Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
How to: Front Upper and Lower Control Arm Replacement
Reply
Thread Tools
Old 04-20-2012, 03:40 AM   #1
zerodevil
Anchorage, AK
2003 XLT V8.
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
How to: Upper and Lower Control Arm replacement.
Let me start by saying this a time consuming, mildly complex, frustrating, and potentially dangerous task. It is my advice that if you are lacking in mechanical expertise, or do not have access to air tools that you let a professional do this one. I managed to do both sides of my truck in about 12 hours, including the installation of a new sway bar.
What you will need.
-Jack, two jack stands.
-Basic tools (wrenches, sockets, extensions, regular car tools..)
-Strut spring compressor (don’t skimp, your safety depends on this tool working well, and being strong)
-Air tools (DO NOT ATTEMPT TO REMOVE LOWER CONTROL ARM WITH OUT AIR TOOLS)
- 30mm deep socket, impact gun rated.
-off set box wrenches, metric.
-1/2 in breaker bar
-Pitman arm puller
-Pickle fork and hammer
- a LOT of penetrating grease, for many of you this will be the first time your suspension parts have been worked on since your rig left Kentucky..expect them to put up a fight.
- a good buddy to hand you tools, engage in witty banter, and to operate a jack for you.
Now lets get started!!
I recommend you start this process by having the underside of your vehicle cleaned, a lot of automatic car washes have this feature, if not a do it yourself spray should allow you to do it yourself.. I went to a DIY wash and was able to spray my entire work area by simply turning the wheels to allow access. A lot of road grime builds up on the underside of your rig over the years, and a cleaner work area will not only make this process easier, but also more enjoyable.. nothing like having dirt fall onto your head while your wrenching away, you know? I also recommend you apply a very, very, very heavy coat of penetrating oil to every bolt you intend to remove, pay extra attention to the lower control arms, as they will have the most corrosion, and grime on them.
Now then go ahead and get your work area prepped, and get the truck jacked up and on jack stands. Remove the negative lead to the battery as a good knock in the right place where your going to be working could very well cause airbag deployment if your unlucky enough. Remove the wheels on both sides of the vehicle.
Your next step is going to be loosening and removing the front sway bar, go ahead and start by loosening and removing the end links on both sides of the vehicle (even if your only replacing one side of the suspension), and don’t worry with the vehicle in the air the sway bar is not under any degree of tension worth noting. After you have removed the end links, go ahead and remove the brackets holding the sway bar to the frame, remove the sway bar if possible (I was unable to manipulate it out of the vehicle, my front differential made it impossible, I was able to work around it with it moved towards the rear of the vehicle and hanging on the LCA’s. Now is a great time to inspect your end links, end link bushings, and your sway bar bushings for wear and tear.
With the sway bar out of the way it is time to remove the strut assembly. Go ahead and get your strut compressor mounted onto your springs, the more “links” you are able to compress, the easier it will be to remove and install the assembly, I was able to make it work with 4 links, but would have had a much easier time reinstalling the spring if I had been able to get more links. Do not begin tightening your strut compressor jest yet. From the engine bay, loosen the three outer bolts on top of the strut tower brace, on the driver side they are clearly visible, but on the passenger side they are hidden under some pipes, I was able to get the socket (13mm deep) on from the wheel well, and then manipulate an extension through the pipes (safely) to the socket, I used an air wrench to effortlessly turn the bolts off. DO NOT LOOSEN OR REMOVE THE LARGE CENTER BOLT.
Use a floor jack to articulate the suspension upwards, the further the better, but be mindful not to lift the vehicle off of your jack stands, as this creates an unsafe work condition. After you have lifted the suspension, start tightening your strut compressor down, ideally when your done there will be no space left between the links of your spring. I was able to turn mine with hand tools, but if I had been able to manipulate an air wrench in there, it would have been far less time consuming and more enjoyable. After you have compressed the spring, lower the jack, you should be able to see somewhere in the strut assembly that tension has been removed from the device, I was able to see where the bottom of the spring left the strut assembly, if you do not see this, or are unsure you have compressed the spring enough to safely remove it from the vehicle, do not proceed, go back and try again. However, if you are satisfied with your handy work (as we all should be ) go ahead and remove the lower mounting bolt.
lower mounting bolt, and bad tie rod end
Now then go ahead and manipulate the strut assembly out of the vehicle, I had the best luck rotating the strut 90 degrees to the right, and pulling the strut towards myself, and towards the front of the vehicle. I found it helpful to articulate the suspension upwards again to provide more clearance from the UCA. Once the strut is removed, you may wish to have your struts/springs replaced, I will cover this procedure next week when I install my new KYB struts and Ground Force lowering springs, otherwise set the compressed strut assembly in a safe place, where it will be undisturbed. It wouldn’t hurt to “point” the spring in a safe direction either.
With the strut and sway bar removed you are now clear to work on either the upper, or lower control arm. I was replacing both, as well as the tie rod ends. I started from the top and worked down, doing the tie rod ends last. To remove the upper control arm lets start by first separating the ball joint from the steering knuckle, loosen the retaining bolt, but leave it on the bolt with a full “nut” worth of threads, this will prevent the knuckle from falling when you separate it from the ball joint. I recommend you support the knuckle with a length of rope. I went around the strut tower, and wrapped the line around the wheel studs with great effect. Use a pitman arm puller to break loose the ball joint from the knuckle. Once it has broken free, remove the retaining nut and separate the two components. The upper control arm is held onto the frame of the vehicle by two nuts located on opposite sides of the strut tower, I recommend you use a breaker bar to get them loosened up, I used an air wrench to turn them off the bolts. On my truck the ABS sensor wire was routed through the UCA, if yours isn’t, go ahead and remove the arm by rotating it downwards and towards yourself, if it is it can be unplugged in the engine bay, follow the wire up to locate the plug.
Installation of the new arm is the reverse of this procedure, be mindful of any camber plates that were under the old UCA nuts, reinstall them if they were present. For legal purposes I will not post torque specs, but you can find them for your year explorer in a Chilton’s Manual. Be sure to torque all bolts to specification. And I recommend you install the new UCA before attempting to work on the lower.
With the upper control arm in place we are ready to remove the Lower control arm. Start by removing the break caliper and the break rotor, this will allow access to the lower ball joint, as well as the tie rod end if you wish to replace it at this time..same goes for your break rotors and pads. Hang the caliper by a length of rope. Honestly, its not worth potentially replacing break lines/caliper and bleeding the lines because you were to lazy to tie a knot in some rope or an old wire clothes hanger folks.
Now lets go ahead and separate the lower ball joint from the steering knuckle, Remove the cotter pin, and loosen the crown nut. Now its worth noting that my Chilton’s manual said I could use a “c clam style puller” to separate the two components, but I was unable to locate such a puller in town. I was able to successfully separate the two with a pickle fork and a large hammer, do not use a pickle fork if you are not going to replace the ball joint, as it will completely destroy the ball joint’s boot. After you have separated the ball joint and the LCA, remove the crown nut.
There are three bolts that hold the LCA to the frame of your truck, a very large one located towards the front that travels through a bushing, we want to turn the nut on this bolt(30mm), located towards the rear of the vehicle. This bolt was factory torqued to 295 ft/lbs.. and as such I feel it is my responsibility to express the futility of trying to do this by hand. This particular bolt despite the extremely heavy coats of penetrating oil, gave my $150 impact gun a run for its money. Loosen this bolt first. I recommend you support the LCA with your floor jack before attempting to loosen the two remaining bolts, and before pushing/pulling the front bolt through the frame and out of the LCA. With these three bolts and the ball joint separated, the LCA can now be safely removed by rotating towards the centerline of the vehicle, installation is the reverse of this procedure. Be sure to torque all bolts to specifications. I was unable to procure a wrench to torque my front bolt back into the high spec, so I torqued it to the 200 ft/lbs my wrench would go to, and I had a mechanic torque it the rest of the way when I had my alignment done. Also be sure to align the “flag” on this bolt with the hold in the frame, or you will be correcting it later on.
If you have a 4wd explorer, now is the most opportune time to replace/upgrade your front sway bar, as removing the sway bar with out removing the LCA appears to be all but impossible.
So if your still with me you have the majority of the work done and it time to get your strut assembly back in place. Getting the strut back into place can take some doing, try and manipulate it as best you can, some force may be required, but be mindful of the amount of force you are holding contained in your hands while you do it. Once you have it back in place secure it to the strut tower with the 3 bolts from earlier. You may need to pull the LCA downwards to align the hole through the strut with the hole through the LCA. Once you have the lower bolt in place and firmly tightened. Go ahead and jack the suspension back up to compress the strut assembly, this will make removing your strut compressor much easier. Remove your strut compressor, reinstall your break rotor and caliper. If your replacing the other side as well, it should be like déjà vu. Otherwise if your only doing the one side, go ahead and re install your sway bar, make sure its centered before you tighten it up to the frame.
Thanks for taking the time to read my lengthy write up, and stay tuned for struts, and rear sway bar installation write ups. Also I’m certain I have left something out and many of you will have questions, so feel free to ask away.
zerodevil is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-08-2012, 05:36 PM   #2
rangermidtn
Smyrna TN
rangermidtn's Avatar
2004 Explorer XLT 4x4
Vehicle Specs
Quoted: 25 Post(s)
I got one question on this, do you have to unbolt the arm from the frame to get the knuckle off the ball joint?
__________________
2004 Explorer 4x4
Truxx spacer lift rear,Rancho quicklift rear. Rancho Quicklift front, F150 tow hooks home made rock sliders, spartan locker,4.10 gears, 285/75/16 grabber at2,Rola roof rack
rangermidtn is offline   Reply With Quote
Old 12-08-2012, 06:23 PM   #3
HiImBrian
St. Petersburg, Florida
2003 Explorer Eddie Bauer
Vehicle Specs
Quoted: 21 Post(s)
Quote:
I didn't. I just gave the bottom of the ball joint bolt a couple taps with a hammer and it popped right out. I did have to remove the arm to press them out/in.
__________________
2003 Explorer Eddie Bauer 4.6L V8
MMR Stage 2 Heads - Ported Bullitt Intake - BanksPower TransCommand - CodeAlarm Remote Start - Hunter Brushguard - Custom Roof Basket - 3rd Cat Cutout - Straightpiped/Magnaflow Catback - 3" Body Lift - 2.25/1.75 BTF Spacers - F-150 Towhooks - 2" Wheel Spacers - HID's - 35/70/17's - EGR & PCV System Delete - AND MORE!
My Registry: HiImBrian's Beachcomber
HiImBrian is offline   Reply With Quote
Old 12-08-2012, 07:27 PM   #4
rangermidtn
Smyrna TN
Vehicle Specs
Quoted: 25 Post(s)
Quote:
Well then what am I doing wrong, I got the ball joint loose, but I can not get the arm and knuckle seperated.
__________________
2004 Explorer 4x4
Old 12-08-2012, 07:44 PM   #5
Mr Dubya
Elite Wannabe Explorer
Boston, Massachusetts
Mr Dubya's Avatar
'03 Explorer Ltd. 4.6L V8
Vehicle Specs
Quoted: 44 Post(s)
You're referreing to the lower ball joint correct? If so, it takes a bit of.negotiating to lift out of the knuckle.
If I remember correctly, I believe I had to disconnect the upper ball joint and CV axle from the knuckle/hub so as to lean the knuckle forward so the LCA would clear it and lift out.
Let me know if that works out for you. I redid all my front suspension recently so its fairly fresh.
__________________
2003 Explorer 4.6L V8 Limited | 7-Seater | 3" PA-883 Body Lift | 2.25"/1.75" BTF Coil Spacers | BTF Upper Control Arms | 17" Black Mamba M3 Wheels
P285/70/R17 Nitto Terra Grapplers | Clear Corners/Mountaineer Tails/4th Gen Mirrors/Halo Projector Fogs | Hunter Chrome Brush Guard
Quote:
"The problem with quotes from the Internet is that it's very hard to verify their authenticity" -Abraham Lincoln
Mr Dubya is offline   Reply With Quote
Old 12-08-2012, 07:47 PM   #6
HiImBrian
Vehicle Specs
Quoted: 21 Post(s)
Use a bigger hammer.
Or try adding a little heat. Also if I remember correctly the end of that post has a hex head to hold it still while you tighten the nut. Throw a wrench on it and see it it'll break free.
EDIT: I was talking about the upper ball joint.... I have NO IDEA how to do the lower. However I'm sure the "Use a bigger hammer" will work either way.... I mean, doesn't it always?
__________________
Old 12-09-2012, 12:01 AM   #7
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 127 Post(s)
if you jack up the lower arm so it's level the ball joint stem will pop out of the knuckle easier. when it's angled downward with the suspension flexed out it puts a side load on it that makes it harder to pop it out.
Ronin8002 is offline   Reply With Quote
Old 12-09-2012, 08:22 AM   #8
rangermidtn
Smyrna TN
Vehicle Specs
Quoted: 25 Post(s)
Quote:
Do you have to remove the CV axle when you did this?
__________________
2004 Explorer 4x4
Old 12-09-2012, 08:41 AM   #9
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 127 Post(s)
Don't think so but of course you should support it with something when you remove the lower control arm.
Old 12-09-2012, 09:42 AM   #10
Mr Dubya
Mr Dubya's Avatar
Vehicle Specs
Quoted: 44 Post(s)
I believe Ronin's correct about jacking the LCA up a bit to get it at a good angle.
__________________
Old 12-09-2012, 09:57 AM   #11
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 127 Post(s)
Mike, it might be easier if you DID pull the CV axle from the diff and just leave the knuckle attached to the other end. That would give you more room to work with the LCA.
Too bad I'm out of town for the next week. I have the OTC tool that ford uses to pop out the front CV axles from the diff. I'd be happy to loan it to you but I won't have access to it until next week.
Old 12-10-2012, 02:52 AM   #12
Dwelves02XLT
NORCAL
05 Eddie Bauer 4WD
Vehicle Specs
Quoted: 2 Post(s)
As the OP mentioned it is time consuming, I did both upper and lower arms with a lift and air tools. Thats one of the perks of being in the service, every base has a hobby shop with all the tools needed. It took 9 hours to complete replacing everything up front, and thats it being a 4x2, so I can only imagine it being a little harder for 4x4 vehicles. The lower control arms are a bitch though, took a while even with a air gun to get off. Replacing the arms brings the vehicles handling back to life, felt like a new vehicle once all done.
Dwelves02XLT is offline   Reply With Quote
Old 01-25-2013, 06:23 PM   #13
rangermidtn
Smyrna TN
Vehicle Specs
Quoted: 25 Post(s)
Alright when I did the coilover conversion, I changed the lower control arm. Wasn't too bad. I found by using a torch to heat up the front bolt on the lower control arm, reall made it a lot easier to take off. Also keeping the the lower arm level made it easier to remove the knuckle. Great thread and was really helpful for me.
__________________
2004 Explorer 4x4
Old 12-27-2014, 05:51 AM   #14
kscop
Haysville, KS
2002 Ford Explorer XLT
Vehicle Specs
Quoted: 1 Post(s)
Older thread but just a couple things I noticed.
On my 2002, I didn't have to use a spring compressor on the strut. I just unbolted the 3 13mm nuts from up top and the single large bolt holding it to the lower arm. Just drops out..
Also, when replacing the lower arm it's important to measure the ride height before starting and then lift the arm to simulate that height when tightening the bolts; starting with the inward ones.
kscop is offline   Reply With Quote
Old 02-23-2015, 10:21 AM   #15
adlpb
Boca Raton, FL
02 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
Quick question:
I believe this how-to is for a 4x4 explorer. I have a RWD model. Do I still need to buy the 30mm socket (which I suspect is for the axle nut)?
And does the suspension spring need to be compressed in a 4x2 as well?
Thanks
adlpb is offline   Reply With Quote
Old 02-23-2015, 01:20 PM   #16
kscop
Haysville, KS
Vehicle Specs
Quoted: 1 Post(s)
You need to check your application. My 2002 4x4 used all sorts of different sizes and they did not always match what the 'how to' or even the factory manual said they should be.
Old 02-23-2015, 02:40 PM   #17
lincolnshibuya
kc mo
2002 mercury mountaineer
Vehicle Specs
Quoted: 88 Post(s)
Quote:
Originally Posted by adlpb View Post
Quick question:
Thanks
there's no axle at the front, so no need.
there's also no need to compress the spring, just remove the top bolt and the whole coil over can be removed easily when the lower control arm is removed.
tighten the control arm bushings with load on the ground (or simulate a load using a floor jack)
lincolnshibuya is online now   Reply With Quote
Old 02-23-2015, 03:53 PM   #18
adlpb
Boca Raton, FL
02 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
Great, thank you sir
Old 06-26-2015, 08:43 PM   #19
rhartmaier
Monroe Township, New Jersey
2002 Ford Explorer
Vehicle Specs
Quoted: 1 Post(s)
Sway Bar?
Is it necessary to undo the sway bar if you are only replacing the upper control arms? Thanks, Bob
rhartmaier is offline   Reply With Quote
Old 02-25-2016, 08:26 PM   #20
sethsport
cocoa beach fl
2003 sporttrac xlt 4x4
Vehicle Specs
Quoted: 5 Post(s)
I have a 2003 xlt 4x4 sport trac. I noticed there was no mention of the torsion bar Or how to remove it out of the lower control arm for replacement. I've read some write ups where they just removed the bolt for the torsion bar and could take it out and some where they had to use a heavy duty two jaw puller to depress the key and take the nut out and everything. I'm about to do a front end upgrade. This info is definitely helpful.
sethsport is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
OBD-II Diagnostic Trouble Codes (DTCs) BobWiersema EEC V 8 03-26-2013 10:22 PM
EEC-IV 2 and 3 digit trouble codes. BrooklynBay EEC IV 16 03-26-2012 09:46 PM
ford manufacturer specific codes whale45714 Stock 1995 - 2001 Explorers 0 04-16-2011 10:03 AM
Lower control arm replacement? ernaldmerican Stock 1995 - 2001 Explorers 3 05-30-2007 07:31 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
