Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
Yearly ball joint replacement from torsion twist
Reply
Thread Tools
Old 05-03-2012, 07:49 PM   #1
hopsing-nh
Gorham, NH
2004 Explorer Sport Trac
Vehicle Specs
(Original Poster)
Am I just the only one who is replacing ball joints yearly due to my torsion twist? I have a 2004 Sport Trac 4X4 and in 2009 I had the torsion twist/shackle combo done. I kept the stock rims and put Nokia Vativa 285/75 R 16 tires on. Yeah, I rub a bit on tight corners but every year I replace either uppper or lower ball joints and control arms. Its getting very tiring and I am now considering changing it back and going with either a body lift or suspension lift. I do not go off roading - just road miles being put on. Thoughts? Suggestions?
hopsing-nh is offline   Reply With Quote
Old 05-03-2012, 10:11 PM   #2
MidnightRebel07
Pittsburgh, Pa.
MidnightRebel07's Avatar
2003 Explorer Sport Trac
Vehicle Specs
First question I gotta ask is how much TT did you have done? Any more than 2" and it'll chew up suspension and steering parts. Putting the front back to stock height and installing a 3" BL will clear the 285's. Any other suspension lift for the weak IFS setup will chew thru parts as well if not faster. The only true way to solve this issue is to do a Solid Axle Swap up front.
__________________
"If you're gonna be a bear, Be A Grizzly"
1.75" TT, WP shackles, 3" BL, 33x12.5x15 DuraTrac's, 15x8 Cragar's, RT Y-pipe, RT High Flow Cat, MagnaFlow 2.5" in/ dual 2.5" out, 2.5" dual pipes, LiveWires, K&N air filter, Uniden C.B., Pioneer H.U., MTX sub, Gen2 Ex dash bezel swap, Amber l.e.d. clearence lights, Custom Built Swing Out Tire Carrier and bumper (my build),custom Winch bumper w/ 12k lb. winch, A.R.E. Cap
MidnightRebel07 is offline   Reply With Quote
Old 05-04-2012, 09:29 AM   #3
JohnnyO
Sport Trac Moderator
Pittsburgh, PA
JohnnyO's Avatar
'08 Sport Trac
Vehicle Specs
1) Keep the torsion twist to 1.5" to 2".
2) The ball joints will crap out whether you have done a TT or not.
__________________
'08 Sport Trac, Gibson exhaust, K&N, Firestone Destination A/T's, Steelers regalia.
"It is not the multitude of ale-houses that occasions a general disposition to drunkenness among the common people; but that disposition arising from other causes necessarily gives employment to a multitude of ale-houses." -- Adam Smith, 1776
JohnnyO is offline   Reply With Quote
Old 05-04-2012, 09:37 AM   #4
colintrax
Georgia
97 XLT and 91 Ranger
Vehicle Specs
^ they shouldn't go bad yearly though. Replaced the originals around 120,xxx and I've got 155,xxx now with the uppers only having ripped boots (that's what I get for buying the cheapest ones I could)
And I slam into a lot of curbs, speed bumps, ect. Although I only have about 1.5" of tt lift and I run 30x9.5x15 tires.
colintrax is offline   Reply With Quote
Old 05-04-2012, 10:01 AM   #5
hopsing-nh
Gorham, NH
Vehicle Specs
(Original Poster)
Hmmmm....Now I am starting to wonder how much my mechanic tweaked them. It was supposed to be 2" torsion and 2" shackles. But then again, living here in northern NH, the yearly potholes and frost heaves will drive any front end mad! Luckily the ball joints have a lifetime warranty so I just have to pay for labor. Thank you for all of the advice. I will consider the 3" body lift and going back to stock height on the front.
Old 05-04-2012, 10:04 AM   #6
MidnightRebel07
Pittsburgh, Pa.
Vehicle Specs
Go to Harbor Freight and get their Ball Joint Tool kit, their pretty easy to do and will save you tons of money.
__________________
Old 05-04-2012, 10:09 AM   #7
colintrax
Georgia
Vehicle Specs
You can just borrow it from auto zone
Old 05-04-2012, 10:25 AM   #8
hopsing-nh
Gorham, NH
Vehicle Specs
(Original Poster)
Nifty tool! As far as Auto Zone...I think the nearest one is about 2 hours away!
Old 05-04-2012, 11:16 AM   #9
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Vehicle Specs
The lower ball joints may not fit tight in the LCA after so many changes.
Oversized lowers may be something to consider. Press them in, no hammer.
http://www.moogproblemsolver.com/_pd...695T006_En.pdf
swshawaii is offline   Reply With Quote
Old 05-04-2012, 01:49 PM   #10
JohnnyO
Pittsburgh, PA
JohnnyO's Avatar
'08 Sport Trac
Vehicle Specs
Cool
When I had my '02 Ranger I had the ball joints replaced on the original 3/36 warranty before I did a TT on it. When I had my '05 Sport Trac I did a TT/shackle lift almost immediately after buying it and had the right side (only) ball joints replaced on the 3/36 warranty also. You'd think both sides of the truck would have the same number of miles.
Just sayin'.
__________________
Old 05-30-2012, 05:48 AM   #11
Bronco89
Cleveland Ohio
98 Explorer
Vehicle Specs
Quote:
Just sayin'.
Look at roadways though, in the parts of the U.S. that have bad winters, most potholes are in the right hand lane, closer to the curb. Thats why in the winter if its a two lane road, I'll hangout in the left lane. Just a tip.
__________________
Currently Serving In Afghanistan.
Bronco89 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
*Help* Upper Rear Ball Joint dpost01 Stock 2002 - 2005 Explorers 1 04-03-2011 05:06 PM
Help, Lower ball joint replacement Snowman08 Stock 2002 - 2005 Explorers 2 10-22-2008 08:16 PM
Help, Lower ball joint replacement Snowman08 New Member Forum 2 10-22-2008 07:37 PM
Front axle replacement and upper Ball joint jspbtown Under the Hood 0 04-26-2005 09:51 AM
ball joint replacement Sport Trac 1 Explorer - Ranger Shocks, Suspensions, Lift Kits 5 07-30-2003 09:03 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
