#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2011 - 2017 Ford Explorer 5th Generation Explorer > 2011 - 2017 Ford Explorer In Vehicle Technology (IVT) Sync, MFT - MyFord Touch
Notices
2011 - 2017 Ford Explorer In Vehicle Technology (IVT) Sync, MFT - MyFord Touch 2011 - 2017 Ford Explorer In Vehicle Technology (IVT). Sync, MFT - MyFord Touch issues, and problems, navigation, back up camera, bluetooth, DVD, cell phone, Sony, Sirius, key fob, keyless entry, BLISS, voice commands, etc.
Bottom USB port only charges
Reply
Thread Tools
Old 04-16-2012, 01:47 PM   #1
Asystole
2013 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
2013 Ex Limited has two USB ports arranged vertically. The top one charges connected devices and reads whatever phones or storage devices I connect to it.
The bottom USB port, however, will only charge devices. It does not read any device I connect to it. I scoured the manual and there is no mention of differing functionality between the two ports.
Anybody have same issue or can verify this as well before I call the dealer? Thank you.
Asystole is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-16-2012, 05:17 PM   #2
w1kedz
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
I use both ports for charging and connectivity with no issue, sounds like you there is a problem with the pins or wiring on the bottom port for you
Old 04-17-2012, 11:13 AM   #3
jwkessel
Monroe, WA
Vehicle Specs
Quoted: 0 Post(s)
I use the bottom port on my 2013 Ex Limited for my iphone and it both charges and connects just like the top port.
jwkessel is offline   Reply With Quote
Old 04-17-2012, 01:40 PM   #4
Asystole
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thank you
Old 04-19-2012, 07:41 AM   #5
bamacommander
FLORIDA
2013 XLT FORD EXPLORER
Vehicle Specs
Quoted: 0 Post(s)
When I try to charge my phone using the USB port I get a pop up that will not go away saying the phone is consuming too much power and the Sync could fail. This pop up comes up by just plugging in the cord with no phone attached. I have had my 2013 for 2 weeks and the MFT has been an absolute nightmare. It is always rebooting, the nav only works when it wants to. I have had all sorts of problems and the car doesn't even have 1000 miles. PIECE OF JUNK.
bamacommander is offline   Reply With Quote
Old 04-19-2012, 08:17 AM   #6
VinceL
Frisco, TX
Vehicle Specs
Quoted: 37 Post(s)
^ Have you tried a different charging cable?
__________________
We bought a Ford
She got a 2013 Ex
Meet the Gray Ghost HERE
Check out the Gray Ghost on Fuelly.com
Average Mileage: 21.3
Best Tank: 26.5
VinceL is offline   Reply With Quote
Old 04-19-2012, 04:47 PM   #7
w1kedz
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
Quote:
Sounds like a bad cable, and/or bad entertainment hub in the Explorer. This is not one of the common issues people are having, and till you posted it (in numerous threads) I've never seen it before. If this is your only problem, then it's an easy fix. Try a different cable, if you still have the symptom then the dealer should be able to replace the entertainment hub and/or the apim.
Old 04-24-2012, 12:04 PM   #8
FordIVTteam
Official Ford Rep
Dearborn, MI
FordIVTteam's Avatar
Ford Explorer
Vehicle Specs
Quoted: 175 Post(s)
Asystole,
Have you by chance tried connecting a USB flash drive with music on it to the bottom port? I'm curious if it will read that. Besides trying a different device and cable, I suggest contacting your dealer to get the bottom port looked at. You should be able to use both ports for for charging and media.
Bamacomander,
Which phone do you have and has it been jail broken in any way? I've come across this message before (it's rare). The person I was talking with had an iPhone 4s and their battery life was very short. He would get this message on the MFT and sometimes a similar message on his phone. He took it to his phone provider, swapped out his phone, and he hasn't received the message since. BTW, his phone wasn't jail broken.
As far as your NAV concerns, when it's not working, what is/isn't it doing?
Rebecca
__________________
FORD IN-VEHICLE TECHNOLOGY TEAM
p: 800.392.FORD (Prompts 1 then 3)
t: @FordService @Ford
f: facebook.com/FordExplorer facebook.com/Ford
FordIVTteam is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to: Add a USB charger. Kazer Modified 2002 - 2005 Explorers 32 03-25-2015 07:18 AM
No Audio from USB Devices Suddenly pwscott 2011 - 2017 Ford Explorer In Vehicle Technology (IVT) Sync, MFT - MyFord Touch 5 11-14-2011 04:31 PM
2010 Sport Trac Second Sync USB Port Brad B 2007 - 2010 Explorer Sport Trac 0 12-22-2010 01:03 PM
Powered USB Port steventadams Explorer Audio & Navigation 21 01-09-2010 05:33 PM
PCV bottom hose ?? SOHC mfinger1 Stock 1995 - 2001 Explorers 0 01-01-2009 06:18 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
