#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
rough idle, loss of power under acceleration
Reply
Thread Tools
Old 04-29-2012, 08:43 PM   #1
SPLplorer
Strasburg VA
97 explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
so this issue has been going on for 2 months now, im having an intermittent miss, it will have loss of power under acceleration and going up hills and when i really give it gas to get going it just hesitates and you can hear the exhaust making a type of hissing noise but its not a constant hissing more like a rapid hissing, then it will run fine at other times, ive replaced the coil pack and changed my intake manifold because it seemed like a vacuum leak but that didnt help and i also did a current ramp on my fuel pump and it was ok and i juss changed my plugs, wires, and fuel pump about 10,000 miles ago also there are 2 DTC's they are p0103 and p0105 which are cylinder 3 and 5 misfire, please help
p.s. im starting to wonder if i have clogged cats because at start up there is a really bad rattle that sounds like its coming from the cats and today i smelled the rotten egg smell when it was missing while i was trying to get on the highway
SPLplorer is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-30-2012, 09:31 PM   #2
SPLplorer
Strasburg VA
97 explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
bump
Old 04-30-2012, 10:22 PM   #3
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Vehicle Specs
Quoted: 865 Post(s)
You did mean p0301 and p0501, correct?
I would double check those two plugs and wires.
swshawaii is offline   Reply With Quote
Old 05-01-2012, 09:55 PM   #4
SPLplorer
Strasburg VA
97 explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
yah i got the numbers and letters mixed up but it ran fine for like 8 months so how could they already be bad?
Old 05-01-2012, 09:57 PM   #5
swshawaii
Kailua-Oahu, Hawaii
Vehicle Specs
Quoted: 865 Post(s)
Quote:
Damaged or cracked ceramic, improperly gapped, mixed wires, etc.
Did you use Motorcraft or Autolite plugs at the recommended gap?
Old 05-01-2012, 10:39 PM   #6
SPLplorer
Strasburg VA
97 explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
yes i used motorcraft and gapped them but this seems more like a fuel delivery issue to me than spark related because it is very intermittent
Old 05-02-2012, 01:05 AM   #7
swshawaii
Kailua-Oahu, Hawaii
Vehicle Specs
Quoted: 865 Post(s)
Quote:
P0301 through P0310 - Misfire Detection Monitor The misfire detection monitor is designed to monitor engine misfire and identify the specific cylinder in which the misfire has occurred
Oops, I meant p0301 and p0305. Just seems to be the first logical step to check #1 and #5 plugs and wires.
Easy enough to pull, unlike the PITA rear passenger #3 plug. Better than just throwing in parts like injectors. GL
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rough Idle, Lack of power and shaking while driving d3ath101 Stock 1995 - 2001 Explorers 3 11-20-2011 06:31 PM
94 explorer,, rough idle cold,???? siTTinLo420 Stock 1991 - 1994 Explorers 26 10-10-2010 01:09 AM
P0420 and Power Loss kevthexplorer Stock 2002 - 2005 Explorers 0 01-12-2010 05:20 PM
Rough Running, both cold & warm, both idle & under power motopsycho650 Stock 1991 - 1994 Explorers 18 02-24-2009 09:49 AM
Loss of Power and rough idle hilliad Under the Hood 2 05-30-2007 02:29 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
