Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Champion 7989 sparkplug failure.
Reply
Thread Tools
Old 05-08-2012, 08:55 AM   #1
Explorer_PL
Rockland County, NY
2006EB,V8, Fisher plow
Vehicle Specs
(Original Poster)
Brief recap of events:
At around 99k miles I developed a miss, that got progressively worse, and at around 101k miles I replaced all 8. 7 came out ok, with screeching and noises. 1 broke in 3 pieces, and I had to drill and tap the head. Installed Champions 7989, and coated them with nickel anti-sieze.
Last month at around 132k miles, I pulled them all out and recoated them again (most of it was gone). All was good for about 3 weeks or so. Yesterday, I went to work and back just driving on 7 cylinders. Found # 4 cylinder not working. Swapped the plug and the coil to # 2, and #4 was ok now, # 2 was missing so I knew it has to be either coil or plug. I still had the original plugs in the garage, so i just screw in the old Motorcraft, and it's fine.
This morning while driving to work, ocasionaly it would miss just a little, so either the old Motorctaft is missing, or another Champion is on its last leg.
I decided to replace all 8 again, and will go with Motorcraft.
Can I use Motorcraft SP515 ?
Nor realy happy with Champions lasting only 32k miles.
Explorer_PL is offline   Reply With Quote
Old 05-09-2012, 07:50 AM   #2
feetwet
Maple Grove, MN
2006 XLT V8
Vehicle Specs
Seems like overkill to replace all 8 again.
I had one 7989 that had a hairline crack in the porcelain that caused a misfire, but that was in a brand new plug, not one that had been working for while.
You might want to swap just the coil to another cylinder
feetwet is offline   Reply With Quote
Old 05-09-2012, 08:39 AM   #3
Explorer_PL
Rockland County, NY
Vehicle Specs
(Original Poster)
I swapped both plug and coil. It was still missing, now on #2. So I replaced the 7989 with the original Autolite HT1 that I still had in the garage with 99k miles on it. It got to about 95% good, just ocasional misfire uphill, so I knew the coil was OK, the plug was the issue.
Since I do about 80-100 miles a day, i could not wait, and last night I bought 8 Autolites HT1 at Autozone. Total $103 less 20 rebate. Ebay had same prices. This morning before work I replaced #1 and #2 plugs (took me 10 minutes, I am getting good at it ), and drove about 40 miles and absolutely no misfire. Will replace the rmaining 6 in the next few days. Did not coat it with anything, as I am planning to unscrew them every 20k miles anyway.
Old 05-15-2012, 09:24 AM   #4
Explorer_PL
Rockland County, NY
Vehicle Specs
(Original Poster)
Update -
over the weekend I replaced the remaining 6 plugs with the Autolites. Drove about 200 miles so far and not a single miss, waaaaaaay much better than driving with Champions (sorry Champion). Before, any attempt to pass a vehicle on the highway, or going uphill would produce a bucking and miss, and eventualy CEL light. I gueass Champions are not made for Fords.
Old 05-15-2012, 09:31 AM   #5
feetwet
Maple Grove, MN
2006 XLT V8
Vehicle Specs
The only time my Champions produced a misfire was when I had a hairline crack in the porcelain on one plug. Once I got a significant enough misfire to register an OBDII fault and determine which cylinder was missing... I replaced my cracked plug, since then, they have been great.
If that was the case with yours, perhaps Champion needs to work on their packaging/handling/testing to prevent cracked plugs from getting to consumers.
Old 05-15-2012, 10:21 AM   #6
Explorer_PL
Rockland County, NY
Vehicle Specs
(Original Poster)
Not sure if I had any cracks, the one that was at fault had the porcelain part much darker. So far so good.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Harmonic balancer failure 2000StreetRod Under the Hood 30 07-18-2012 02:24 PM
EEC-IV 2 and 3 digit trouble codes. BrooklynBay EEC IV 16 03-26-2012 09:46 PM
List of codes, conditions, and what they mean. Blacksheep Josh Stock 1991 - 1994 Explorers 7 02-21-2012 08:52 PM
Need Information on CHAMPION 7989 replacement plugs dxgmmpa Stock 2006 -2010 Explorers 3 11-14-2011 11:49 PM
ford manufacturer specific codes whale45714 Stock 1995 - 2001 Explorers 0 04-16-2011 10:03 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
