| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Modified 1991-1994 Explorers Questions concerning modifications to the 1991-1994 Explorer, Mountaineer, Ranger and Navajo. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap. |
Thread Tools |
#1 |
Wannabe Elite Explorer
bunkerhill, wv
91 explorer 4x4 sport
91 explorer hub conversion
i am just running things threw my head and had a ? when you do the convertion to manual hubs do you really need the converstion kit to hold the wheelbearing or can you just keep the set up for the auto hubs to hold the wheelbearing? i know the cam assembly from the auto hubs is a little bigger then the convertion kit. i was just woundering if i can leave the cam assembly on to hold the bearing and use the manual hubs but i aint sure if the manual hubs will fit over the cam assembly from the auto hubs.
#2 |
EF Vendor
mass
Welcome to the site.
#3 |
Moderator-Stock 91-94
Vail, Arizona
1992 XLT 4x4
I've heard reports of people using and not being able to use the auto hubs hex nuts (2 3/8" nut) with manual hubs.
Some have said it won't fit, other say it will.. Here is a post of someone who said it fits/works.. http://www.explorerforum.com/forums/...83&postcount=9 As for the Cam/assembly.. That has to go.. I'm also going to move this thread to the modified 91-94 forum.. ~Mark Edit: Here is a post with info about NOT being able to fit the automatic hub "nut" inside the manual hub.. http://www.explorerforum.com/forums/...hub+nut+manual |
#4 |
Denver Colorado
'93 Explorer XLT
Been there, done it; you won't regret going with the manual lock-nuts! Getting rid of that damned locking 'T' thing is worth the conversion in and of itself.
As a side note, I don't know about the stock manual hubs, but the auto lock nuts will NOT fit with the upgraded Warn 37780 hubs, cam or no cam. |
#5 |
Omaha Nebraska
1994 ford explorer
Ive blew a hub before because i didnt have the hub lock kit installed. I literally put the hub on locked it drove about 4 feet and blew the driver side apart and cracked the hell out of the casing on the passenger side.
#6 |
bunkerhill, wv
well i found put that i can not use the stock manual locking hubs from the rangers or broncos cuz the axles are smaller. so does anyone know where i can get a set of manual locking hubs under 100 bucks?
#7 | |
Vail, Arizona
1992 XLT 4x4
Quote:
Your only way to get warn hubs for < $100 is to find them used. ~Mark |
#8 |
bunkerhill, wv
yea i figured i would have to get them used to do that. its just finding them is a bigger problem then i thought.
#9 |
Massachusetts Merrimack Valley
1994 ext
Ive never had any issues with the manual hubs. I've blow a few but I work at a junk yard so I converted from autos for free and replace the hubs for free. I used all hte hardware from a 93 ranger on my 94 explorer and have been wheeling for years with no regrets
#10 |
bunkerhill, wv
yea i thought about that the only thing different on them is thefront axle size
#11 |
Beaverton/Portland, OR
EXPLORER YEAH!!!
I found some stock manual hubs off an explorer at pick and pull what/where can I find the conversion kit for changing my stock auto hubs to manual hubs?
__________________ 1993 Limited Edition:Sold http://www.explorerforum.com/forums/...79#post2723079 1993 XLT: http://www.explorerforum.com/forums/...05#post3037805 |
#12 |
1994 ext
The "Conversion Kit" just consists of the hardware that holds the wheel bearing on from the same truck that hubs came off from. As mentioned above, be sure it has the Dana 35 axle that your ex should have. I've never had any trouble but have known others who have not been able to install the neccesary hub hardware on their rig
#13 |
EXPLORER YEAH!!!
Ah so i didn't take anything from that truck but the hubs.. I guess I could go back and find it again. Is there no way to buy the parts off rock auto or something? I just don't know what ones I would need.
#14 |
Vail, Arizona
1992 XLT 4x4
IIRC it was Tbars4 that made a thread about the conversion nuts and he posted the part numbers for the cheaper parts.
~Mark Edit: post 1 of this thread : http://www.explorerforum.com/forums/...d.php?t=232754 |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Top search phrases for this site | Rick | Suggestion Box - Forum Feedback | 11 | 09-12-2011 09:22 AM |
| Auto Hub Washer Fix With Pictures | BobK | Under the Hood | 33 | 04-24-2011 10:37 AM |
| Manual Hub Conversion Kits - Warn & Mile Marker, interchangeable?? | manousos | Modified 1991-1994 Explorers | 11 | 04-29-2008 09:59 PM |
| Nato's - 91 Explorer - TO - 94 B3000 - Front End Conversion!!!!! | natopotato | Modified 1991-1994 Explorers | 7 | 04-18-2007 11:59 AM |
| More 2002 Explorer info | Rick | Ford Industry News | 12 | 10-08-2000 11:09 PM |
| Thread Tools | |
