| Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Monroe, CT
'11 Limited
AM Radio - any connection to roof fix???
So I brought in my Explorer for the MFT upgrade and the rain noise issue. I noticed that my AM radio is now inoperable as the static is horrendous. At first I thought maybe it was the MFT upgrade, but I am thinking maybe it could be something with the roof fix? Is there an AM antenna in that area? I am really so done with this. AM radio should not be a difficult thing to have! Not to mention that it finally rained and the rain noise was not noticeably better.
#2 |
2011 Explorer XLT
Noticed also the am is terrible after update, was also in for the rain noise they did not really say if they completed it or not, paper work was going to be mailed to me. Seeing the nightmares with expanding foam all over other posters interiors I will not complain if it wasn't completed as it is a lease.
#3 | |
Toyota Highlander Convert
Ottawa, Ontario area
2011 Limited AWD
Quote:
I am taking mine in tomorrow for the 12B36 program and an oil change. I initially asked them to do the rain noise TSB but after reading the various posts, I have asked them to delay that until later. I'll evaluate it some more. To be honest, I haven't really been bothered or noticed the noise that much. I can't comment on the AM reception since I don't listen to it in the vehicle at all. Peter __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#4 |
Richmond, VA
2011 Ford Explorer XLT
I have had my car in twice to address the static in the AM radio. In the last 3 months ths great radio has gone down the drain. The receipt from the dealership that checked the radio recommended that maybe I need a longer antenna and they mentions a 32 inch might do the trick. I believe the Tech was being a real smart.....! I do like the car, but this has been a real negative experience trying to get things fixed.
#5 | |
2011 Limited AWD
Quote:
If it really bothers you and you're willing to pick up the cost, I would suggest tasking it to a car audio shop. Peter __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#6 |
Rochester Hills, MI
'11 explorer XLT 202A
Does somebody even listen to AM radio?
#7 |
New Castle, DE
2011 Explorer Limited AWD
I read somewhere that we are in an active period for solar activity/sun spots. Will continue thru next year. This effects radio, sat., etc.
Don't know if it effects am more than fm. new to ford, I'm with you. Last time I listened to am was 2006. Driving a truck in Philadephia. Always listened to all news station for traffic updates every ten minutes. __________________ "Always do right. This will gratify some people and astonish the rest."- Mark Twain |
#8 |
Monroe, CT
'11 Limited
The best sports radio station is on am.
I finally brought in my car for a bunch of things and the am radio was one. They called me a couple of days later to say everything was done and when I asked about the radio they said everything was fine. Really??? When I questioned this the guy said they get really bad reception inside. I asked him to listen to it outside. A day or two later he called back and said they tightened up all of the wires. I asked if it helped and he said I had to be the judge of that. Long story short - it is still awful. THIS is why when people ask me how I like the explorer I say it is OK but these annoying things add up and I wouldn't recommend it to anyone. |
#9 | |
2011 Limited AWD
Quote:
Just went out and tried the AM radio and pulled in 3 local stations without any problems. This was with the engine off and sitting in a closed garage. Peter __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds Last edited by peterk9; 08-23-2012 at 05:40 PM. |
#10 | |
Monroe, CT
'11 Limited
Quote:
Thanks for checking your radio for me! |
#11 | |
Ontario
2012 Explorer Limited
Quote:
I haven't listened to it in years and don't know if it works in my Ex and Icould care less if it doesn't..... |
#12 | |
2011 Limited AWD
Quote:
Have you tried other radios of Explorers on the dealer lot? If they are getting good reception on the same stations then it should prove to the dealer that there is a problem and that it should be fixed. Good luck. Peter __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#13 |
Old and in the way
Humboldt, Kansas
2000 Mounty
Geez people. Who cares if "you" listen to AM. The OP does and I am with him.
Am radio is still out there, blazing 50,000 watt stations are all over the place. Ads are purchased. Lots of people still listen to it. Sometimes talk is ok you know-it does wonders to keep you awake on a long lonely road. If someone pays over 40k for a new car, yes, all the features should work. and they should work good. If they can't even get the AM radio right, how can you trust anything else is? |
#14 | |
2011 Limited AWD
Quote:
"blazing 50,000 watt stations" , except when they have to reduce power to around 10K at night. ![]() Peter __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#15 |
Old and in the way
Humboldt, Kansas
2000 Mounty
Perfect example of how the explorer became what it is today--
" The 4x4? work? I don't ever use it so I don't know if it works or not" |
#16 |
Offroad Moderator
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
..Thanks to this mod, whenever I'm in the back country I have all the am stations I want..
![]() http://thatguy.stp.com/blog/detail/q...radio_antenna/ __________________ I have Rocks in my head. What's in yours? ![]() '95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel '91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's ListHow to: Wheels,Tires, & Lifts... Buy Explorerforum.com Items here |
#17 | |
Ontario
Quote:
Just saying....
#18 |
Evil Asian
Elkridge, MD
91
Does the static change with rpm's? It maybe a issue with interference with something in the explorer or the surroundings. The logical fix would be to add shielding to the cable but thats kinda hard when its in the roof.
#19 |
Old and in the way
Humboldt, Kansas
2000 Mounty
If the antenna cable goes thru the roof cavity to the antenna, I see how expanding foam might pull the connection loose. That stuff can move a door casing on a house.
#20 |
Cumming, GA
'11 LTD Golden Bronze
The AM radio reception in mine has always be horrendous and un-listenable. I would be on the complaint bus, but fortunately most of the AM stations in town have added an HD band for simulcast that works most of the time.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Radio / Clock display problem 1998 and up Explorers ( blank / fade / blanks / fades ) | dkoets | Stock 1995 - 2001 Explorers | 112 | 05-02-2013 06:19 AM |
| I need help with a radio connection on a 2005 Ford Explorer. | yankeegrl09 | Explorer Audio & Navigation | 1 | 11-16-2009 09:09 PM |
| Ham Radio Introduction | Rick | Ham Radio - CB - Trail Communications | 1 | 02-15-1999 09:08 PM |
| Thread Tools | |
