#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Why would "THEFT" light stay on?
Reply
Thread Tools
Old 04-10-2012, 06:10 PM   #1
Phili602
Phoenix
96 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 1998 XLT Explorer and whenever I press the lock button on either the remote or the door to lock the doors, the THEFT light stays on and flashes brighter and its causing my battery to drain. Any suggestions are greatly appreciated!
Thanks
Phili602 is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-10-2012, 06:17 PM   #2
NHarris
Gillette, Wyoming
04 Wrangler, 08 Ranger
Vehicle Specs
Quoted: 3 Post(s)
Quote:
Thanks
Based off of my assumption (on my 98), all second gens have the theft light that flashes.
Let's specify here...
Is it causing your battery to completely lose charge, or just drain it slightly?
__________________
Nate H
2008 Ford Ranger FX4
2008 Ford Taurus Sport
NHarris is offline   Reply With Quote
Old 04-10-2012, 06:57 PM   #3
Phili602
Phoenix
96 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Well my battery was fine until i came out after leaving it sitting for a few days and it didnt want to start.... The theft light flashes on and off even when the doors are unlocked, but when i press the door lock button on either the door or remote, the theft light stays illuminated and just flashes brighter even though its already lit
Old 04-10-2012, 07:13 PM   #4
NHarris
Gillette, Wyoming
Vehicle Specs
Quoted: 3 Post(s)
Did you get your battery tested?
The ECU, radio, and whatever other electronics also are using power to stay on. I'll have to take a look at my X and see what its theft light is doin.
__________________
Nate H
Old 04-10-2012, 10:14 PM   #5
Phili602
Phoenix
96 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Yes i got my battery tested. 1st time was at a oreilly and they said it was no good. But I think the oreilly i went to is shady because I took the same battery to autozone and they said its good and fully charged it for me. 1 of the cells on the battery were low so I just added some distilled water and it seems to be keeping its charge but havent put it back in the x because I dont want it to drain it again. My previous x had the theft light and it would flash all the time weather the doors were locked or not. and it wouldnt stay lit and flash like this 1 is doing.
Old 04-13-2012, 04:41 PM   #6
Phili602
Phoenix
96 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Any suggestions on what could be causing the theft light to stay on at all times? How could i disconnect that light so it doesnt drain my battery?
Old 04-13-2012, 05:10 PM   #7
Trolling
kah-lee-fur-nyah
1997
Vehicle Specs
Quoted: 0 Post(s)
for the past few occasions that [I] had my instrument cluster all apart, my theft light bulb has been a tiny red LED. Even with that left on for a week, it can't drain a car battery dry.
Maybe there is something else draining your battery?
__________________
302 V8, BW4406, K&N CAI, 1" Phenolic spacer, TMH, Henson Custom Tune and a ticking noise problem.
Trolling is offline   Reply With Quote
Old 04-13-2012, 06:26 PM   #8
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
If it's blinking super fast and you hear a relay clicking at the same rate, then this usually means that the battery voltage is too low. If the battery is ~3-ish years old, then it's probably time to replace it. Another culprit could be of course the alternator not charging the batt.
__________________
...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 04-13-2012, 08:44 PM   #9
Phili602
Phoenix
96 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
It may be another issue then besides the light
Old 07-06-2013, 08:57 AM   #10
jturkey69
Sheboygan,WI
98 Explorer 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
Did you ever figure this out? I replaced my starter yesterday, and after reconnecting battery, I started the truck to verify it was fixed, and immediately shut it off...three seconds later I tried again, and lo and behold the theft light and dash lights went dim, and clicking under dash (pats). I got on Ed here and found I had to insert keys in one by one to reprogram so to speak. All works fine now except theft light stays on when locked, and flashes a little brighter while its already on. What could this be? Did I miss a step?
__________________
1998 Explorer XLT V8..65,000 miles as of 8/20/11 airbox mods, and true duals with glasspacks, 3RD SEAT!
2005 Nissan Altima SE-R 6spd,wifes pocket rocket.. built and fast!
71 Cutlass budget pro-touring build.
jturkey69 is offline   Reply With Quote
Old 07-20-2013, 11:26 AM   #11
jturkey69
Sheboygan,WI
98 Explorer 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
Anyone? I have to disconnect and reconnect my battery, and cycle my keys to get it to start every time.! Dealer says that has never happened before...go figure..and wants 100$ plus to look at it. After a day the theft light flashes normally. Is there a sequence of things I need to do?
Any help is appreciated.
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
LED conversion: High Mount Brake light trucku Performance Lighting 18 06-16-2012 12:11 AM
My under the hood light install with pictures! XLT Modified 1995-2001 Explorers 15 04-18-2010 09:23 AM
Ranger dome light and cargo light stay on? nfazer Ford Ranger - Mazda B-Series Forum 2 04-12-2010 02:03 PM
How-To: Repair Broken 3rd Brake Light Socket (1st Gen) TedJ Stock 1991 - 1994 Explorers 0 08-31-2009 10:49 PM
Neon Light Write-up Glowin97x Performance Lighting 26 03-04-2009 08:15 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
