EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Modified 1991-1994 Explorers
Notices
Modified 1991-1994 Explorers Questions concerning modifications to the 1991-1994 Explorer, Mountaineer, Ranger and Navajo. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
My 93' Explorer Restoration Project
Reply
Thread Tools
Old 06-19-2012, 03:29 AM   #81
cerberusaardvark
San Diego
1994 Explorer xlt
Vehicle Specs
one thing i found after i had all my hardware in place was that the ride height was super equal without the addition of the one inch extended leaf spring shackles included in the kit. after i had the kit 100% done, i had it towed to an alignment shop so they could correct the camber and everything. after having the truck back for about a month, or about 500 miles, one day i happened to be walking up to it and i noticed the front tires had gone all crazy pointing in different directions.. so my advice would be to not forget about getting it re aligned and re tightened. i also had a lot of luck re tapping the RA studbolt holes. mine were so rusted that when i finally got them to give in it warped the boltholes on the way out. after i re tapping them, i could tighten he studbolts all the way to the quick with just my fingers. i would recommend re die-ing the threads on the studbolts as well to clean off all the nasty crud, so that way you get a true torque read when you put them back together. one other thing i did was leave off the front differential bolt that gets covered up by the radius arm. did that because i would like to add in a locker at some point in the future without having to tear everything back apart. couple other things i did while the front differential was out was replacement of the axle seals (jeffs bronco graveyard) and installation of the c clip eliminator. that front pig is a pain to get to so while its out, take advantage and do a little tlc. one thing i over looked was while the rear leafs were out and apart for the add a leaf i neglected to have leaf spring keeper bands placed around all four leafs (including the add a leaf). nbd but now im too lazy to go back and do it.
cerberusaardvark is offline   Reply With Quote
Old 06-19-2012, 06:52 AM   #82
adamsbro2
Clearfield, UT
93 XLT
Vehicle Specs
Looking Awesome Bro!!! I am actually quite jealous of the double shocks and new buckets i might have to spring and get some myself. I am impressed at the patience you are having and taking the time to clean all the frame parts and paint everything, As you know I didn't do that! I am planning on going back and getting it "EVENTUALLY" but who knows when that will actually happen. Keep up the great work you are one to look up to!!!
__________________
The Hulk '93 Explorer 5.5" Superlift, 35x12.50x15 BFG KM2s, 4.56 gears, Eaton E Locker rear, 96 Ranger knuckle and brake swap, Dynomax Turbo Cat Back Exhaust, Front bumper from jamscal with warn xd9000i winch, coming hopefully this year front sas with 4.88 gears and locker in front.
Build Thread/Elite Registry http://www.explorerforum.com/forums/...d.php?t=356278
Bryan
adamsbro2 is offline   Reply With Quote
Old 06-19-2012, 01:26 PM   #83
Suicide77
Salt Lake City, Utah
Suicide77's Avatar
1993 Explorer
Vehicle Specs
(Original Poster)
Thanks for rooting for me man, when I get it done I'll drive it up so we can compare both the lifts. As far as the coil buckets and dual shocks I think they would work good on your super lift kit. Instructions are pretty straight forward and you wouldn't need to remove the axle (although it is nice). Also, maybe when the chevota is up and going or if you have a free weekend we can hit the underside of you truck and do some rust proofing!
Thanks for the heads up man! Definately something I will watch out for! Where did you buy the tap for the threads? Who would carry one that size?
Suicide77 is offline   Reply With Quote
Old 06-19-2012, 01:50 PM   #84
RobertFord
Amsterdam, Netherlands
1991 Ford Explorer XLT
Vehicle Specs
Awesome posts! All the pics are great! Keep up the good work
RobertFord is offline   Reply With Quote
Old 06-19-2012, 10:55 PM   #85
Suicide77
Suicide77's Avatar
1993 Explorer
Vehicle Specs
(Original Poster)
Ok, here's a new one for you guys, and perhaps I will start a second thread just to see if it will generate any more helpful responses. I sheared the transmission mount stud (bolt/rivet?).
Any advice? Does the mount assembly just bolt up and drop out? Any help GREATLY APPRECIATED! At the very least I plan on going to pick an pull tomorrow to try removing the bracket and get a new radius arm stud.
Old 06-20-2012, 02:26 PM   #86
Suicide77
Suicide77's Avatar
1993 Explorer
Vehicle Specs
(Original Poster)
Well ended up being an easy fix! Also, got to kill two birds with one stone while I was there; pulled out an axle stud to replace my rusted to bits one.
Ah, now back to work!
Old 06-21-2012, 01:25 AM   #87
Naasau
Denver Colorado
Naasau's Avatar
'93 Explorer XLT
Vehicle Specs
Nicely done, sir.
__________________
I love my garage art.
Naasau is offline   Reply With Quote
Old 06-21-2012, 01:35 AM   #88
NHarris
Ogden, UT
1998 XLT V6
Vehicle Specs
Good work and easy fix there!
I also like one of the tags "rust."
If you ask me, your truck is pretty darn clean for a 93.
__________________
Nate H
1998 Ford Explorer XLT 4.SLOW Restoration Project - OEM Restoration with larger than stock tires.
2004 Jeep Grand Cherokee Laredo - 3.5" Lift, Quick Disconnects, Rear Locker, Mopar Off Road Package, Gray Moab Wheels, Differential Skid Plates, and much more!
NHarris is offline   Reply With Quote
Old 06-22-2012, 12:00 AM   #89
Naasau
Denver Colorado
Naasau's Avatar
'93 Explorer XLT
Vehicle Specs
Yeah it is. We're all very jealous.
__________________
Old 06-22-2012, 06:54 PM   #90
Suicide77
Suicide77's Avatar
1993 Explorer
Vehicle Specs
(Original Poster)
You guys are too kind! Thanks Again!
Old 06-24-2012, 01:42 AM   #91
Suicide77
Suicide77's Avatar
1993 Explorer
Vehicle Specs
(Original Poster)
Alright, I've got some good news to report today! To start out, I was at the point of needing to mount the radius arm brackets. Well, as always, I saw some rust and decided to take care of it.
...and as always I got a little carried away and just did the whole thing.
Next was getting the brackets perfectly lined up. The instructions said to be 5" back from the body mount. After holding things up and seeing how it would fit, I determined on my truck it would have to be 4 1/2" back to get the transmission mount to line up properly. After C-clamping everything in place it was time to get drilling. I have a regular drill, but with the 1/2" bits being almost 6" long and the drill itself being an additional 8" long I was unable to line it up to any of the holes. The solution: a Milwaukee Right Angle Drill!
And once again, the only thing with this kit is that sections of the frame are double walled and the bolts don't address that. So, I added two bolts on the driver side that were a half inch longer. The passenger side was fine as is. Here in the picture you can see my dilemma.
After drilling it out things lined up nicely. Here is the passenger side bracket.
Finally, after re-measuring and re-measuring we lifted everything in place (with the help of my dad) and torqued everything down to specs (definitely a two man job).
And a close up of the mount.
Hopefully I can finish the passenger side shock mount tomorrow and then start putting it back together!
Old 06-24-2012, 06:14 AM   #92
wood1
North of Ottawa
wood1's Avatar
'93 XLT, Cayman Green RIP
Vehicle Specs
Dude, I can't believe I haven't seen this until now. I am very impressed with your work and your write-up. You are definitely giving this old girl a new lease on life.
Keep up the great work!
__________________
Ribs. I had ribs for lunch, that's why I'm doing this.
List of useful TTB Threads
wood1 is offline   Reply With Quote
Old 06-24-2012, 11:18 AM   #93
adamsbro2
Clearfield, UT
93 XLT
Vehicle Specs
It's looking awesome bro!
__________________
Bryan
Old 06-24-2012, 11:23 AM   #94
Suicide77
Suicide77's Avatar
1993 Explorer
Vehicle Specs
(Original Poster)
Thanks Guys!!!
Old 06-25-2012, 10:33 PM   #95
Suicide77
Suicide77's Avatar
1993 Explorer
Vehicle Specs
(Original Poster)
Well I got some more positive progress done on the Explorer. Tedious, but necessary, was lining up the passenger side shock mount to be right on 5" from the coil bucket. Not a horrific task, but simply put, it is a pain to clamp this little guy in place.
After drilling it out I got the bolts on. Once again I went with grade 8's from the hardware store.
And yes, I know. I plan on repainting and touching up everything that the WD-40 and wrenches mess up Lol. Lastly, I also got the driver side beam bracket put on.
Now I haven't torqued this bracket down yet because I noticed the kit didn't include washers for this bracket. It is set up to go just straight bolt and nut on metal. Does anybody know why??? I kinda want to put washers in there, and there is definitely enough room. Any ideas? Would putting on washers hurt? Thanks Again!
Old 06-26-2012, 11:53 AM   #96
Naasau
Denver Colorado
Naasau's Avatar
'93 Explorer XLT
Vehicle Specs
Nope, Wouldn't hurt a thing. Do it.
As for the shock mount, I forgot to share a secret, I took a thick walled piece of pipe and cut it down to 5", then square on both sides using a lathe, afterwards I tightened it down with the hardware they gave me to the bucket, which gave me a positive lock on its location, then I clamped the bottom to the frame rail and drilled.
... I probably should have mentioned that earlier, sorry.
__________________
Old 06-26-2012, 08:18 PM   #97
Suicide77
Suicide77's Avatar
1993 Explorer
Vehicle Specs
(Original Poster)
Smart man, definitely would have helped :S But I manned up and just measured, measured, measured again, and measured just to be sure. Funny as hell you mentioned this now though, I got a good laugh out of it!
Also, to recall the original question; thanks! I think I will go ahead then and torque it down with the washers. 90 foot pounds alright? I notice everything but the studs and radius arm anchor bolt seem to be 90. Thanks Again!
Old 06-26-2012, 11:07 PM   #98
NHarris
Ogden, UT
1998 XLT V6
Vehicle Specs
Close to being finished yet? I know its a time consuming process...
__________________
Nate H
Old 06-26-2012, 11:13 PM   #99
Naasau
Denver Colorado
Naasau's Avatar
'93 Explorer XLT
Vehicle Specs
I went a bit heavy, and when I upped it to grade 8, I aimed for about 110 ft*lbs.
__________________
Old 06-28-2012, 12:13 AM   #100
Anime
GREEN SCREAM!!
Hattiesburg, MS
Anime's Avatar
'93 Sport 4x4
Vehicle Specs
For whatever it's worth, the rubberized undercoating isn't a very good idea on wheels, or anything else that gets really hot. When that undercoated wheel is mounted, and the brakes are used and the wheel gets hot, that undercoating is going to get real gooey or even runny. At best it will wind up just sticking to the drum/disc it's mounted to making it a hassle to clean off so you can re-mount the clean wheels, at worst it will fly off everywhere and you'll have splatter all over the tire, fenderwell, and maybe even the brakes and bodywork.
I realize the thought behind undercoating a wheel that spends it's time as a spare tire under the back end, but it's just not the right coating for the job if the spare is ever used. It'll certainly be a PITA to remove the undercoating from the wheel, but less work than cleaning up the mess if you want to find out what happens the hard way.
__________________
"I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins
Anime is offline   Reply With Quote
Reply
Tags
2.5 inch, james duff, restoration, rust, Shiny
Similar Threads
Thread Thread Starter Forum Replies Last Post
88 Bronco II + 93 Explorer = Short and powerfull Diff Whack Daddy Offroad Explorer - Ranger Projects 97 11-13-2011 02:49 PM
Top search phrases for this site Rick Suggestion Box - Forum Feedback 11 09-12-2011 09:22 AM
93 explorer check engine light? dalton125 Stock 1991 - 1994 Explorers 6 12-21-2008 07:16 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
