| Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Lubbock texas
00 XLT
westin running board removal
looking to remove my westin running boards and go under the truck, turns out half the bolt you cant get to with a wrench. anybody got tips for removing these other then cutting them off? thanks. mine are mounted to the frame of my 2000 xlt 4 door
#2 |
The SOUTH
1997 xlt Explorer
This is a pretty easy thing to do, but rust is the enemy. Spray all the mounting points down with wd-40 before doing this. First, get a socket extender, and unbolt the single bolt on the front mount that secures it to the frame. It is much easier when you unbolt the westin in the front and then take the mount off. The mount will slide backwards about a foot and will slide off from on top of the frame. The second mount is much more difficult. First, unbolt the small bolt on the back-topside of the mount that secures it to the frame. Once this is completed, the hard part begins. You will need a ratchet strap to wrap around the axle. You will then run the ratchet part of the strap to the 3/4in hole that is in on the frame behind the tire. You will then need to cinch the strap down as tight as possible (to what you think is safe). This will prevent the strut from shifting way out of its mount when the pin that holds the strut in its mount and the west in to the frame is pulled out partially. Once that is done, slowly start to unbolt the large bolt on the face of the mount. Every 5 or so turns, take a hammer and pound it back to its seated position so that it doesn't thread its way out of the back hole. Once the back bolt is off, slowly start to tap the bolt out of its housing. When it is about 3/4's of the way out stop, and the westin should come rite off. If this process is done without the strap, you will have a serious "OH SHIT" moment, because it will be nearly impossible to get the strut to realign with both holes. To get the strut to move in minor increments, take a big flat head screwdriver and drive it between the strut and the housing to get it to move down. Once the hole is aligned, pound the pin back through and make sure the nut is seated in its proper fashion (check opposite side). Then repeat for the other side. You will also need to jack the car up in the rear and on the frame rail in front of the front strut mount.
#3 |
Lubbock texas
00 XLT
Thank you man. Turns out the rust was my enemy but I got them out. Thanks for your help man
#4 |
Missouri, south of St. Louis
Sounds complicated.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Removing Running Board | Wait_Im_Reloadin | 2001-2005 Explorer Sport Trac | 1 | 04-15-2010 04:44 PM |
| Power running board went out | GVSS | Stock 2006 -2010 Explorers | 3 | 03-03-2010 12:20 PM |
| Help! running board removal! | ab4x4WA | Modified 1991-1994 Explorers | 4 | 01-24-2010 11:20 AM |
| Yet another Running Board Question | Campo | Body Work & Detailing | 2 | 07-25-2002 10:28 PM |
| Thread Tools | |
