Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Body mount help
Reply
Thread Tools
Old 04-10-2012, 09:10 PM   #1
balnisj
2001 Ford Ex. Sport
Vehicle Specs
(Original Poster)
Unhappy Body mount help
I have a 2001 explorer sport SOHC and i took it to the stealers the other day and they said that I needed to replace all of my body mounts. They gave me a quote for $1400.00 for the parts which is obviously not do-able.
I wanted to know:
a) If anyone knows of any body mount replacement kits?
b) If universal energy suspension body mounts (all identical) are able to replace all 5 sets of body mounts on the car?
Thanks for any help,
joe
balnisj is offline   Reply With Quote
Old 04-10-2012, 10:03 PM   #2
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Vehicle Specs
One of many threads.
http://www.explorerforum.com/forums/...d.php?t=292471
swshawaii is offline   Reply With Quote
Old 04-10-2012, 10:44 PM   #3
balnisj
2001 Ford Ex. Sport
Vehicle Specs
(Original Poster)
Thanks for the quick reply... I read over that thread before and no one mentioned the comparability of universal mounts? Are all the mounts on the vehicle the same size? If so then the universals should work right?
Old 06-26-2012, 06:05 PM   #4
ajc0401
South Carolina
2002 Ford Explorer Sport
Vehicle Specs
Quote:
I wanted to know:
joe
Balnisj, unfortunately this is a common problem seen in 3rd generation sports and S/T ('01-'02) that is an obvious manufacturing defect. I just got done working on mine and although i wouldn't recommend doing the job yourself, it is possible but a lot of work. I used the Daystar polyurathene body mount bushing kit part #KF04009BK. Although this kit is made for 2nd generation explorers ('91-'98), with a few modifications they will work just fine; and they only cost $250.
http://www.streetsideauto.com/search...ords=KF04009BK
In a few days I will post a step by step instructions on how I went about changing them and the modifications I had to make. Like I said its a lot of work, but saving more than $1500 on parts and labor makes it worth it.
Stay tuned...
ajc0401 is offline   Reply With Quote
Old 06-26-2012, 06:09 PM   #5
01STrunner
Reva, Virginia
01STrunner's Avatar
2001 Sport Trac
Vehicle Specs
ajc - a pipe wrench with a breaker bar slipped over the end of it will actually hold the bottom plates of the mounts from spinning so you don't have to kill yourself trying to pry vise grips in there to hold it from spinning. Only downside is you need an extra set of hands.
__________________
Here's a link to my Registry
"This hobby begins as a search for the perfect setup, then gradually becomes the never ending discovery of the weakest link."
01STrunner is offline   Reply With Quote
Reply
Tags
body, bushing, mount, mounts, sport
Similar Threads
Thread Thread Starter Forum Replies Last Post
body mount location CRUISERMEDIC Modified 1995-2001 Explorers 1 09-27-2007 06:13 PM
Broken body mount bolts while doing body lift. need help!!! 184baller Modified 1995-2001 Explorers 10 07-31-2007 05:48 PM
Replacement Body Mount Bushings? gavin Stock 1995 - 2001 Explorers 4 08-25-2005 05:27 AM
Body mount point above gas tank ManixT Explorer - Ranger Shocks, Suspensions, Lift Kits 4 01-09-2004 09:51 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
