Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Questions about 95-01 axle interchangeability
Reply
Thread Tools
Old 04-08-2012, 02:09 AM   #1
Dawgpack
Bozeman, MT
Dawgpack's Avatar
1999 Explorer
Vehicle Specs
(Original Poster)
I searched but couldn't find quite what I was looking for. I know 95-01 axles should be similar, but I want to make sure before I drop money on an axle that won't work.
I have a 99 and I've been trying to find a 2nd gen with 4.10 gears for an axle swap. I found a 97 with both the rear axle and the front differential. Would I be able to swap those into my 1999? I'm worried about compatibility with the speedometer with the rear and I read they changed the IFS a bit in 98. So if someone could clear that up for me, that would be great!
__________________
1999 Explorer XLT | 4.0 SOHC | K&N filter | TT, AAL, Warrior Shackles | Running board delete | 31x10.5r15 duratrac's | Curt roof basket | Curt front hitch
Dawgpack is offline   Reply With Quote
Old 04-08-2012, 07:31 AM   #2
boominXplorer
Virginia Beach, Va
boominXplorer's Avatar
00 4x4 Mounty
Vehicle Specs
You need to look for a set from a 98-01. It seems most that 4x4 sports have 4.10s
__________________
1998 Mountaineer 5.0 2wd - Mac intake, Ported intake, FMS headers, 3" Exhaust, E-fan, SCT tuned, Baumenn Shift Kit, MSD, 4.10 l/s, Lowered 3/2 on 18x9 Cobra r's, HID's
2002 F250 Crew Cab SB 7.3 Diesel 4x4 - 4" MBRP exhaust, AIH delete, SCT Livewire
2001 Ranger ext cab 4x4 - 5.0/4r70/4406 swap in progress
(2) 97 Mountaineers for parts
98 Sport for Parts My eBay auctions
boominXplorer is online now   Reply With Quote
Old 04-08-2012, 09:08 AM   #3
vroomzoomboom
Elite Canuck STOCK SUCKS!
selkirk, manitoba
vroomzoomboom's Avatar
98 5L sport
Vehicle Specs
the rear axle on a 95-97 will not have the speed sensor in it. the speed sensor on those years it in the t case. also, on 95 for sure (96 i am not totally sure) the front diff was a vacuum disconnect. the way it worked if i am correct is that for it to go into 4x4 was the axle engaged using motor vacuum, vs electronically on the t case. otherwise, physically they are all the same, and will bolt in. just like boomin said, if you want 4.10's hunt a sport down. they came with them from factory.
__________________
NOS is nice, but i'd rather be BLOWN
evils elite registry
roll pan build for 1st and 2nd gen explorers
door switch LED convention
vroomzoomboom is online now   Reply With Quote
Old 04-08-2012, 11:21 AM   #4
Dawgpack
Bozeman, MT
Dawgpack's Avatar
1999 Explorer
Vehicle Specs
(Original Poster)
Dang, ok thanks guys!
EDIT: is the front diff the same in 97 then? If it doesnt have the vacuum disconnect and its swappable I might go snag that and keep looking for a rear axle.
__________________
Old 04-08-2012, 12:38 PM   #5
boominXplorer
Virginia Beach, Va
00 4x4 Mounty
Vehicle Specs
97's are 50/50 trucks. What I mean by that is half way through the year they started making changes. Only real way to tell is just go look if it has the disco on it
__________________
Old 04-08-2012, 01:05 PM   #6
vroomzoomboom
selkirk, manitoba
98 5L sport
Vehicle Specs
Quote:
......i didnt know that, and i want one of those diffs, and have had a 97 parts truck for over a year just sitting and never thought to look!
__________________
Old 04-08-2012, 01:18 PM   #7
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quote:
Yes it does. The 95-97 has the ABS sensor in the rear axle, thats the same sensor the 98+ uses for the speedo.
__________________
94 limited: 4.0l, 5spd swap, 6" skyjacker lift, 35x14.5 thornturds, 4.56s. 5.0 swap started (94 cobra 5.0, zf 5spd, np205)
95 xlt: stockish (SOHC swap, 30,000miles and I blew up the 3rd 4r55e...now collecting parts for a Cummins swap.)
Cummins 4BT swap thread
Ranger bed trailer build
snoranger is online now   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
8.8 Axle Facts and Swap info Tbars4 Explorer & Ranger Transmissions, Transfer Cases, & Differentials 33 02-13-2012 06:51 PM
HCU Swap From 01 to 95 ryancrf Under the Hood 0 04-06-2011 10:05 PM
Lug nut wheel torque specification chart. BrooklynBay Ford Explorer - Ranger Tires & Wheels 1 11-26-2008 09:12 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
