EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer Audio & Navigation
Notices
Explorer Audio & Navigation Audio and navigation systems. CD, DVD, MP3, GPS, Video, Mobile Computer, Speakers, Amplifiers.
System pop
Reply
Thread Tools
Old 04-08-2012, 01:30 AM   #1
jimster502
socal
jimster502's Avatar
97' ex XLT
Vehicle Specs
(Original Poster)
Question System pop
I know this has probably been asked hundreds of times on here but I really don't know why my speakers pop. I've searched around the forum but I can't seem to find what I need when I need it. The first sound system I had( which only involved a monoblock & two 10's) never made a thump when I turned on/off the stereo. When I installed my current system (mono + two 12's) I noticed a thump everytime I turned off the stereo. At the moment I didn't mind but I recently installed another amp ( 4 channel) & it makes 2 speakers pop when the stereo is turned on. I really don't think it can be where I grounded them because I change the locations from where each were grounded to & still no luck.
Does anyone know why my door speakers pop when the stereo is turned on & why my subs pop everytime the stereo is turned off? Thanks.
jimster502 is offline   Reply With Quote
Old 04-08-2012, 01:50 AM   #2
toypaseo
Flunked daycare
outside shovelling snow
toypaseo's Avatar
................ 96 XLT ™
Vehicle Specs
This post might help...
http://www.explorerforum.com/forums/...ighlight=thump
I know you can buy some products that will delay turn-on also.
__________________
Kent - 1996 XLT - Hypertech Programmer, Gibson Catback, K&N FIPK, Alpine V12 MRV-100M, 8" round 2ohm Kicker Solobaric
1992 Toyota Paseo - Tein Super Street coilovers, Whiteline swaybars 22MM(F) 20MM(R), Prothane endlinks & mounts, VVR poly control arm bushings, K&N drop-in, Dynomax Ultraflo, Gibson stainless tip, Pirelli Winter Carving Edge(F) Kumho HP4 716(R) on steelies
toypaseo is offline   Reply With Quote
Old 04-08-2012, 11:41 AM   #3
jimster502
socal
jimster502's Avatar
97' ex XLT
Vehicle Specs
(Original Poster)
Thank you very much! I will get this as soon as I can! & oh how do I connect this? Is it the same as a toggle switch with neg, pos, & accessory input?
Old 04-08-2012, 12:31 PM   #4
Bruces expo
Middle GA
Bruces expo's Avatar
91 Mazda Navajo
Vehicle Specs
sounds like the pop your hearing is your Remote to your amps , normally its because its turning the amp on and off at the same time as radio and you get interference because the amp is turning on without any signal input , Sounds like what i have dealt with before on and install years ago ,
__________________
1999-Exdpedition Xlt 4.6 Silver-Grey- OIL LEAKING .haha
ZAPV#161, 91 Navajo, 3" Bodylift , 2.5"skyjacker coils,skyjacker shocks , 2" ext shackels, . home made CAI.no muffler's straight cat's ,warn locking hub's,throttle cable mod ,deleted rear swaybar , front sway bar disco's ,custom cut front bumper ,deleted front fender flare's ,clear turn's ,clear tail's,33" Pro Comp AT's
1953 Ford F-100 Restoration Project
Bruces expo is offline   Reply With Quote
Old 04-09-2012, 12:17 AM   #5
jimster502
socal
jimster502's Avatar
97' ex XLT
Vehicle Specs
(Original Poster)
Quote:
So what do you think I should do to avoid this "pop"? I remember reading somewhere that after having more that three accessories that are running with the same remote wire, a relay has to be installed..? & I think this goes for me b/c I'm running an eq, 2 amps, and a bass reconstructor with the same remote wire.
Old 04-09-2012, 12:36 AM   #6
Bruces expo
Middle GA
91 Mazda Navajo
Vehicle Specs
I Would use more than one remote wire , find another 12v source coming from your head unit
__________________
Old 04-09-2012, 12:49 AM   #7
jimster502
socal
jimster502's Avatar
97' ex XLT
Vehicle Specs
(Original Poster)
Is that the only solution? The fact that I would have to run more wires doesn't sound fun anymore haha.
Old 04-10-2012, 02:27 PM   #8
SirJeffro
Raleigh, NC USA!
2003 Sport Trac XLT 4X4
Vehicle Specs
I just did this in my Sport Trac last week! BIG POP when the HU turned on the amp. Put this baby and it worked like a charm!...... Use this voltage regulator....
http://www.radioshack.com/product/in...ductId=2062599
I think it was $1.99....felt silly carrying it in a bag!
Rock on!!
__________________
Jeff Parrish
Raleigh, NC USA!
2003 Ford
Explorer Sport Trac XLT 4X4
SirJeffro is offline   Reply With Quote
Old 04-10-2012, 04:17 PM   #9
jimster502
socal
jimster502's Avatar
97' ex XLT
Vehicle Specs
(Original Poster)
Quote:
http://www.radioshack.com/pr<br /> ...ductId=2062599
Rock on!!
How do you install one of these suckers?
Old 04-15-2012, 03:30 PM   #10
jimster502
socal
jimster502's Avatar
97' ex XLT
Vehicle Specs
(Original Poster)
So I installed one these voltage regulators and it just made the pop from the subwoofers quieter. I can still hear the pop a bit, but not to the point where it was annoying me.
So afterall, the regulator reduced the pop from the sub amp but not from the 4 channel amp. The pop from the 4 channel app is still loud. I even checked to see if the speakers were connected wrong, but they arent.
Does this mean I have to buy another regulator and install it before the 4 channel amp?
Btw, I am supposed to connect this on the remote turn on wire right? Or am I wrong?
Old 04-16-2012, 02:40 AM   #11
jimster502
socal
jimster502's Avatar
97' ex XLT
Vehicle Specs
(Original Poster)
Anyone?
Old 04-16-2012, 05:31 AM   #12
SirJeffro
Raleigh, NC USA!
Vehicle Specs
They way I understand is that the OEM system uses lower voltage (5V) to turn on the factory amp(s). My JVC HU sends 12 volts out on the remote turn-on wire, so you get the big pop. If you are using factory amps and wiring check to make sure you are only sending 5 volts to the amp turn-ons. My harness adapter had two separate sets of wires (+ & -) for remote switching. So, depending on your harness, you may need two of the little regulators.
Hope this helps.....
__________________
Jeff Parrish
Raleigh, NC USA!
2003 Ford
Old 04-16-2012, 01:05 PM   #13
jimster502
socal
jimster502's Avatar
97' ex XLT
Vehicle Specs
(Original Poster)
I'm not using factory amps
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
EEC-IV 2 and 3 digit trouble codes. BrooklynBay EEC IV 16 03-26-2012 09:46 PM
Nav system problems larrymcj 2011 - 2014 Ford Explorer In Vehicle Technology (IVT) Sync, MFT - MyFord Touch 6 03-02-2012 10:33 AM
Loud Pop From My Sound System swiftyman Explorer Audio & Navigation 2 02-26-2012 06:06 PM
1st Gen audiophile system: connector to by-pass main amp & keep sub-W amp? saxon Explorer Audio & Navigation 0 06-05-2006 01:22 PM
Win98 Install crashing...doing my head in!! MeatyCrab Exploring Computers!! 18 03-27-2003 10:12 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
