Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Ignition-Wire color help!
Reply
Thread Tools
Old 04-26-2012, 06:02 AM   #1
craftsman67
Willow Spring NC.
1998 Ford Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Dk Exp Ignition-Wire color help!
I know it's kinda silly, and pointless... but I'm doing one of those push button starts I bought from ebay...just because! Lol.... Anyway, I found a good schematic for 97 and before, but can't seem to find one for 98 and up...Would the ignition wiring colors be the same? I understand that they may have changed some of the wiring in 98...Can someone help me with this info.
Thanks!
Scott.
craftsman67 is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-26-2012, 07:08 AM   #2
craftsman67
Willow Spring NC.
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I found this info somewhere else...I hope it's correct!
1998 Ford Explorer Car Alarm Wire Diagram
Battery Constant 12v+ Positive Wire (+): Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Red/Light Blue
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Light Green/Purple (1 Of 2 Wires, Use Either Wire)
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Light Green
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Gray/Yellow (1 Of 2 Wires, Use Either Wire)
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): White/Purple
Parking Light Negative Wire Location: In Drivers Kick Panel
Parking Light Positive Wire (+): White/Black
Parking Light Positive Wire Location: At Headlight Switch
Power Door Lock Negative Wire (-): Pink/Yellow
Power Door Lock Negative Wire Location: In Drivers Kick Panel
Power Door Unlock Negative Wire (-): Pink/Light Green
Power Door Unlock Negative Wire Location: In Drivers Kick Panel
Door Trigger Positive Wire (+): Black/Light Blue
Door Trigger Positive Wire Location: In Drivers Kick Panel
Domelight Supervision Wire: Use Door Trigger (Requires Relay)
Domelight Supervision Wire Location: N/A
Horn Negative Negative Wire (-): Yellow/Light Green
Horn Negative Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Tan/Yellow
Tachometer Wire Negative Wire Location: At PCM. The PCM (powertrain control module) is located at the top of the firewall towards the passenger side of vehicle.
Brake Light Positive Wire (+): Light Green
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): Dark Green/Purple
Factory Alarm Disarm Wire Location: In Drivers Kick Panel
Anti Theft Type: Ford’s PATS anti-theft (some vehicles) transponder system.
Old 04-26-2012, 01:24 PM   #3
bobflood
Powder Springs, GA
1997 Eddie Bauer V8 2WD
Vehicle Specs
Quoted: 98 Post(s)
Quote:
Thanks!
Scott.
Great source for online wiring info.
Auto - Online Repair Info
http://search.ebscohost.com/
PW: rebsco
Select: Auto Repair Reference Center
Fill in: Find Your Vehicle
Follow prompts down to Wiring Diagrams.
__________________
1997 Ford Explorer, Eddie Bauer, 5.0L V8, 2WD, 295K+ miles, starting to show its age!
bobflood is offline   Reply With Quote
Old 04-26-2012, 01:37 PM   #4
SouthernSAR
Naples, FL
SouthernSAR's Avatar
2004 Explorer ST XLS
Vehicle Specs
Quoted: 0 Post(s)
I'm in love with that website.
__________________
ZAPV373- 2004 Explorer Sport Trac XLS 2WD
Quote:
Originally Posted by jcerrion View Post
flame throwers come standard on the XLT.
SouthernSAR is offline   Reply With Quote
Old 04-26-2012, 02:13 PM   #5
craftsman67
Willow Spring NC.
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
PW: rebsco
I'm very confused about this website...don't see anything at all about wiring diagrams...or am I missing something?
Old 04-27-2012, 09:40 AM   #6
bobflood
Powder Springs, GA
Vehicle Specs
Quoted: 98 Post(s)
Once you get thru the steps listed in the post, you should see a list of "Topics" for your vehicle. The third one down is titled "Diagrams" and is the wiring diagrams. Where are you getting hung up??
__________________
Old 04-27-2012, 01:42 PM   #7
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
remote crank method
I added a remote crank capability for compression testing. The same method could be used for a start button. The button would work whether the ignition is on or off. See this link: Remote crank control
2000StreetRod is offline   Reply With Quote
Old 04-27-2012, 02:07 PM   #8
craftsman67
Willow Spring NC.
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I got it...I was just a little confused witch harness was the right one...the above wiring chart is correct.
After the install, the only issue I have, is the rear wiper motor isn't working... I placed the start button in the radio bezel, where the cig lighter was. I removed the bezel to mod it, so the button would fit right. I had to remove the switch harness for the rear washer/wiper...The washer part works as far as pumping the fluid, but no wiper...I located the 15a fuse for it, and it was ok. I was trying to find a relay for it...any ideas where it is, or even if there is one?
Old 04-27-2012, 02:09 PM   #9
craftsman67
Willow Spring NC.
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
I like that...I would add one of those too...If mine wasn't a stick.
Reply
Tags
Push button start
Similar Threads
Thread Thread Starter Forum Replies Last Post
The Comprehensive Brown Wire Mod Thread gijoecam Explorer & Ranger Transmissions, Transfer Cases, & Differentials 386 04-09-2016 10:14 AM
4405 to 1354 e Conversion albi1cnobi1 Explorer & Ranger Transmissions, Transfer Cases, & Differentials 30 11-17-2014 07:37 AM
Ignition Systems: COP vs. Wastespark vs. DIS mshuler009 Need for Speed! 2 09-06-2010 10:50 AM
Where is the wire from ignition to starter? 99 4.0 Ranger379 Under the Hood 1 09-09-2009 08:06 AM
ignition hot wire color? - '97 XLT treywylie Explorer Audio & Navigation 1 07-24-2003 08:19 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
