| Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Ontario
2012
Got My Recall Notice for Cooling Fans..
I received a recall notice for the cooling fan issue recently, gonna have to book a half-day to have it checked out. I've driven 30k kms already and never noticed a problem. The notice talks about corrosion on the switches, given I drive in winter salted roads I think I'm a good candidate for the problem. I'm glad to get this checked out before I go on my summer road trip to the southern U.S. .
I always set my dash display to show the engine temp gauge. Is there any way to get the dash display to stay in one position after setting it instead of it changing every time I shut down the truck ?. Between that and having to select the radio selection on the other side of the dash each time I get into the car it gets to be a bit of an irritation. I wish it would just remember the last setting and leave it like that if it had some kind of memory feature. |
#2 |
VanBC/GoodyearAZ
2013 X Limited 4WD
It is supposed to hold the memory settings when you shut it off but MFT issues are effecting that too.
__________________ 2013 X Limited 4WD 302A Rapid Spec, Luxury Seat & Technology Package, Tuxedo Black, Charcoal Interior, 20"Polished Aluminum Wheels,Navigation, Dual Panel Moonroof, 2nd Row Buckets & Console, OEM Invision LT Series DVD, Tow Package, Inflatable Seatbelts, 28% Tint Fronts, Husky Liners, OEM Bumper Protector, NuSheild,
#3 | |
Toyota Highlander Convert
Ottawa, Ontario area
2011 Limited AWD
Quote:
One thing I noticed now is that after I using Max A/C, the temperature settings revert to Lo and have to be reset. Didn't notice that before. Sgt1411 is correct in that the setting you chose before shut down should be retained. Peter __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#4 |
monmouth, NJ
'11 Limited
isn't there an option on the left side cluster that you have to put on? i think its memory- on/off. (I'm not in my car, sorry)
#5 | |
2011 Limited AWD
Quote:
Not really sure if it controls last settings. I just looked it up in the manual. By the very definition, it seems to have to do with the Menu. I believe when mine was on Standard, the vehicle still held the selected radio stations, etc. Peter. __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#6 | |
monmouth, NJ
'11 Limited
Quote:
#7 |
2012 Explorer Limited
I thought this service bulletin was only for the early 2011's, but I just got the letter for my late 2012. So they're covering all model years?
#8 |
Fairfield, Ca
2012 AWD Limited
Received mine also, ours is a second week 2012 build, weird
__________________ 2012 Limited EX. Tri-White plat. Dual panel sun roof, 302a package, bliss, pecan interior, 20" polished aluminum wheels, tow package, cross rails for roof rack, Aries Stainlees Nerf bars, upgraded LED interior lighting.
#9 |
Gainesville, FL
12 EXP LTD
Got mine Florida.
#10 |
Spring, TX
2013 Explorer Limited
Sounds like they are expanding the scope of this TSB/Recall/Whatever-the-heck-it-is.
__________________ We just bought American! ![]() She got the 2013 Ex Meet the Gray Ghost HERE Check out the Gray Ghost on Fuelly.com Average Mileage: 21.3 Best Tank: 26.5 |
#11 |
Fairbanks, AK
2012 XLT Ex
Mine is 11/23/2012 build and I got it done. I must say - it changes things. The MFT is WAY more reliable and honestly, I've been afraid to say anything but...I swear the shift points and acceleration are better. It didn't used to 'feel' faster than my 02 4.0 ranger. I drove the p/u while the Ex was in the shop that day and when I got back in the Ex, I was actually surprised to 'feel' it perform better. Maybe I am crazy (as I've always suspected). Anyone esle notice something like this? I wish I had data to back it up but I am quite in tune to the vehicles I drive, but still all I got is my 'feelings' on the subject. Lol
#12 | |
2011 Limited AWD
#13 |
Fairbanks, AK
2012 XLT Ex
Sorry. Two seperate issues, you're right. My service writer was calling it the same thing and I guess, even knowing better, sorta kept that theme alive. To calrify, the MFT update worked wonderfully and the PCM reprogram from 12B36 seemed to have changed shift points etc. I know they "said" it was only the cooling fan issue so I wasn't expecting anything else, but the performance was noticeably different and I can't help but think they took the opportunity to "hide" other needed changes in the reprogram. I mean, I'm no electrical engineer, but changing the fan cycle rate and speed to keep contacts clean? Call me skeptical but that seems funny to me...
#14 | |
2011 Limited AWD
#15 |
Fairfield, Ca
2012 AWD Limited
Mine was completed Friday, don't notice any shift point changes or performance gains. Did notice fans stay on about 5 to 7 seconds longer after vehicle is turned off?
#16 |
Ontario
2012
a pcm re-program was part of the service bulletin/recall , I haven't noticed anything different, one of my complaints has been the slow response to downshift at highway speeds but I'll see if anything has changed on that front, I doubt it has though.
My service advisor said they changed the amount of time the fans would run as they were burning out from running too long. But then again he will pretty much say anything off the top of his head and I never really believe anything he ever tells me that is technical related, nice guy but I don't think he really knows much. |
#17 | |
2011 Limited AWD
#18 | |
Ontario
2012
Quote:
#19 |
Neenah, WI
1998
how do find out if you have a recall on your truck!
#20 |
2011 Limited AWD
Hi ford tonya1975, welcome to the Forum.
![]() Are talking about a 2011 to 2013 model? If so, there is a list of TSBs for them at the beginning of the threads. To my knowledge there are no actual 'recalls' for them but there are updates for the MFT and the cooling fans. If you are asking about another model year, you should pose your question on the appropriate thread. Your dealer should also be able to check for recalls. Peter __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Electric fans Mark VII, Ramcharger-Taurus--Explorer bracket kits available also-- | Turdle | Need for Speed! | 245 | 11-16-2012 08:09 AM |
| I got a firestone recall notice | Jason94sport | Ford Explorer - Ranger Tires & Wheels | 8 | 11-16-2006 10:56 PM |
| FYI: KUMHO recall Venture HT and AT light truck tires | toypaseo | Ford Explorer - Ranger Tires & Wheels | 0 | 08-02-2006 06:41 PM |
| Ignition Recall? | timfretwell | Under the Hood | 5 | 08-17-2001 11:50 AM |
| Recall from 1/2001 reflashed PCM question | F350 Dually | Under the Hood | 1 | 07-16-2001 12:40 PM |
| Thread Tools | |
