| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#21 | |
Burnaby, BC, Canada
97 Explorer Limited SOHC
Quote:
In terms of 'reviews' which part in my recipe are you referring to? Thanks! __________________ Nate from Vancouver, BC, Canada 1997 Ford Explorer Limited - w/Electronic Air Control 4.0L SOHC / Automatic Transmission Pearl Ivory Paint / Tan Leather Interior 238,000km |
#22 | |
Burnaby, BC, Canada
#23 | |
Burnaby, BC, Canada
Quote:
For the rear, what are ALL the bushings I will need / you would recommend? I bought new leaf springs from a local manufacturer for about $450... saved a TONNE buying direct. The install was easy, but I did take it to a mechanic friend of mine with a hoist in his garage. Probably took an hour all in. The hardest part was hammering out the old screws. Hoist helps, and supports for the axle from what I remember... Hope that helps! So, what are all the bushings??? __________________ Nate from Vancouver, BC, Canada 1997 Ford Explorer Limited - w/Electronic Air Control 4.0L SOHC / Automatic Transmission Pearl Ivory Paint / Tan Leather Interior 238,000km |
#24 | |
Wannabe Elite Explorer
Newport News, VA
2001 V8 (Eddie Bauer) AWD
Quote:
The fifth just controls the rear sway, I think it doesn't need to be monotube (or variable valving). |
#25 | |
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Quote:
giving you less articulation. That's the primary reason off road setups use disconnects or remove the sway bars entirely. As for less body roll, that's the biggest benefit with reduced bump steer. Regarding reviews, I was referring to Addco or Explorer Express sway bars having a huge following. |
#26 |
Burnaby, BC, Canada
That 36mm one is the 5th shock.
#27 |
Harold Tellefsen
McHenry, IL
1996 Eddie Bauer AWD V8
I have had the sensa-traks on my Explorer for just over 2 weeks, and LOVE them. they really showed me how bad my old one where. no longer am I bouncing for seemingly ever after going over a bump.
__________________ Martha, My 1996 Ford Explorer Eddie Bauer Edition Upgrades coming along nicely... -Alpine stereo, with Alpine Doorspeakers and MTX Subs -15x7 Cragar Soft 8's, On Hankook 235/75R15 Tires -Upgraded CB Radio soon(Radio Shack Special now) -POR 15 undercoat(Summer Project) |
#28 |
Burnaby, BC, Canada
Do you carry weight? Or is it typically just you in the truck? Most reviews i've seen say that they can be soft... perhaps 2 weeks isnt enough time to 'settle in'.
#29 |
Knoxville, TN
98 Mountaineer A4WD
Sway bars are usually only noticed or felt in corners, that's their purpose. So in normal driving where you contact any bumps equally left/right, the sway bars have no affect on ride etc. When you sometimes hit a bump with one tire alone, such as turning sharp into a parking lot that has a step up into it, the front suspension will feel stiffer for that moment that the one tire is forced upward, with a stiffer front bar. That is the only time you will notice a stiffer ride with bigger bar sizes, besides off roading as mentioned.
The Bilsteins are available in two versions, which differ in how stiff they are in each direction(jounce/rebound). I chose the one best for a lower vehicle, they resist down(jounce) more. That makes them feel a bit stiffer than the other version, but they are also less likely to bottom out(given the shorter travel available down). I would call these "strong" shocks, good and firm, and I have really never bottomed out with them. I've only used them for a couple of years, the truck is rarely driven since 2005, but I like them better than the Edelbrock IAS shocks I had. __________________ Don 91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior. The best thing that could help us all, is the Fair Tax Plan. Be American, Buy American (Manufacturer)
#30 | |
Knoxville, TN
98 Mountaineer A4WD
Quote:
I had those tires last, in 265/60/18's, I didn't like them much. They didn't grip well in rain and didn't impress me for general handling. I chose them based on reviews for those things. Now I have Pirelli's, 255/60/18's, which are much better for me. I was impressed on one day when I found snow on the roads going to work 21 miles. I drove faster than I should have given snow, I was late, and it fortunately never slipped. I own dedicated snow wheels/tires for bad conditions. If you did replace all of the front suspension, then you already took care of the bushings on the control arms. Those are the most important. The sway bar bushings are next to renew or stiffen up with urethane. I suggested waiting on the front bar because each bar takes a different frame bushing, plus the Addco bar needs a different frame bushing bracket than what they supply. It took me a while to get my preferred machine shop to make some for me. __________________ Don 91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior. The best thing that could help us all, is the Fair Tax Plan. Be American, Buy American (Manufacturer)
#31 | |
Burnaby, BC, Canada
Quote:
don, which ones exactly did you buy??? Are these 'heavier' options the B6 46mm? > With intended use for motor homes? Need clarity..... When I visit the Essex Distributor site and enter the vehicle info (YEAR, MAKE, MODEL) I do get 2 options, but one is described as for use with a 2wd, the other with 4wd or awd. http://www.bilsteincanada.com/ Heavy Duty Series (B36-2135-H0) Axle Wrap Rear (24-021357) Heavy Duty Series (B46-2131-H0) 2wd Front (24-021319) Heavy Duty Series (B46-2132-H0) 2wd Rear (24-021326) Heavy Duty Series (B46-2133-H0) 4wd Front (24-021333) Heavy Duty Series (B46-2134-H0) 4wd Rear (24-021340) __________________ Nate from Vancouver, BC, Canada 1997 Ford Explorer Limited - w/Electronic Air Control 4.0L SOHC / Automatic Transmission Pearl Ivory Paint / Tan Leather Interior 238,000km |
#32 | |
Burnaby, BC, Canada
Quote:
I'm certain we did the upper control arms. We did not 'replace' the lower control arms, but im certain we did replace the ball joint on them... hmmmmmm... have to check on that. I actually do have a clunk on the front still under/near the drivers foot. Most times it sound like something is 'flexing'... like a snapple bottle cap... gives and pops back. Anyone else have this issue? __________________ Nate from Vancouver, BC, Canada 1997 Ford Explorer Limited - w/Electronic Air Control 4.0L SOHC / Automatic Transmission Pearl Ivory Paint / Tan Leather Interior 238,000km |
#33 |
Knoxville, TN
98 Mountaineer A4WD
Oops, the tires, I mixed up what you have with my two trucks. I meant the 18's I had first on my Mountaineer, those were Yokohama G52's IIRC. I have the 245/70/16 General UHP's on my 99 truck, they are better than the Yokohamas were for grip. I wouldn't avoid the General tires, they are close to what reviews suggested I think. They aren't great in the rain, but not bad like I would describe the Yokohama tires I had.
#34 |
Knoxville, TN
98 Mountaineer A4WD
I had to call Bilstein to clarify which shocks were best for a lowered truck, the descriptions didn't help.
I still have one rear shock unused, because I couldn't remove one of the shock mounting bolts. I can check that box for the model number shortly, if it isn't visible below. It isn't in this picture or others not re-sized. I have a bigger one that shows the RF shock, it's a 2133 for sure. __________________ Don 91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior. The best thing that could help us all, is the Fair Tax Plan. Be American, Buy American (Manufacturer)
#35 |
Knoxville, TN
98 Mountaineer A4WD
Since you have a 1997 truck, check the torsion keys. From 1995-97, those had a kevlar wear pad built onto them. Those wear out, and result in a creaking or clunking. In 1998, the frame portion was revised and included an insulator device, similar to a large piece of urethane. Below shows my 1999 key and the insulator part above it.
#36 | |
Kailua-Oahu, Hawaii
Quote:
Also check the #2 drivers side body mount. Better yet, check them all. |
#37 |
Harold Tellefsen
McHenry, IL
Right now I have 6 24 packs of water, and 2 12" subs, along with more misc. stuff. it has quite a bit of weight. Also cornering has gotten better too. like today after a run in with a road raged driver I made a corner at 45 mph, and the shocks held it up real nice, although, now I am thinking of a better sway bar.
#38 |
Knoxville, TN
98 Mountaineer A4WD
I discovered that something was worn out in my 99 truck going through a corner at 60mph+. It was scary that night, for a 45mph zone that is usually safe to do at 60mph. The back end hopped around badly. I don't usually push the truck, or trucks, but sometimes it's fun. The next day I discovered one rear end link bushing virtually gone, and the other side very loose.
Check the end link bushings regularly. __________________ Don 91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior. The best thing that could help us all, is the Fair Tax Plan. Be American, Buy American (Manufacturer)
#39 |
Burnaby, BC, Canada
Don is your vehicle lowered?
#40 |
Knoxville, TN
98 Mountaineer A4WD
Yes, I began with the EE kit($800 or so), which is 1.375" down in the back with the EE blocks. I later lowered it more in the front, just before buying new tires. I ended up a good 2" lower in front at least.
Not every Explorer is the same though, my 99 truck doesn't seem to be able to get as low. The front alignment didn't do well with it lowered like I wanted it, so it's a good bit higher than my 98. This 99 is a 4WD, not ARC, so it has stiff leaf springs. I added 1" lowering blocks to it and adjusted the ARC height sensor. __________________ Don 91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior. The best thing that could help us all, is the Fair Tax Plan. Be American, Buy American (Manufacturer)
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Need opinion on shocks for 95 Limited... | spotdog14 | Stock 1995 - 2001 Explorers | 22 | 12-11-2012 05:24 PM |
| I screwed up & bought Sensa-Trac shocks | Kamaaina | Stock 1995 - 2001 Explorers | 11 | 09-01-2008 11:43 PM |
| ARC monroe replacement shocks equivalent to 'normal' or 'offroad' setting? 98 5.0 | Riken | Stock 1995 - 2001 Explorers | 6 | 10-25-2007 08:46 PM |
| Shocks with SOA | Limited Ex | Explorer - Ranger Shocks, Suspensions, Lift Kits | 11 | 03-28-2003 07:46 PM |
| Thread Tools | |
