..I have helped a number of people out here chasing that same problem on the 3.0 Rangers of different years.. ...Head problems are common on the 3.0 and until they are swapped with new and not rebuilt you shall be chasing these symptoms as they keep changing.. ...I've had Dealerships tell me this is a known issue and they have even swapped the heads under a resale warranty for the customer/ one of my friends truck...On the other hand, I have had guys from the dealership swear they never heard of head problems with the 3.0.. ![]() ..The best way to chase this is by doing compression test... ..This of course is only if you have already ruled out bad wires/plugs, bad ground on coil pack, etc.. ![]() .. ..If you could take a picture of that may help others to for what to look for..
__________________ I have Rocks in my head. What's in yours? ![]() '95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel '91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's ListHow to: Wheels,Tires, & Lifts... Buy Explorerforum.com Items here |
#3 |
Elite tree-smasher
04 Ranger Edge
Yea I know about the head issues, it would seem to me on such a low mileage motor it shouldn't be a problem. I do need to do a compression test, just haven't been able to do it yet.
It doesn't say anything anywhere about running Iridium plugs, so I will assume for now the platinums are fine. The coil pack hasn't been tested, I need to do that too, but I believe it is fine. The truck runs great most of the time, its just the hot idling its having problems at. Even still it isn't that noticeable, I've driven vehicles that idled worse when they were running correctly. __________________ Jesse '94 Eddie Bauer DD/Beater "Old Faithful" RIP '04 Ranger Edge DD "Black Knight" You want to see my face? |
#4 |
Offroad Moderator
..Curious but what does it say on your header panel sticker? It should have a plug number and gap on the bottom of the sticker.
..I was wrong on another 3.0's plug and am wondering if the iridium is a Cali only thing..
#5 |
Elite tree-smasher
04 Ranger Edge
It doesn't say anything under the hood about the plugs other than the gap. However, I looked in the owners manual to see what plugs it had listed, and it just said to take it to the dealership. That kind of tips me off about the plugs being strange. I found a service manual so I will see if its in there
Edit: I should mention the sticker on the truck says it conforms to us and cali emissions. Perhaps it is a cali truck __________________ Jesse '94 Eddie Bauer DD/Beater "Old Faithful" RIP '04 Ranger Edge DD "Black Knight" You want to see my face? |
#6 |
Elite tree-smasher
04 Ranger Edge
So I looked around, the plug that is listed for my truck on the motorcraft website is a nickel plug. I looked and I can get Iridiums for my truck, but I can get all types of plugs. So who knows. It is strange the part number for the plugs is so hard to find.
#7 |
Offroad Moderator
..I do know for sure that the 2006 3.0 cali Ranger requires Iridium plugs and it is on the sticker..
..The one Ranger 3.0 I was wrong about before had no plug info like yours and I had them change from the platinum to the dbl platinum and they said that helped them a lot... ..I am not saying it is your fix but if I had the funds and even if I did the compression test, (until I swapped the heads), I would try the DP's.. __________________ I have Rocks in my head. What's in yours? ![]() '95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel '91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's ListHow to: Wheels,Tires, & Lifts... Buy Explorerforum.com Items here |
#8 |
Elite tree-smasher
04 Ranger Edge
I'm tempted just to throw some iridiums in there anyways since I believe they are supposed to be the best plugs.
I drove it again just now and on the warm start there was initially no light but after a minute it came on. Ran the codes and I had one for random multiple misfires in addition to the others this time. Seeing as how it seems to be getting worse as the plugs break in I feel like they may be causing the problem __________________ Jesse '94 Eddie Bauer DD/Beater "Old Faithful" RIP '04 Ranger Edge DD "Black Knight" You want to see my face? |
#9 |
Offroad Moderator
What were the plugs you took out?
..It is not unheard of to get a faulty new wire or plug when they are brand new.. ![]() ..You can easily move the #4 wire and plug over to another cylinder to see if the misfire moves with them. I wouldn't rule out firing order either. __________________ I have Rocks in my head. What's in yours? ![]() '95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel '91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's ListHow to: Wheels,Tires, & Lifts... Buy Explorerforum.com Items here |
#10 |
Elite tree-smasher
04 Ranger Edge
The plugs that came out were new Bosch Platinums that came in the truck, that's the main reason I replaced them in the first place.
The wires tested out fine, but I do need to swap them and see if that's the problem. I doubt firing order is the issue, as it runs smooth as silk at anything above idle. Thanks for the suggestions so far Tbars __________________ Jesse '94 Eddie Bauer DD/Beater "Old Faithful" RIP '04 Ranger Edge DD "Black Knight" You want to see my face? |
#11 | |
Offroad Moderator
#12 |
Elite tree-smasher
04 Ranger Edge
Both, actually.
#13 |
Elite tree-smasher
04 Ranger Edge
Okay, so compression checks out even through all cylinders, so that should help rule out a head issue. I swapped wires with no change, tested as well and they all have very low resistance.
I looked up the spark plugs on the motorcraft website by using the VIN number and it came up with platinums and nickle plugs. However, I'm still tempted to try some Iridiums just to see what happens. I'm also starting to run out of ideas on this one. Could a camshaft position sensor be part of this at all? __________________ Jesse '94 Eddie Bauer DD/Beater "Old Faithful" RIP '04 Ranger Edge DD "Black Knight" You want to see my face? |
#14 |
Offroad Moderator
..Did you swap the plug and what were your compression readings?
..Usually a CPS just goes..Unless you know of it or other parts recently being swapped in just before purchase till now.. __________________ I have Rocks in my head. What's in yours? ![]() '95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel '91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's ListHow to: Wheels,Tires, & Lifts... Buy Explorerforum.com Items here |
#15 |
Elite tree-smasher
04 Ranger Edge
I don't remember the exact compression readings, they were all within 10 psi of each other though. I didn't swap the plugs, I should try that and see what happens. I do know it through the same codes with the bosch plugs, which leads me to believe they aren't the problem.
#16 | |
Offroad Moderator
Quote:
..I would also make sure your spout connector is in place, timing belt (chain?) and timing are good.. ..I'm running out of ideas and would still bet on the heads but if I were you and while searching the forum, I would keep an eye on this new thread as some other ideas may come up on it.. ![]() http://www.explorerforum.com/forums/...d.php?t=351690 __________________ I have Rocks in my head. What's in yours? ![]() '95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel '91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's ListHow to: Wheels,Tires, & Lifts... Buy Explorerforum.com Items here |
#17 |
Elite tree-smasher
04 Ranger Edge
One more thing for right now until I go tinker some more... OE plugs for this truck are Motorcraft part# 432. They are not the normal platinums, they are special ones. Maybe that is the problem.
#18 |
Offroad Moderator
..Hopefully someone with information on that specific plug will join in here..
..But yes, there are several factors taken into account for spark plugs which most people do not even think about.. ..Even though a parts house spits out a certain number for your vehicle only means it is what they are selling as a common plug for your vehicle.. ..I believe this to be the true oem p/n for your truck.. P/N SP-432 / AGSF32FM __________________ I have Rocks in my head. What's in yours? ![]() '95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel '91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's ListHow to: Wheels,Tires, & Lifts... Buy Explorerforum.com Items here |
#19 |
Elite tree-smasher
04 Ranger Edge
So I went ahead and got a set of the SP432s and put them in. For starters, somehow I had the gap about .10 too big on the other ones, so that wasn't helping for sure.
However, the problem is still there. I drove it for awhile and it definitely felt better though. I haven't gotten a CEL yet, and I let it idle for awhile in the driveway, where I observed something else. It only has the miss when in park with the A/C off. I cranked the A/C and idled in park, no miss. I put it in gear and let it idle, no miss. So under any load the problem really doesn't exist. The plugs that came out all looked perfect, including the one out of cylinder #4. I'm thinking it wouldn't hurt to maybe run a seafoam treatment or at least put something in the gas to make sure I just don't have a dirty injector for some reason. I also wouldn't be against removing them and cleaning them outside of the truck. Is there anything else I can do to check the head out without actually removing it? If that is the problem I will probably just run it as is until it gets bad, and I could also try a little stop leak to see if that fixes things up for now. __________________ Jesse '94 Eddie Bauer DD/Beater "Old Faithful" RIP '04 Ranger Edge DD "Black Knight" You want to see my face? |
#20 | |
Wannabe Elite Explorer
Southeast USA
2000 Sport
Quote:
I've seen problems like this that turned out to be something very simple, but will drive you crazy very quickly. Maybe clean the coil pack top. Spray or pour alcohol on the coil top and wipe it down good. If a terminal has started arcing it will make a carbon track and cause a misfire. Clean the terminal boots. I'd also be tempted to change the plug wire, since a break in the insulation could cause the miss and the wire resistance could still check good. You can open the hood on a dark night and see if there's any arcings.... The coil pack is still a suspect. __________________ 2000 Sport 4x2, 4.0 ohv, 5R55E w/Superior shift kit, 3.55 diff, Mazda truck alloys/BFG TAs, RoadMaster Active Suspension, EE anti-sway bar, F&R poly bushings, camber kit, Rancho shocks, Hooker Aero Chamber muffler, Medium Wedgewood Blue..... Bought another 2000 Sport (God help me ), 4.0 ohv auto, 60K actual miles, Cragar SS alloys/BFG TAs, AAL, EE anti-sway bar, Gibson cat-back, Harvest Gold, GT leather interior.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2001 Explorer Sport 4.0 SOHC Cylinder Misfire Codes | ironhed85 | Stock 1995 - 2001 Explorers | 44 | 03-24-2012 05:41 PM |
| Constantly have to replace ignition lock cylinder. 95 ford ranger 4 cyl 2wd | DUPEY87 | Ford Ranger - Mazda B-Series Forum | 3 | 06-23-2011 09:54 PM |
| Recurrent plug 4 misfire fixed! | greasemanicure | Under the Hood | 6 | 10-18-2010 09:24 PM |
| I can't find the starter relay on an 02 Ranger with a 4 cylinder. | dagodrummer | Ford Ranger - Mazda B-Series Forum | 1 | 07-20-2009 11:42 PM |
| 2004 ranger tranny help | takidd4597 | Explorer & Ranger Transmissions, Transfer Cases, & Differentials | 0 | 12-15-2008 12:46 PM |
| Thread Tools | |
