Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
disable anti-theft tsystem
Reply
Thread Tools
Old 05-08-2012, 01:12 PM   #1
Sarajevo
2001 Ford Explorer E.B.
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
My 2001 explorer eddie bauer is having some issues. Sometimes the key will not turn in the ignition. It just gets stuck. Other times the key will turn and so will the starter. But at the same time there is no ignition. This is clearly the antitheft system malfunctioning. How do i disable the system permanently so that i can install a non-coded ignition key cylinder (switch)? Thanks
Sarajevo is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-08-2012, 03:53 PM   #2
Blee1099
Evil Asian
Elkridge, MD
Blee1099's Avatar
91
Vehicle Specs
Quoted: 10 Post(s)
If the key won't sometimes turn then its not really the anti-theft. The PATS will just prevent the engine from getting fuel/spark if a coded key isn't recognized in the ignition. Could the actual ignition switch itself. You could try some graphite in the ignition and see if that helps. You could also try spraying the ignition with wd-40 or similar with the red straw until stuff starts flowing out of the ignition. Once thats dry, put some graphite or tri-flow in there. The idea of using graphite or tri-flow is to use something dry that won't gunk up in the column.
Blee1099 is offline   Reply With Quote
Old 05-08-2012, 04:39 PM   #3
my98nnj
Boonton, New Jersey
1998 XLT
Vehicle Specs
Quoted: 71 Post(s)
The anti theft system has nothing to do with your key not turning.
What is the theft light doing when a crank with no start condition exists?
my98nnj is offline   Reply With Quote
Old 05-08-2012, 09:32 PM   #4
deweyville65
Dewey,Az
96 EXPLORER XLT
Vehicle Specs
Quoted: 30 Post(s)
Quote:
Isn't graphite an electrical conductor? I'm not sure I would want to spray it in the ignition switch.
deweyville65 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
p a t s (anti theft) tashmore1 Stock 1995 - 2001 Explorers 4 11-20-2012 03:09 PM
2004 Ford Ranger anti theft disable. applepiebb Ford Ranger - Mazda B-Series Forum 5 10-11-2011 02:11 PM
anti theft starting/stalling problems? radioiowa88 Stock 1995 - 2001 Explorers 4 06-20-2011 04:41 PM
How do you disable the anti theft system on a 94 Explorer? rkw Stock 1991 - 1994 Explorers 6 04-27-2009 12:00 PM
How to disable anti theft in 97 penn28 Stock 1995 - 2001 Explorers 5 12-31-2008 08:10 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
