| Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Cologne, Germany
'07 Eddie Bauer 4x4
Brake caliper bleeder valve ripped off
Dear @all,
yesterday I wanted to sevice the brake fluid on our '07 EB. Unfortunately I ripped off a bleeder valve of a rear caliper. Head with hexagon is ripped off, valve itself is still in the caliper. No ridge to use a vice or similar. Away from ordering a new caliper, is there a process to get the damaged valve out? What is the dimension of the new valve? Thank you for your help! __________________ Joachim 07 Explorer Eddie Bauer 4x4 02 Explorer XLS M/T 4x2 95 Mustang 5.0 GT Convertible 82 Corvette Coupe 67 Mustang 289 M/T Convertible |
#2 |
Rockland County, NY
2006EB,V8, Fisher plow
Sorry I do not have the size answer, but you are not the first one breaking them off. They tend to snap off.
Check this: http://www.ehow.com/how_5908178_remo...e-bleeder.html http://ls1tech.com/forums/suspension...e-caliper.html |
#3 |
Topeka, KS
00 V8 Mountaineer
At $35-$40 for a new caliper I would just order a new one.
#4 |
Aerostar Forum Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Use an easy out bolt & screw extractor.
#5 |
The Big City of Orange City, Florida
97,03 explorer 07 mounty
yes easy out or left hand drill bit it might spin out.
#6 |
Cologne, Germany
'07 Eddie Bauer 4x4
Thank you guys for reply.
Yes, my first idea was to order me a new caliper, just a $50 affair. I checked RockAuto and found out rear calipers are the same from '01 to '10. Fortunately I do have a rear right caliper in stock for our '02 Explorer. They seem to be identical. But... the threads taped into the housing for bleeder valve and brake line are different. Whereas the '02 caliper has 3/8" UNF theard the '07 caliper is metric, 10mm. So I'm going to get me some metric 10mm bleeder valves and try to screw the ripped-off out after soaking in penetrating oil for some days. __________________ Joachim 07 Explorer Eddie Bauer 4x4 02 Explorer XLS M/T 4x2 95 Mustang 5.0 GT Convertible 82 Corvette Coupe 67 Mustang 289 M/T Convertible |
#7 |
Elite Canuck, Eh ??
In the Great White North where winter never seems to end ,Ontario,, still ice fishing,,
96xl,99xls,old Rangers
there is an easy way, just get a drill bit that fits in the hole, make sure the hole is completely clean with that bit.
than step up just a bit bigger but not as big as the threads, and drill it again, as the metal thins you may be able to use a slot screwdriver that fits in the hole to spin it out as the heat from drilling will loosen it, just make sure your bit is in the middle,, __________________ Log Roller,, Fox Coilovers 35's and others, , Truck of the month Ranger Of Danger,,,project truck, also look for Blues Traveller Elite registry, , |
#8 |
Brooklyn, NY
These bits go into a drill:
![]() You set the drill to reverse, then the bit will drill into the bleeder until the easy out part grabs the bleeder. Here's another extractor: You drill a hole into the bleeder, then tap the extractor into the hole. A wrench or a socket turns the extractor with the bleeder. Here's another extractor set: ![]() A drill bit drills the hole, then the spiral extractor grabs the bleeder. |
#9 |
Torsion Bar Free
since 2010
94 XLT-95 FX4
BB, I need to get me a set of those Pro-Grabit! Those look very handy indeed.
#10 |
Brooklyn, NY
Sears sells their own version of them. Check Lowe's & Home Depot as well. The first time I've used one of these bits was on a Craftsman planer. One of the screws holding the blade was stripped, and I couldn't remove it. It was an Allen head bolt. The tool zipped right into it, and removed it in no time.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to change your 2005 V6's PCV Valve | High_Order1 | Stock 2002 - 2005 Explorers | 8 | 02-03-2013 04:10 PM |
| A4LD Valve Body Rebuild Journal - Reassembly (w/pics) | TN_Explorer | Explorer & Ranger Transmissions, Transfer Cases, & Differentials | 28 | 04-12-2011 11:38 PM |
| 96 5.0L P0402 but no DPFE Sensor? | cbr rob | Stock 1995 - 2001 Explorers | 31 | 09-02-2010 08:32 PM |
| Warning!! "Dorman Disc Brake Caliper Bracket" does not fit | bkmc24 | Stock 1995 - 2001 Explorers | 2 | 03-07-2010 12:02 PM |
| Brake Caliper slider Pins | Icepick2010 | Stock 2002 - 2005 Explorers | 8 | 02-18-2010 05:24 PM |
| Thread Tools | |
