Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Street Truck & Performance Forums > Street Trucks > Need for Speed!
Notices
Need for Speed! Explorer, Ranger, Mountaineer 4.0 - 4.6 - 5.0 Nitrous, Superchargers, Camshafts, Head Work, Stroker Kits... DRAG RACING. Explorers, Mountaineers and Rangers CAN move!
SOHC V6 Supercharger
Reply
Thread Tools
Old 04-27-2012, 02:09 PM   #21
Dono
Supercharged OHV
Winnipeg, Manitoba
Dono's Avatar
00 Explorer XLT 4.0 OHV
Vehicle Specs
Couldn't you just take the fuel rails off of a junk yard motor and use them? I think on rpcasters web site there is a small blurb with pictures as to what was done to an sohc explorer to make the kit fit. Looked pretty easy.
__________________
Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it.
Dono is online now   Reply With Quote
Old 04-27-2012, 02:11 PM   #22
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
Quote:
Originally Posted by 2000StreetRod View Post
Thanks for posting that link. It looks like the plenum bolts directly to the heads.
Attachment 69440
If so, then what about the knock sensor and the injector wiring harness?
Attachment 69441
A new injector wiring harness could built but I would hate to lose the knock sensor - it is even more important with forced induction.
Attachment 69477
From the above photo it looks like there is no problem with the knock sensor because it is lower than the head ports.
From the photo in the first post it looks like the Explorer Express phenum allowed retention of the knock sensor and stock injector wiring harness.
I bet you if you split that harness open there is two main groups of wires in there.one per side or bank.if so there is no point of having it grouped together in the middle.just split it and run one on each side of the sc mount.my buddy has a ton of harnesses for sohc including some from a ranger,ill ask him when he gets home and check it out
__________________
92 xl 5.5"duff arms,3"BL,PJ 36x14.50,wrapped headers,side dump exhaust,.20 over,HF oil pump,422cam,45cc 95tm p+p 10.67:1 heads,p+p lower manifold,75mm TB,90mm maf,36lbs injectors,P+P GM M90 Supercharged & intercooled!!SCT tuned!!electric fan,4.88s aussie locked front & back!!next NOS&W/M
http://www.explorerforum.com/forums/...=double+vision
jd4242 is online now   Reply With Quote
Old 04-27-2012, 08:26 PM   #23
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
here is the reply to the email i sent rpcaster.so i was right you can spit it and put it on the outsides
''Sounds like you might have an Explorer?
I does mount to head. You can open loom and move injector wiring to outside "like Ranger" and other can mount below in void area. Check out website bansheesuperchrger.com visit "customer rides" click on the year link below explorer and I believe you will find add'l info.
- rpcaster''
__________________
Old 04-28-2012, 07:37 AM   #24
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
2000 Sport SOHC 2WD
Vehicle Specs
(Original Poster)
belt slip
One concern for belt driven superchargers that is not an issue for turbochargers is drive belt slip on the supercharger pulley. Higher boost is achieved by decreasing the driver pulley to make the supercharger spin faster. The faster the supercharger spins the more force required to drive it. A smaller pulley reduces the contact area between the drive belt and pulley increasing the chance of belt slip. Unfortunately, the SOHC V6 (unlike the V8) has an integrated harmonic balancer/serpentine belt pulley. It is impractical to add a dual belt pulley to the harmonic balancer. Therefore the supercharger must be driven by the serpentine belt that drives the rest of the accessories. It looks like the Banshee kit replaces the stock idler pulley with a dual idler pulley and snout support bracket.
This configuration would provide about 180 degrees of supercharger pulley wrap (almost the maximum).
I wonder what boost (smallest pulley) can be achieved without belt slip.
__________________
My Helpful Threads, Registry, 16.4/23 mpg, 3900 lbs, 5R55E, 3.73:1, 175 rwhp, Henson custom tune, CAI, Spectre air filter, Lightning 90mm MAF, 75mm throttle body, A/F ratio meter, synthetic oils, Accusump, 2 row radiator, 3+1 leaf springs, .75 inch drop, Edelbrock IAS lowering shocks, engine oil & ATF temp gauge & remote filters & coolers, remote crank
2000StreetRod is online now   Reply With Quote
Old 04-28-2012, 01:39 PM   #25
Dono
Supercharged OHV
Winnipeg, Manitoba
Dono's Avatar
Vehicle Specs
http://www.pulleyboys.com/store/prod...5&cat=9&page=1
I'm not sure, but see Rockets postings on efficiency of the m90. Also, I haven't heard of anyone complain of belt slip. You could be right though.
__________________
Old 04-28-2012, 04:23 PM   #26
2000StreetRod
Greenville, SC
2000 Sport SOHC 2WD
Vehicle Specs
(Original Poster)
Fuel efficiency
It may seem inconsistent to discuss supercharger fuel efficiency but when gas prices approach $4 per gallon it is something to consider. Eaton superchargers are positive displacement air pumps. That is one reason they produce boost at low engine speeds. When a blower is producing boost it is performing work which requires energy. An Eaton supercharger is ideal for accelerating a heavy vehicle from rest or from upshifts for a transmission with wide spaced gearing. Boost is probably not required at idle, normal cruise speeds or deceleration.
The chart below posted by Rocket 5979 shows the inlet flow vs supercharger rpm which is quite linear.
One article I read states the airflow of a centrifugal supercharger increases proportional to the square of the rotation speed. If 8 psi of boost is produced at 6500 rpm engine speed only 2.8 psi of boost is produced at 3250 rpm engine speed.
I think centrifugal superchargers "slip" more than positive displacement superchargers at low engine speeds. Consequently, they produce less boost but require less energy. Accordingly, a centrifugal supercharger may have better fuel efficiency than an Eaton supercharger for a daily driver. On the other hand, for a heavy SUV the lower speed boost provided by an Eaton supercharger will make the engine displacement seem significantly larger and much more responsive. More torque at low engine speeds could reduce average engine speeds and improve fuel efficiency. Since vehicle manufacturers incorporate positive displacement superchargers much more frequently than centrifugal superchargers I suspect they have already determined which type is most fuel efficient and driver satisfying.
The rotation speed and boost of a turbocharger is more dependent on engine load than either of the above types of superchargers. As exhaust flow increases so does the turbine speed and associated boost.
__________________
Old 04-28-2012, 04:57 PM   #27
boominXplorer
Virginia Beach, Va
boominXplorer's Avatar
00 4x4 Mounty
Vehicle Specs
All the newer 01 newer sohc's (except explorer) have steel fuel rails instead of plastic and have the wiring harness on top of the fuel rails. They also use plastic valve covers with the pvc valve on the drivers side instead of using the box thingy in a freeze plug in the valley of the block.
__________________
1998 Mountaineer 5.0 2wd - Mac intake, Ported intake, FMS headers, 3" Exhaust, E-fan, SCT tuned, Baumenn Shift Kit, MSD, 4.10 l/s, Lowered 3/2 on 18x9 Cobra r's, HID's
2002 F250 Crew Cab SB 7.3 Diesel 4x4 - 4" MBRP exhaust, AIH delete, SCT Livewire
2001 Ranger ext cab 4x4 - 5.0/4r70/4406 swap in progress
(2) 97 Mountaineers for parts
98 Sport for Parts My eBay auctions
boominXplorer is online now   Reply With Quote
Old 04-28-2012, 07:14 PM   #28
2000StreetRod
Greenville, SC
2000 Sport SOHC 2WD
Vehicle Specs
(Original Poster)
fuel rails & injector harness
Quote:
Thanks, Chris. That could be very helpful, cost and labor saving information.
__________________
Old 04-29-2012, 06:36 AM   #29
2000StreetRod
Greenville, SC
2000 Sport SOHC 2WD
Vehicle Specs
(Original Poster)
Gearing & engine performance
The formula for vehicle speed vs engine rpm is:
mph = (rpm*tire dia.)/(ratio*336)
My BFG P235/75R15 tires have a diameter of 28.86 inches
My rear axle ratio is 3.73:1
1st 2.47*3.73=9.21 @ 6,000 rpm = 56 mph
2nd 1.86*3.73=6.94 @ 6,000 rpm = 74.3 mph
3rd 1.47*3.73=5.48 @ 6,000 rpm = 94 mph
4th 1.00*3.73=3.73 @ 6,000 rpm = 138 mph
5th 0.75*3.73=2.80 @ 6,000 rpm = 184.5 mph
A graph of the above shows the change in engine rpm when shifting from one transmission speed to another for any vehicle speed.
For example at 60 mph an upshift from 3rd speed to 4th speed is an engine speed change from approximately 3800 rpm to 2600 rpm.
At lower engine speeds the torque converter increases the overall gear ratio increasing the engine speed for a given vehicle speed. This can be seen on a datalog of a WOT test from rest in 3rd speed.
The bold line represents engine rpm with its scale on the right of the graph. The other line represents vehicle speed with its scale on the left of the graph. The time scale is on the bottom of the graph.
The vehicle speed increases while the engine speed remains constant (@75 secs) or even decreases (@76 secs) as the torque converter ratio decreases to 1:1.
Below is a copy of my stock engine performance after the throttle cable modification in transmission selector "2" or 3rd speed.
Selecting a supercharger that broadens the engine torque curve will result in the most satisfying driving experience.
__________________
Old 04-29-2012, 06:54 AM   #30
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Like you said, it all depends on where you want that extra power. With a centrifugal you're going to get it at the top of the RPM range/WOT usually. With a positive displacement you get it down in the lower RPM range and the ability to build some boost at part throttle.
Having run a Vortech centrifugal on my 91 4.0 OHV, I personally feel for a truck or SUV it's better to get the power down low (positive displacement) since accelerating from a stop is where these types of vehicles need more power.
I guess if you're racing you might want power at the top end/WOT. But if that's your goal then maybe you could just run nitrous oxide injection and have a less expensive setup that is only "on" when you want it.
A graph of the above will show the change in engine rpm when shifting from one transmission speed to another for any vehicle speed.
At low engine speeds the torque converter increases the overall gear ratio increasing the engine speed for a given vehicle speed. This can be seen on a datalog of a WOT test from rest in 3rd speed. The vehicle speed increases while the engine speed remains constant or even decreases as the torque converter ratio decreases to 1:1.
__________________
Mods: 265/70/17 Mickey Thompson Baja STZ on 17x8 Black Rock Viper 900B wheels, Bentley style grille, Raptor style LED grille lights, Pacer performance clearance lights, 30" 180W LED light bar behind grille, BTF upper control arms, Fox 2.0 5" travel emulsion coilover shocks in front/rear Truxx spacers, 1" body lift, front skidplate under radiator, recovery shackle mounts
My Rig:http://www.explorerforum.com/forums/...47#post3004247
Ronin8002 is online now   Reply With Quote
Old 04-29-2012, 09:03 AM   #31
2000StreetRod
Greenville, SC
2000 Sport SOHC 2WD
Vehicle Specs
(Original Poster)
no racing
Quote:
I agree. Thanks for posting your first hand experience with a centrifugal supercharger.
I have no interest in racing. Almost all of my driving is in the city. I just want to enjoy the responsiveness of a larger engine without performing an engine swap to the 5.0L V8.
__________________
Old 04-29-2012, 01:37 PM   #32
2000StreetRod
Greenville, SC
2000 Sport SOHC 2WD
Vehicle Specs
(Original Poster)
ultimate supercharger
In my opinion for my driving the ultimate supercharger would be one with instantaneously available variable boost appropriate for engine load and user requested demand. The variable boost would be PCM controlled and the requested demand would be reflected by the depression of the accelerator as reported by the throttle position sensor. One method of providing nearly instantaneously available variable boost is by driving a supercharger with a variable speed electric motor. Unfortunately, an appropriate capacity motor (10 hp) normally requires a 24 volt or greater supply to reduce current flow. That would mean another 12 volt battery and alternator (heavy and space consuming) in additional to the electric motor.
The next best alternative seems to be a positive displacement blower. While not providing a user requested variable boost, at least the boost is fairly constant throughout the normal power range of the engine. I will investigate the various types and brands of positive displacement superchargers. One other advantage could be a less cluttered engine compartment.
__________________
Old 04-29-2012, 03:55 PM   #33
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer A4WD
Vehicle Specs
Hi Dale, I see that you are well on your way to figuring out the best path for your truck.
I suggest the Eaton style over intake PDB, with an intercooler underneath if possible. Fuel mileage may suffer, but there is one simpler possibility than the variable boost/pump etc.
I saw a car show recently which advertised an aftermarket cylinder cut out device for EFI vehicles. There were no real details or price, I didn't catch a brand name, but it appears it would work for any OBDII vehicle. That may be an answer to a vehicle that has lots of low rpm power and drag, during light throttle.
Good luck there, and don't do anything without addressing the weak 5R55E trans. It's fine for a stock engine, but above that it needs all the little things done that are available. If I boosted a SOHC vehicle, I would first build and install a spare 5R55E with everything done to it. Work out the kinks with that, and then put the boost to the engine.
__________________
Don
91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior.
The best thing that could help us all, is the Fair Tax Plan.
Be American, Buy American (Manufacturer)
CDW6212R is online now   Reply With Quote
Old 04-29-2012, 08:16 PM   #34
2000StreetRod
Greenville, SC
2000 Sport SOHC 2WD
Vehicle Specs
(Original Poster)
5R55E upgrade
Quote:
Originally Posted by CDW6212R View Post
. . . don't do anything without addressing the weak 5R55E trans. It's fine for a stock engine, but above that it needs all the little things done that are available. If I boosted a SOHC vehicle, I would first build and install a spare 5R55E with everything done to it. Work out the kinks with that, and then put the boost to the engine.
Thanks for the good advice Don. I'm surprised that Jake's transmission has lasted so long with the turbocharger.
__________________
Old 04-29-2012, 08:48 PM   #35
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
You want a surprise, i still run a A4ld! probably not much long though, i plan on doing the 2.9 5 speed swap.but not because the a4 is failing,i want that lower first gear of the 2.9
__________________
Old 04-29-2012, 09:10 PM   #36
2000StreetRod
Greenville, SC
2000 Sport SOHC 2WD
Vehicle Specs
(Original Poster)
back & knees
Quote:
I've had numerous vehicles with manual transmissions: Alfa 2600 Spider, Jaguar E-Type, BMW 635, Volvo 544 & 142E. I eventually learned that a good automatic could shift faster but doesn't have as much control (engine braking, downshifts, etc.) Now I'm lazy with a bad back and knees so will never have another manual.
__________________
Old 04-29-2012, 09:14 PM   #37
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
O i hear you.i love my auto but i want that controll like you said and that lower first gear.i run BIG 36x14.50 and 4.88s.i wish i went 5.13 for sure as this is mostly a off road truck.ive hear those 5r can be pretty strong with some mods.
__________________
Old 04-30-2012, 12:46 AM   #38
rocket 5979
Resident Gearhead
Lake Villa, Illinois
rocket 5979's Avatar
'03 XLT 4.6
Vehicle Specs
Proper tuning and band adjustment are key to keeping those transmissions alive. Got those down pat and as long as the transmission was in good mechanical shape beforehand they will be able to take a little bit of power. Your tuner might just know a thing or two about that.
__________________
2003 4.6 V8 XLT Black Explorer, Kenne Bell 2.2 Supercharger, VT Billet bottom end, MPH 2.5 Heads, Blower cams, A1000 custom fuel system, and on and on...
2009 6.6 V8 Pontiac G8 GT, Twin Turbo, 402ci, Turbocam, Circle D Built 6L80E, Circle D 3000 Stall, new fuel system on its way...Shooting for 750+rwhp and easy middle 10's.
2002 4.0 V6 Explorer Sport, CAI, Gibson Exhaust...
2005 3.9 V8 Lincoln LS, KBX Performance Garrett Turbo System...Sold...
rocket 5979 is offline   Reply With Quote
Old 04-30-2012, 04:11 AM   #39
2000StreetRod
Greenville, SC
2000 Sport SOHC 2WD
Vehicle Specs
(Original Poster)
band adjustment & tune
Quote:
Thanks for reminding me that I still need to perform a band adjustment. When I purchased my Sport I couldn't tell from driving it whether I had a 4 speed or 5 speed trannsmission because the upshifts were so soft. James did an excellent job adjusting the transmission shift pressure and timing.
__________________
Old 04-30-2012, 09:00 AM   #40
rocket 5979
Resident Gearhead
'03 XLT 4.6
Vehicle Specs
I bet he did. I tune all of my own vehicles myself but when I wanted a tune for the Green V6 Explorer I didn't even bother with it because I knew James can tune it better than I could because of all of his experience with the 4.0 SOHC and 5R55E. Why mess with perfection and reinvent the wheel when I have a friend who is likely the best V6 Explorer tuner out there?
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
4.0 Sohc V6 Supercharger 93whitelightnin Need for Speed! 8 04-27-2011 07:34 AM
Calling all SOHC Experts - Differences and Headers Fredness Modified 1995-2001 Explorers 17 01-12-2008 09:18 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
