Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Vibration/chatter from 60 mph up
Reply
Thread Tools
Old 04-22-2012, 12:25 AM   #1
calthaus
Minnesota
2002 XLS 4x4 4.0
Vehicle Specs
(Original Poster)
I have been searching the forum here and have found several threads similar to this yet many do not continue to post when they find a solution. Maybe they don't...?
Two years ago I purchased a 02 XLS Auto 4x4 with 145,000 miles from a used car dealership to use for hunting and hauling the dog around. Everyting seemed fine until a few weeks later when I took it down the interstate. It had a terrible noise/vibration/shake (actually kind of bounced and wandered)that started at about 65 mph and did not go away at higher speeds. I assumed it was because of the uneven tires they had on it and just stayed off the interstate and below 65mph until I got some different tires.
Fast forward to now and 5,000 miles later...I just replaced all 4 tires which has dramatically smoothed the ride, however the vibration/noise is still there. The noise is best described as a deep chatter that I can now here actually becomes noticable at about 60 mph, increases to the loudest at 65 and stays that loud up to 80 (have not pushed it beyond as I am afraid something is failing). The rear end does have the whine everyone is so familiar with. This is a much different noise.
After reading others posts, I have tried several things to attempt to narrow down what might be causing it.
Bring it up to 75mph, turn overdrive off, noise stays the same.
Brown Wire Mod to disable power from being applied to front wheels. - no change, noise is the same.
Wheel Bearing check (6 and 12 position) no play. However part of me thinks that driving on those uneven tires for 5,000 miles may have ruined a bearing or two...
Jacked all four wheels off the ground, put it in drive and ran up the speed. There was all sorts of noise from what sounded to be the transfer case and some from the rear end. It was difficult to compare the sound to what is heard on the road as it was much noiser. Almost sounded like the transfer case would not fully engage properly at times. It made clicking noises even at idle speed.
All boot covers are in good shape, Rear drive shaft moves about 1/16 to 1/8" up when I press up where the two shafts connect in the center. Could not find anywhere if that is normal or not. There seems to be a lot of play in driveshafts/tranfercase and differentials.
My next thing to try is to remove the front driveshaft and see if anything changes...
Anyone have any experience with something similar? I really don't want to just start randomly replacing parts.
calthaus is offline   Reply With Quote
Old 04-22-2012, 12:41 AM   #2
tlutz211
Houston, TX
1997 XLT 4x4 4.0 sohc
Vehicle Specs
Cv joint on front drive shaft where it connects to transfer case... Even if visually it looks sound, internally it could be fried... This fixed most of my problem with the same exact symptoms (cv joint $125 autozone special order) still have some growling though and and hoping that it will be resolved this weekend with new bushings for upper control arms and camber bolts (mine look fine but do have some play) also if you have done a torsion twist try backing down just a little.
tlutz211 is offline   Reply With Quote
Old 04-22-2012, 02:29 AM   #3
Wills05xlt4x4
Ashland Va
Wills05xlt4x4's Avatar
2005 Xlt 4x4
Vehicle Specs
US
Quote:
Agreed they can be trash and appear ok...
btw No torsion bars on third gens... Struts all around...ifs/irs
__________________
Factory DVD, third row, rear A/C, Moon roof, Advancetrac RSC, Tow package, Leather everything, Eddie Bauer running boards.MODS- deep transmission pan w/dipstick, 1.5" Body lift, Expedition front tow hooks, Treadwright Guard Dog M/T 265-75/16 C Ply, Telescoping steering wheel mod, 4.56 gears limited slip front and rear,brembo brakes,front skid plate, Cb.FUTURE MODS-rock sliders, oba, steel front bumper w/ warn VR12000, possibly a M90
Wills05xlt4x4 is offline   Reply With Quote
Old 04-22-2012, 04:27 AM   #4
tlutz211
Houston, TX
Vehicle Specs
Ahh... Didn't pay attention to that... I have a bad habit of seeing someone with similar symptoms that I have had and just assuming they are running a comparable year model lol
Old 04-22-2012, 01:58 PM   #5
calthaus
Minnesota
2002 XLS 4x4 4.0
Vehicle Specs
(Original Poster)
Thanks for the quick responses. I pulled the front driveshaft, noise is still there at 60 on up. Put the rearend up on jackstands and ran it up to 30 then 60. Crawled under to listen closer and the noise is definetly coming from the differential/half shafts. Sounds like more noise is coming from the drivers side. After shutting down I checked the movement of the half shafts. The drivers side moves in and out much more than the passenger side. How much movement is normal?
Old 04-29-2012, 12:36 PM   #6
calthaus
Minnesota
2002 XLS 4x4 4.0
Vehicle Specs
(Original Poster)
OK, I pulled the drivers side rear knuckle and hub. How can I tell if the wheel bearing is bad? When I turn it, it does not "free wheel" and there is a faint noise like there is sand in the bearing. Should it spin pretty easily and keep spinning on its own for a bit?
Old 04-29-2012, 01:48 PM   #7
buckwill
trona calif
1998 sport
Vehicle Specs
if you have pulled the half shaft and turn the wheel and u can hear or feel anything the bearing is bad and needs changed,,should hear and feel nothing when bearings are good,, buck
__________________
if my memory was getting shorter would i know???,, disabled viet vet, retired navy,, 98 exploder sport sohc 4.0,, retired macinist,gas and steam turbine millwright,, ive arrested, stroked twice and i mispell lots,
buckwill is offline   Reply With Quote
Old 04-29-2012, 09:50 PM   #8
calthaus
Minnesota
2002 XLS 4x4 4.0
Vehicle Specs
(Original Poster)
I guess I am then getting a new bearing. I also managed to tear the ball joint boot worse than it already was whiltrying too remove the ball joint from the knuckle. Where the heck can I find a new boot? I have searched all over and no luck...
Old 04-29-2012, 10:17 PM   #9
buckwill
trona calif
1998 sport
Vehicle Specs
andys auto sports 1-800-419-1152,,, ball joint boots for ford explorer,, in COLOR if u want!!!!buck
__________________
Old 04-30-2012, 10:18 PM   #10
calthaus
Minnesota
2002 XLS 4x4 4.0
Vehicle Specs
(Original Poster)
Thanks. I found a universal boot I can use for now till I order one up. I took the hub to my mechanic who said the bearing seems fine. Said to bring it up and they would put it on the lift and try to find the source. So I put it back together (which was much easier than taking it apart) and took it for a ride. Keep in mind I also changed the gear oil in the differential yesterday. It was dirty and a bit thinner than the new 70w-145 I added. Anyhow, I noticed a change in the symptoms... the noise now starts at 70 MPH vs 60-65. I also noticed that now when I run it up to 80 and get the roaring vibration, if I let off the gas the sound fades for a moment as it starts to slow than comes back. It also seems like after I let off the gas and let the sound fade then accelerate softly just before the sound comes back it also keeps it at bay for a moment.... slack in the rearend? Gears, bearings?
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Explorer Shaking at Highway Speed (60 - 70 mph) XCAMP Stock 2002 - 2005 Explorers 30 01-04-2013 10:18 PM
My vehicle shakes when I go above 60 MPH. pwally1981 Stock 1991 - 1994 Explorers 7 05-07-2012 09:20 PM
Vibration above 60 mph Red_99 Stock 1995 - 2001 Explorers 10 08-11-2009 11:31 PM
Utterly useless trivia.... aldive Exploring every thing under the sun!! 5312 02-28-2009 01:49 AM
60 mph shake/vibration bcrews Explorer - Ranger Shocks, Suspensions, Lift Kits 2 05-18-2000 11:37 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
