Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2011 - 2014 Ford Explorer 5th Generation Explorer > Stock 2011 - 2014 Ford Explorer Discussion
Notices
Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost.
Rain Noise TSB
Reply
Thread Tools
Old 05-12-2012, 08:52 AM   #41
peterk9
Toyota Highlander Convert
Ottawa, Ontario area
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
Quote:
Originally Posted by gpzrider View Post
Just got my EX back from several TSB fixes. As for the rain noise fix, to me, when I tap on the sloping part of the roof line, it sound exactly like it did before they "allegedly" put foam sealant in there. They did a great job of not getting it anywhere in my car. But it sounds just as loud as it did before the fix. Those of you that feel that it fixed it a little, when you tap on the roof line, does it sound less like a Jamacian Steel Drum?
The important thing is, what does it sound like from the inside?
__________________
Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).
Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds
peterk9 is online now   Reply With Quote
Old 05-12-2012, 11:38 AM   #42
gpzrider
Los Angeles, CA
2012 Limited 4x4
Vehicle Specs
Wife was sitting inside while I was doing it. Said sounds exactly the same.
gpzrider is online now   Reply With Quote
Old 05-12-2012, 04:10 PM   #43
blwnsmoke
Vehicle Specs
Just picked mine up.. perfectly done.. LOVE my service dept.
blwnsmoke is online now   Reply With Quote
Old 05-12-2012, 04:24 PM   #44
peterk9
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
Quote:
Does it make a difference? There are many posts that indicate there is no change.
__________________
Old 05-12-2012, 06:17 PM   #45
blwnsmoke
Vehicle Specs
Quote:
When i tap on it.. it sounds like a tin can still.. time will tell when we have the next rain storm. I didnt receive paperwork because the W/O wasnt closed out. The service manager is going to call me Monday. I mentioned the transmission clunk and it doesnt seem they did anything but cant tell till I see the paperwork.
Ill update then.
Old 05-12-2012, 07:10 PM   #46
Rodomontade
Vehicle Specs
(Original Poster)
Quote:
Originally Posted by cnsheets View Post
Rodomontade,
Did you get this resolved? I just got my EX back after 10 days. They replaced the headliner, passenger front seat leather cover, and center console because of the foam. They still need to replace the drivers sun visor and drivers interior A-Pillar moulding.......
What I found interesting.....I now have a brand new windshield also (nothing wrong with old one), apparently per the dealer, the only way to replace the headliner is to remove the windshield and put the headliner in through the windshield opening after laying all the seats flat. Which I guess this means they had to also remove the outside A-pillar appliques and stuff. They said the rear hatch it too narrow to get the headliner in. I just hope that I don't have problems now with the windshield leaking or anything........time will tell........
Also, the new center console is slightly different than the original, the media hub (SD Card Slot, USB's) area on the new one now has a raised area around the SD card slot, which I assume is to help prevent accidental bumping of the SD card for the NAV.....The old one did not have this.....
Still not resolved.
They did install a "new' headliner but the "new" one has a 1.5 inch cut in the passenger A-pillar area.
They did install the headliner without removing the windshield.
Cory escalated the call with Ford and I was contacted by a lady named Tara.
Tara was polite but explained the dealer denied there ever being a problem.
She said that it was a "he said - she said" situation and that I needed to take it up with the dealer.
I have my attorney involved as of yesterday and it is probably headed for litigation.
I seriously doubt I will ever buy another vehicle from Joel Confer.
Depending on how this turns out I may never buy another Ford vehicle!
Ill keep you posted.
Rodomontade is offline   Reply With Quote
Old 05-12-2012, 09:04 PM   #47
cnsheets
Anaheim, California
11' Explorer
Vehicle Specs
Sorry to hear that, so are they saying that you caused the 1.5 inch tear and now refusing to do anything about it? That sucks......When I went to pick mine up after having the headliner replaced, I thought of your ordeal, I took a flash light with me and looked over every inch for any tears.
cnsheets is offline   Reply With Quote
Old 05-13-2012, 01:08 PM   #48
Rodomontade
Vehicle Specs
(Original Poster)
Partly correct.
According to Tara at Ford, the dealer denied anything ever happening!
Including the original glue / foam smear.
It's costing me a considerable amount in attorneys fees.
I should hear something by the end of this week.
Old 05-14-2012, 08:18 AM   #49
FordCustSrvc
Official Ford Rep
Dearborn, MI
FordCustSrvc's Avatar
Vehicle Specs
Mine sounds much much better on the edges, but as you progress towards the center of the windshield/roof line, its more tingy, but not completely as bad as before the fix. I just suffered from the foam everywhere and having to have a ton of stuff replaced on the interior.....
Quote:
Originally Posted by dencan View Post
... Well it finally rained this weekend and probably not a big surprise that it didn't work...
Quote:
Originally Posted by jrmexplorer View Post
My dealer was explicit that it will help with the rain noise, but not eliminate it...
...As for the rain noise fix, to me, when I tap on the sloping part of the roof line, it sound exactly like it did before they "allegedly" put foam sealant in there...
When i tap on it.. it sounds like a tin can still.. time will tell when we have the next rain storm...I mentioned the transmission clunk and it doesnt seem they did anything but cant tell till I see the paperwork...
cnsheets, dencan, jrmexplorer, gpzrider, & blwnsmoke,
I have your contact information from previous messages, so drop me a line via PM if you’d like me to lend a hand.
Quote:
Originally Posted by HDJulie View Post
...I called around 3 this afternoon to see if the car was ready & they had run out of foam. They are supposed to get some tomorrow so I'm letting then keep the car...
Quote:
Originally Posted by jfbk View Post
...I haven't been able to drive the car during a rain to see if it did any good. I did go through a car wash that I had gone through many times before and it did seem to make a big difference. Gone, NO, but 90% better. True test will be doing a hard rain.
HDJulie & jfbk,
I wanted to check in with you; are you still having a concern?
I was going to get the same TSB done with my next visit. That will be next week when I go for an oil change, but I told them to hold off on the TSB for now...
Keep us in the loop on whether you decide to have the TSB performed, Peter.
Quote:
Originally Posted by Rodomontade View Post
Still not resolved...Cory escalated the call with Ford and I was contacted by a lady named Tara...I have my attorney involved as of yesterday and it is probably headed for litigation...
Rodomontade,
I want to see that this is resolved for you. However, because you're working with an attorney, I'm no longer able to help.
Cory
__________________
FORD SERVICE
p: 800.392.FORD
t: @FordService @Ford
f: facebook.com/FordExplorer facebook.com/Ford
FordCustSrvc is offline   Reply With Quote
Old 05-14-2012, 11:39 AM   #50
cnsheets
Anaheim, California
11' Explorer
Vehicle Specs
I was going to get the same TSB done with my next visit. That will be next week when I go for an oil change, but I told them to hold off on the TSB for now. I'm having second thoughts after reading some of the posts. No one at the dealership has done this one yet so I'm going to wait and re-evaluate if I really need to get it done.
If I could go back, I would never have had this TSB done. I would have dealt with the tin can sound. As a result of having this TSB done, I have been without the vehicle for a total of about 15 days (10 days straight plus a few here and there) and have had to have the following parts replaced as a result of carelessness regarding the foam:
1. Headliner
2. Windshield
3. Passenger seat cover (leather)
4. Drivers side visor
5. Drivers side A-pillar interior moulding
6. Center console (where cup holders, media ports, shifter are)
7. Center Dash cluster (center dash piece that houses the MFT screen, vents, audio/climate touch controls)
8. Shifter knob
Its simply not worth it.........
Old 05-24-2012, 03:08 PM   #51
davek4
Princeton, NJ
Vehicle Specs
Can the fix be done to moonroof cars?
davek4 is offline   Reply With Quote
Old 05-24-2012, 05:31 PM   #52
peterk9
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
CAN
Quote:
The TSB does not say that it is limited only to non moonroof vehicles, so yes, it applies to all.
I have a moonroof and had arranged to have the TSB done with my last oil change but asked them to hold off while I rethink this through some more.
Whether it is a 'fix' is another matter. A few who have had it done do not notice a difference.
__________________
Old 05-24-2012, 07:15 PM   #53
cnsheets
Anaheim, California
11' Explorer
Vehicle Specs
LEAVE IT BE, DON'T DO THIS TSB FIX!! You have been warned. Not worth it.
Old 05-25-2012, 08:22 AM   #54
blwnsmoke
Vehicle Specs
Not everyone has incompetent dealer like you do.. mine came out perfect. Now whether it made a difference is something to be determined.
Old 05-25-2012, 09:46 AM   #55
cnsheets
Anaheim, California
11' Explorer
Vehicle Specs
Completely agree. I'm only speaking of my personal experience. But still, I think the potential benefits of a "clean" execution of the TSB are not worth the risks of a botched execution. One little drop of the foam on something else and your screwed.....to each their own.
Old 05-25-2012, 01:51 PM   #56
gpzrider
Los Angeles, CA
2012 Limited 4x4
Vehicle Specs
I agree. Don't have it done. Mine came out perfectly clean the only thing wrong, it did nothing to dampen the noise. So, what's the point?
Old 05-27-2012, 12:04 AM   #57
jeff59rt1
2011 Explorer XLT
Vehicle Specs
Agree with ^ everything was perfectly done on my ex. Just it made no difference in the rain noise. Got my a pillars fixed and can really hear the rain now. Dont bother getting this done, or just expect no difference!
jeff59rt1 is offline   Reply With Quote
Old 06-30-2012, 08:06 AM   #58
HDJulie
Little Rock, AR
2012 Explorer Limited AWD
Vehicle Specs
Quote:
Originally Posted by FordCustSrvc View Post
HDJulie & jfbk,
Cory
I apologize for taking so long to get back to this thread. I had the Rain Noise TSB done (or I assume it was done - they kept my car for 3 days & when I got it back I had no smell or any other indicator it was done :-) ). I asked for it because I hoped it would help with the bluetooth noise. It did not make any difference for me -- the bluetooth still sucks.
HDJulie is offline   Reply With Quote
Old 06-30-2012, 08:30 AM   #59
RonJrSVCMGR
11-13 Explorer Moderator
Gilford, NH
RonJrSVCMGR's Avatar
'13 Ford Explorer Limited
Vehicle Specs
I find the Bluetooth to work 20 times better than our 2007 Camry Hybrid. People hear me clear as a bell. The first time I used it I forgot to turn off the climate fan and my wife said it sounded like I was n. a wind tunnel. Shut the fan off and she could not believe how clear it was. Using an iPhone 4 with the volume all the way up on the phone.
__________________
2013 Ford Explorer Limited AWD in White Platinum Tri-coat & Medium Light Stone interior. 302a package with power fold 2nd row bucket seats, 2nd row center console, power fold 3rd row seats, trailer tow package, heated/cooled front seats, Ford all-weather floor mats (summer), WeatherTech Floor liners for all three rows (winter) & Cargo Well + Cargo Liner, additional Trailer Hitch Cap modified to accommodate a Bike Carrier, dual moonroof and Visual Garage Shark Fin Antenna. Goes by the name "Storm Trooper".
RonJrSVCMGR is offline   Reply With Quote
Old 06-30-2012, 08:35 AM   #60
VinceL
Spring, TX
2013 Explorer Limited
Vehicle Specs
Well, turning off the climate control in Houston summer heat really isn't an option, and shouldn't be necessary, lol! But you said the 3rd quarter update tries to address this issue?
Thanks
__________________
We just bought American!
She got the 2013 Ex
Meet the Gray Ghost HERE
Check out the Gray Ghost on Fuelly.com
Average Mileage: 21.3
Best Tank: 26.5
VinceL is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
What makes a grinding noise like a bad wheel bearing other than a wheel bearing? jayton Stock 2002 - 2005 Explorers 23 09-23-2012 10:18 AM
Rain noise. Terry H Stock 2011 - 2014 Ford Explorer Discussion 384 08-14-2012 07:58 AM
'98 XLT Strange noise decelerating jawns Stock 1995 - 2001 Explorers 6 02-20-2012 08:58 AM
Noise Coming From Passenger Side Rear 07 Mountaineer AWD SirManny Stock 2006 -2010 Explorers 2 02-03-2012 01:22 PM
calling all noise detectives IkeH Stock 2002 - 2005 Explorers 1 07-14-2010 12:30 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
