Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
longer tortion bolts
Reply
Thread Tools
Old 04-29-2012, 08:57 PM   #1
01Strac
Bainbridge Georgia
2001 Sport Trac
Vehicle Specs
(Original Poster)
I was wondering how much more lift can i get if i got the longer tortion bar bolts
__________________
My Registry
01Strac is offline   Reply With Quote
Old 04-29-2012, 09:16 PM   #2
MidnightRebel07
Pittsburgh, Pa.
MidnightRebel07's Avatar
2003 Explorer Sport Trac
Vehicle Specs
Longer TB bolts are really just for when your factory TB bolts are maxed out and or your TB's are worn out and sagging. TT rules with longer TB bolts still apply for IFS, you only wanna do 3" (2wd) and 2" (4wd). You can get them from Todd Z. at Zabteck.com, he also runs the www.mysporttrac.com site.
__________________
"If you're gonna be a bear, Be A Grizzly"
1.75" TT, WP shackles, 3" BL, 33x12.5x15 DuraTrac's, 15x8 Cragar's, RT Y-pipe, RT High Flow Cat, MagnaFlow 2.5" in/ dual 2.5" out, 2.5" dual pipes, LiveWires, K&N air filter, Uniden C.B., Pioneer H.U., MTX sub, Gen2 Ex dash bezel swap, Amber l.e.d. clearence lights, Custom Built Swing Out Tire Carrier and bumper (my build),custom Winch bumper w/ 12k lb. winch, A.R.E. Cap
MidnightRebel07 is online now   Reply With Quote
Old 04-30-2012, 06:26 AM   #3
01Strac
Bainbridge Georgia
2001 Sport Trac
Vehicle Specs
(Original Poster)
thanks i wasnt sure on that cause i got 3 out of mine but wanted a few more inches
__________________
My Registry
Old 04-30-2012, 12:52 PM   #4
soon2bsick
florida
2000 mountaineer
Vehicle Specs
I ordered mine from zabteck, Will be installing them on my 2wd this week. I don't have the tt done yet but I figured it wouldn't hurt to go ahead and get the longer bolts
__________________
HEB 11:1
soon2bsick is offline   Reply With Quote
Old 04-30-2012, 08:43 PM   #5
MidnightRebel07
Pittsburgh, Pa.
Vehicle Specs
soon2bsick, you'll wanna cut them down some and round off the tops so they sit in the torsion key cups. I have a set and will be installing them soon to regain my TT lif, my TB's are sagging bad.
Just make sure you measure before you remove the bolts and after the new set are installed so you know how much lift you get.
__________________
Old 04-30-2012, 09:43 PM   #6
soon2bsick
florida
2000 mountaineer
Vehicle Specs
any idea how much to cut down?
__________________
HEB 11:1
Old 04-30-2012, 10:37 PM   #7
MidnightRebel07
Pittsburgh, Pa.
Vehicle Specs
When you take your old set out, cut the new ones down to about 1/2-1" longer then the old ones. This will give you plenty of bolt but not too long so their sticking way below the TB brackets.
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
I'm buying used Warrior Products lift shackles, no bolts. What size are the bolts? MidnightRebel07 Explorer - Ranger Shocks, Suspensions, Lift Kits 4 05-31-2011 10:11 PM
Where do you guys get grade 10.9 bolts? dcdyd Stock 1995 - 2001 Explorers 16 04-04-2011 07:21 PM
I have a BAD LEAK (coolant)need to know name of part where the leak is coming from. PriestMacGregor Under the Hood 3 03-21-2010 11:34 AM
Longer bolts For TT jfman Modified 1995-2001 Explorers 18 06-27-2006 05:00 AM
tortion bolts 00exploder Seriously Lowered Explorer - Ranger Suspension Tech 2 08-04-2003 05:58 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
