Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
How to open hood?
Reply
Thread Tools
Old 04-26-2012, 05:13 AM   #1
Chris4x4Gill2
Decatur, AL
99 XL 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
How to open hood?
I know, simple question right? My 99 Explorer will not "pop" the hood using the in cab release and I haven't been able to open it from the grill either. Whats the trick to get it open?
Also, how do I fix the in cab release?
__________________
Chris
'99 SAS Explorer
Chris4x4Gill2 is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-26-2012, 06:41 AM   #2
BigJoe1094
New Jersey
2000 Mercury Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
there should be a cable attached to the latch. make sure that is still attached. if not there's your problem.
__________________
2000 Mercury Mountaineer SOLD
2006 Ford Ranger 5-6 inches with 35s
Pics of the Mounty
BigJoe1094 is offline   Reply With Quote
Old 04-26-2012, 06:45 AM   #3
drbenz
High Point, NC
2000 EB 5.0
Vehicle Specs
Quoted: 5 Post(s)
Try the two man method to open the hood, one to pull the release and the other to push down on the hood to take the pressure off of the hood latch. Sometimes it takes a little messing with the hood to open it (be careful not to overdo it, i've seen hoods dented by pushing too hard) and after it's open lube the latch to prevent the problem from happening again.
drbenz is offline   Reply With Quote
Old 04-26-2012, 07:21 AM   #4
Chris4x4Gill2
Decatur, AL
99 XL 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
The cable is still attached to the release, ill find a second set of hands and see if relieving the tension helps.
Is there a way to release the latch with a screwdriver or something through the grill if that fails?
__________________
Chris
'99 SAS Explorer
Old 04-26-2012, 09:13 AM   #5
yavapaires
Dewey, Az
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
Yes, you can go through ths grill, just to left (drivers side) of center at the top opening. Use a long flat screwdriver. There is a slot at the top of the latch. Very easy to do. I have to thank someone else on here for posting the procedure last year.
yavapaires is offline   Reply With Quote
Old 04-26-2012, 10:05 AM   #6
dcdyd
Eden Prairie, MN
98 Explorer
Vehicle Specs
Quoted: 12 Post(s)
The latch could be rusted. It was that way for my case.
dcdyd is offline   Reply With Quote
Old 04-26-2012, 11:23 AM   #7
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 685 Post(s)
Look under the dash and you'll see a brass colored bracket which the cable slides through. First, make sure the screws attaching it are tight.
Grab an adjustable wrench, clamp it onto the bracket, and "adjust " it by bending toward the firewall. Move the wrench from side to side while bending it to make it even. Move it only about 1/4" or so.
Now, grab the latch release handle give it a very fast tug and see if the hood pops.
Worked for me.
Lube the entire latch mechanism once you get it to pop open. Good luck.
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline   Reply With Quote
Old 04-26-2012, 07:51 PM   #8
Chris4x4Gill2
Decatur, AL
99 XL 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for the tips, ill be giving it a try this weekend.
__________________
Chris
'99 SAS Explorer
Old 06-21-2012, 07:07 AM   #9
Chris4x4Gill2
Decatur, AL
99 XL 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have still not been able to get the hood open! I can push the second release from underneath the truck, but can not get the first latch to let go. Anyone know a trick to get this thing open? The under dash cable is not broken, i can hear it moving at the latch, but the hood isnt budging.
__________________
Chris
'99 SAS Explorer
Old 06-21-2012, 07:33 AM   #10
Ghostimage
Winnipeg, Manitoba
1996 Explorer XL
Vehicle Specs
Quoted: 0 Post(s)
Do you have someone lifting on the hood while you pull the cable?
Ghostimage is offline   Reply With Quote
Old 06-21-2012, 09:12 AM   #11
Chris4x4Gill2
Decatur, AL
99 XL 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Yes. Tried pushing down, prying up, even got underneath the truck and pushed straight up using a broom handle.
__________________
Chris
'99 SAS Explorer
Old 06-21-2012, 01:50 PM   #12
deweyville65
Dewey,Az
96 EXPLORER XLT
Vehicle Specs
Quoted: 30 Post(s)
Did you do what I posted on 4-26-12? If that doesn't open the latch, get a cutting torch. Actually it is very easy to open the hood with a screwdriver. Did this on mine right after Igot it. Having lubed the latch, and adjusting the hood stops, it opens with very little pressure from the inside.
deweyville65 is offline   Reply With Quote
Old 06-21-2012, 02:06 PM   #13
Chris4x4Gill2
Decatur, AL
99 XL 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Deweyvilles - i do not see an earlier post from you.
Yavapairs said to use a flat scfewdriver in the slot at top left of the latch, can someone explain this more?
__________________
Chris
'99 SAS Explorer
Old 06-21-2012, 02:37 PM   #14
deweyville65
Dewey,Az
96 EXPLORER XLT
Vehicle Specs
Quoted: 30 Post(s)
Deweyville, yavapaires, one in the same. I use a POS Samsung tablet that causes me a lot of trouble. Got logged off somehow, couldn't find password, signed up new. Now, to your problem. Top opening of grill to left of center. Right side when looking at front. Look at top of hood latch. You may need a flashlight. There is a small slot at the front top. Using a long flat screwdriver, reach into the slot and pry to the left . The hood should come open. If it does not open, you are SOL as far as I can tell. Get a buddy to push down/ pull up on hood at the same time. Be careful, as you can dent tbe hood when pushing down.
Old 06-21-2012, 02:48 PM   #15
Chris4x4Gill2
Decatur, AL
99 XL 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ok, thanks for the details. Ill give it a shot.
__________________
Chris
'99 SAS Explorer
Old 06-21-2012, 06:49 PM   #16
2010nctaco
North Carolina
2000 explorer
Vehicle Specs
Quoted: 0 Post(s)
I was having the same problem. If you can get some wd-40 or pb blaster and spray the latch as best as you can with it closed. That may loosen it up some so you can get someone else to help push down on the hood while you ppull the latch. That worked for me anyway. Hope that helps.
2010nctaco is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
My hood won't open. pgriggs Stock 1991 - 1994 Explorers 5 12-27-2010 10:00 PM
Hood won't pop open without extra help. Czar Zach Stock 1991 - 1994 Explorers 2 07-19-2010 03:02 PM
HELP!! Wife just called, 93 X won't start and hood won't open shadowless127 Elite Explorer 911! 12 08-24-2009 05:26 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
