Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Bronco II > Bronco II
Notices
Bronco II Our Ford Bronco II forum covers maintenance, problem solving, 4x4 issues, and all topics regarding the 1984 - 1990 Ford Bronco II.
Starter Issues... '85 Bronco II
Reply
Thread Tools
Old 04-04-2012, 12:32 AM   #1
Venia
Huntington Beach California
1985 Ford Bronco II
Vehicle Specs
(Original Poster)
I hope people still use this Forum.. Hello there, new subscriber to this forum.. I bought a 1985 Ford Bronco II and I have a hellacious starting issue... To me it sounds as if the starter isnt lining up with the flywheel... I ran my finger through the inspection cover and I found metal shavings that came from the flywheel.. But after turning the flywheel 360 degrees, the flywheel still looks servicable. I was told that Ford made different style Bronco II's. Am I wrong? So anyway, I bought a new starter and replaced it but it is still doing the same thing... Oh yeah I also bought a Shim thinking that would help with my issue... No dice. Any thoughts on what is the problem or what I am doing wrong?
Venia is offline   Reply With Quote
Old 04-04-2012, 11:16 AM   #2
janderson4010
third boxcar, midnight train
janderson4010's Avatar
86 BII
Vehicle Specs
here is some reading for you, seems this guy had the same prob and got it fixed,
http://www.pirate4x4.com/forum/showthread.php?t=701467
__________________
Prevent Wilderness!!!
warranties are invalid if you don't use the product for its intended purpose!!!!
build thread: http://www.explorerforum.com/forums/...d.php?t=315686
janderson4010 is offline   Reply With Quote
Old 04-12-2012, 06:41 AM   #3
Venia
1985 Ford Bronco II
Vehicle Specs
(Original Poster)
Thanks for the post. I see he got his fixed.. He had an automatic, I guess I failed to mention that I have a 2.9L V6 5 speed manual... Any thoughts on a manual?
Old 04-12-2012, 12:01 PM   #4
janderson4010
86 BII
Vehicle Specs
the fm146 he put in there is a 5spd manual, should be the same or very similar to what you have in your bII. he said the a4ld he had in there blew up so he replaced it with the fm146 which is a manual 5spd trans. no further ideas from me, good luck.
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Diagnosing A No Start/Slow Start - Starter Concerns ExplorerDMB Under the Hood 16 12-17-2012 03:16 AM
Starter issues. fastcharlie Stock 1991 - 1994 Explorers 4 05-28-2011 11:50 PM
Starter issues. Princessbeeca Stock 1995 - 2001 Explorers 4 10-31-2010 05:06 AM
Starting Issues 18theng Stock 1991 - 1994 Explorers 2 08-30-2009 12:34 AM
91X--Dead starter (95% sure). arebee123 Under the Hood 3 05-19-2006 12:04 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
