Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
alternator not charging battery
Reply
Thread Tools
Old 04-18-2012, 11:26 PM   #1
cerberusaardvark
San Diego
1994 Explorer xlt
Vehicle Specs
Quoted: 21 Post(s)
(Original Poster)
scratching my head here, my battery has died multiple times and my alternator doesnt charge it while the engine is running. i got a new stock alernator(95 amps) and i slow charged my battery overnight but in the morning i still had a low battery gauge while the engine was running. now i charge the battery every night but the the needle on the battery gauge never gets above the "n" in normal. i took out the battery and cleaned the terminals with sandpaper. when i drive longish distances i can actually watch the battery needle go down, especially at night.
the first time i was driving at night and my lights got dim, i lost power to my interior electronics and tachometer, and my engine sound like it was about to blow up and or meltdown. that spoke to me of alternator problems but the new one doesnt help at all.
I took it to ford but they tested the battery and said it didnt have a full charge and everything looked good.
why is my engine turning into an electricity zombie?
cerberusaardvark is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-19-2012, 10:27 AM   #2
Jason94sport
South FL
93 Sport 2WD 5 speed
Vehicle Specs
Quoted: 49 Post(s)
Replace your cables. They tend to rot out. They may look ok, & not be.
Jason94sport is offline   Reply With Quote
Old 04-21-2012, 01:13 AM   #3
Dano!
Lemoore CA
Dano!'s Avatar
91 Navajo X 2
Vehicle Specs
Quoted: 0 Post(s)
I agree i had the same issue. I had to jump everytime i started the truck. Didn't matter how long i drove if i killed the engine, it would be dead. I pulled the old battery cables out and i had 4 separate breaks through the wire shielding from just rubbing on different parts.
After i replaced the wires i turned the key and it fired tight up. Its not that hard to do either.
Dano! is offline   Reply With Quote
Old 04-21-2012, 01:04 PM   #4
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 213 Post(s)
You need to find out if the issue is not charging or if the issue is the battery is being drained overnight..
Charge the battery up and let it sit overnight.. if it dead in the morning (or much lower) then the battery is bad OR you have a drain when the vehicle is off.
If the above test pass then skip down to the Battery not charging section..
Next, charge up the battery and disconnect the negative cable and check it in the morning.. If its low/dead its the battery.. If not, you know its a drain.
Next is to charge the battery and put a DC Amp meter between the battery and the negative cable. You want to see a very very very minute drain or no drain. If you see 1 Amp or more something is pulling power that shouldn't. Start pulling fuses to find it..
I'd start with Fuel pump Fuse, then any lighting fuses (including the one for the glove box light)..
Once you find the fuse that makes the drain go away you know "around" where the issue is..
If the battery isn't charging take your DVM (digital volt meter) and put it on DC volts (20v scale). Now measure from the negative battery post to the positive when the truck off and running. The voltage will probably be the same or lower when the truck is running which indicates a problem.
Now measure between the negative battery post and the big lug on the back of the alternator. If you see the voltage is higher then the alternator is trying to charge but the wire is broken between the alternator and the battery (possibly a blown fusable link).
If the alternator isn't "trying" to charge then look for the alternator fuse (I think its under the hood) AND make sure the bulb in the dash for the charge light is good. If either is bad the alternator won't get excited and won't charge..
Ok, enough rambling.. Good luck..
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 05-01-2012, 09:48 PM   #5
cerberusaardvark
San Diego
1994 Explorer xlt
Vehicle Specs
Quoted: 21 Post(s)
(Original Poster)
updates...just got done with some cable replacement. i replaced the positive cable because i could see some sections where the sheathing had come loose and exposed the red insulation... but that didnt solve my problem. didnt think it would but you never know about the corrosion concealed beneath the rubber. tomorrow im going to pull the alternator cable, the one that runs from the starter to the plugs on the back and start looking for breaks.
Old 05-02-2012, 12:52 AM   #6
buckwill
trona calif
1998 sport
Vehicle Specs
Quoted: 0 Post(s)
HI BUCK HERE,, ONE THING ID ADD,, with a known fully charged abttery,, turn ign switch off,, remove either cable removed,, test for voltage between batt post and cable with that dvm, that is with every thing off, doors closed, any voltage shows voltage being drawn off,,no voltage=no drain, buck,,,,,,
~Mark
__________________
if my memory was getting shorter would i know???,, disabled viet vet, retired navy,, 98 exploder sport sohc 4.0,, retired macinist,gas and steam turbine millwright,, ive arrested, stroked twice and i mispell lots,
buckwill is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Battery Not Charging did readings and altenator is seems OK lindykid Stock 1995 - 2001 Explorers 3 03-04-2010 01:30 PM
Battery Light On - New Alternator, New Battery grn03exp Stock 2002 - 2005 Explorers 10 12-04-2009 02:55 PM
Battery / charging light still on.... JusWannaMudd Stock 2002 - 2005 Explorers 2 06-05-2008 05:34 PM
Battery Hold-Down 02 Explorer - None there! - Powervolt Battery? wdhendrick Stock 2002 - 2005 Explorers 3 03-22-2008 04:30 PM
Battery problem at Ford asterus Elite Explorer 911! 3 10-28-2005 10:01 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
