Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
2004 Ranger Cylinder 4 misfire
Reply
Thread Tools
Old 04-07-2012, 07:46 AM   #21
Willard
Elite tree-smasher
Bloomington, Indiana
Willard's Avatar
04 Ranger Edge
Vehicle Specs
(Original Poster)
Thanks, I will definitely give it a clean and see what happens. I should not I tested the coil pack and the resistance checked out fine. I'm still kind of suspicious about the wires as well, I will take a look at them once it gets dark and see if there is any arching going on.
__________________
Jesse
'94 Eddie Bauer DD/Beater
"Old Faithful" RIP
'04 Ranger Edge DD "Black Knight"
You want to see my face?
Willard is offline   Reply With Quote
Old 04-08-2012, 09:03 PM   #22
Willard
Elite tree-smasher
Willard's Avatar
04 Ranger Edge
Vehicle Specs
(Original Poster)
Well I may have found the issue. I finally remembered to go out and have a look with it nice and dark outside, and sure enough, I got arcing going on with that number 4 wire. It looks like a bad connection down towards the plug, that's where most of the action was. It also shot some random arcs on the other side where that wire goes around the back of the motor. I also some a little arcing on the number 1 and 2 plugs.
Also, I revved it up while I was watching, and the arcing actually went away mostly, which explains a lot. Remember this wire tested out at less than 10k ohms resistance, which should be pretty good. Definitely didn't tell the whole story though. Whenever I get paid I will grab a set of Autolite wires and throw them on to see what happens.
Edit: Went and looked some more, is it normal at all to have arcing right at the end of the boot where the wire goes over the plug? I ask because cylinders 4,5, and 6 all had a bunch of arcing at the actual spark plug like that. The more I watched it the worse it got on #4, too. It was shooting all the way up the wire almost. Cylinder 2 had a pretty nasty one too.
__________________
Jesse
"Old Faithful" RIP
Old 04-08-2012, 10:52 PM   #23
Runnin'OnEmpty
Southeast USA
2000 Sport
Vehicle Specs
Lightbulb
Quote:
No, that is not normal. There should be no arcing at all!
I'm sure you've found the problem and it should run
like a champ with new plug wires.
__________________
2000 Sport 4x2, 4.0 ohv, 5R55E w/Superior shift kit, 3.55 diff, Mazda truck alloys/BFG TAs, RoadMaster Active Suspension, EE anti-sway bar, F&R poly bushings, camber kit, Rancho shocks, Hooker Aero Chamber muffler, Medium Wedgewood Blue.....
Bought another 2000 Sport (God help me), 4.0 ohv auto, 60K actual miles, Cragar SS alloys/BFG TAs, AAL, EE anti-sway bar, Gibson cat-back, Harvest Gold, GT leather interior.
Runnin'OnEmpty is online now   Reply With Quote
Old 04-09-2012, 12:03 AM   #24
Willard
Elite tree-smasher
Willard's Avatar
04 Ranger Edge
Vehicle Specs
(Original Poster)
I'm pretty confident I found the issue as well. I can't wait to get money to put some new plug wires on this thing, hopefully it helps the gas mileage on it. I've been averaging 16.5 with quite a bit of highway, and I would like to see better with this truck
__________________
Jesse
"Old Faithful" RIP
Old 04-12-2012, 08:17 PM   #25
Willard
Elite tree-smasher
Willard's Avatar
04 Ranger Edge
Vehicle Specs
(Original Poster)
Well, got the new wires today and installed them and did a seafoam treatment while I was at it.
It definitely runs better, and after a good long drive I got back and let it idle for a few minutes, and no misfire
It still isn't a perfectly smooth idle, but I think it's probably as good as a 3.0L will get. The torque seems to be better, I noticed it downshifted less on the hills, and it seemed to climb better overall. So I'm gonna hope I've got this kicked, and now its time to save up for some power adders for this little motor
__________________
Jesse
"Old Faithful" RIP
Old 04-12-2012, 10:51 PM   #26
Runnin'OnEmpty
Southeast USA
2000 Sport
Vehicle Specs
Thumbs up
Good job!
Cool Ranger.
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2001 Explorer Sport 4.0 SOHC Cylinder Misfire Codes ironhed85 Stock 1995 - 2001 Explorers 44 03-24-2012 05:41 PM
Constantly have to replace ignition lock cylinder. 95 ford ranger 4 cyl 2wd DUPEY87 Ford Ranger - Mazda B-Series Forum 3 06-23-2011 09:54 PM
Recurrent plug 4 misfire fixed! greasemanicure Under the Hood 6 10-18-2010 09:24 PM
I can't find the starter relay on an 02 Ranger with a 4 cylinder. dagodrummer Ford Ranger - Mazda B-Series Forum 1 07-20-2009 11:42 PM
2004 ranger tranny help takidd4597 Explorer & Ranger Transmissions, Transfer Cases, & Differentials 0 12-15-2008 12:46 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
