Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
4 hi, no 4 low, fuse resets 4hi (2001 sport trac)
Reply
Thread Tools
Old 04-04-2012, 09:37 AM   #1
swilks84
grand rapids, mi
2001 Sport Trac
Vehicle Specs
(Original Poster)
Hello, i am new to the site and am quite happy with the info and my soon to be ability to help when possible, but right now, i have an issue- my 4 hi works for a while, then when i need it, it wont work, until i pull the fuse for the 4x4 in the left side of console panel, and it resets it, then will go into 4 hi no problem a few times(cycle), but never will go into 4 lo. tried in neutral, tried backing up ( i know the old ones had to go in reverse to disengage something?), nothing works. i am hoping it is something simple, and if it is the motor in the transfer case, i am capable of replacing it, i just dont want to have to! any ideas are appreciated, thanks for looking.
swilks84 is offline   Reply With Quote
Old 04-04-2012, 09:54 AM   #2
MidnightRebel07
Pittsburgh, Pa.
MidnightRebel07's Avatar
2003 Explorer Sport Trac
Vehicle Specs
Could be as simple as the switch on the dash or the electric shift module on the side of the transfer case.
__________________
"If you're gonna be a bear, Be A Grizzly"
1.75" TT, WP shackles, 3" BL, 33x12.5x15 DuraTrac's, 15x8 Cragar's, RT Y-pipe, RT High Flow Cat, MagnaFlow 2.5" in/ dual 2.5" out, 2.5" dual pipes, LiveWires, K&N air filter, Uniden C.B., Pioneer H.U., MTX sub, Gen2 Ex dash bezel swap, Amber l.e.d. clearence lights, Custom Built Swing Out Tire Carrier and bumper (my build),custom Winch bumper w/ 12k lb. winch, A.R.E. Cap
MidnightRebel07 is offline   Reply With Quote
Old 04-04-2012, 11:57 PM   #3
swilks84
grand rapids, mi
2001 Sport Trac
Vehicle Specs
(Original Poster)
When it wont do anything at all, I figured out it is fuse number 35 (4x4 module) that I can pull, put back in (it doesnt blow) and then it will go into 4 hi again. But nothing happens when trying 4lo. And it only will go into 4hi for as long as it feels like it, then I have repeat pulling and putting back in.
Old 04-05-2012, 04:21 AM   #4
ncranchero
Sport Trac Moderator
Denver,NC
ncranchero's Avatar
Truckin' on Pat & Charlie
Vehicle Specs
The first( and easiest) thing to try is disconnecting and reconnecting (2 or 3 times) the shift module behind the right kick panel. The terminals sometimes oxidize and don't make good contact. if that doesn't help do the same thing to the connection at the shift motor. If you have to replace the shift motor it's mounted externally with 3 bolts so you should be able to do it with little/no problem.
__________________
Steve,
2010 Transit CONNECT 145K miles, 2002 Sport Trac 4x4 SOLD
2000 Taurus SES 3.0L 24 Valve DOHC Duratec 87K miles
1994 F150 4x4 4.9L/5-speed 160K miles,
1995 Ranger 2.3L/5-sp/3.73 75K miles "Plain Jane"
How to post photos
ncranchero is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
My 2001 Sport Trac 01Strac Explorer Registry 13 01-18-2013 06:27 AM
Rear brake conversion 2001 Sport Trac Hamptons1 2001-2005 Explorer Sport Trac 11 05-04-2012 06:20 PM
2001 sport trac 4x4 5.0l swap fastgoat04 2001-2005 Explorer Sport Trac 23 04-30-2012 11:36 PM
Explorer sport shifts to 4 low unexpectedly at freeway speeds JA1471 New Member Forum 0 03-28-2012 07:12 AM
2001 Explorer Sport (no trac) Body? Black Magic RC & Models Forum 1 04-09-2002 08:46 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
