Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
replacing oil pan gasket on an 02 explorer
Reply
Thread Tools
Old 05-08-2012, 04:11 PM   #1
ml5888
2002 ford explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
how hard is it to replace the lower oil pan gasket on an 2002 explorer xlt 4.0 4x4? I have read that you have to lift the enging is this true?
ml5888 is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-08-2012, 04:41 PM   #2
Exproblems
Orchard Park, N.Y.
'05 Explorer XLT 4.0L
Vehicle Specs
Quoted: 85 Post(s)
Quote:
No, You don't have to raise the engine to remove the "lower", sheet metal oil pan. The engine must be removed from the vehicle to remove the upper, aluminum section so you are good to go just removing the lower, oil pan section according to the Haynes manual. I've never done this myself, just quoting the Haynes manual.
Exproblems is offline   Reply With Quote
Old 05-08-2012, 08:20 PM   #3
abarkl
Phoenix, AZ
'03 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
I replaced my '03 4.0 a few years back and didn't do anything special but remove the bolts and clean both surfaces.
abarkl is offline   Reply With Quote
Old 05-09-2012, 01:23 AM   #4
Mario81587
Newport, NC
02 Mountaineer AWD
Vehicle Specs
Quoted: 0 Post(s)
I can't get mine off after taking all of the bolts out. I tried gently prying it and it would not budge.
__________________
2002 Mercury Mountaineer AWD V6
2004 Nissan Sentra SE-R Spec V - all options
2007 Toyota Camry Hybrid - all options
Mario81587 is offline   Reply With Quote
Old 05-09-2012, 05:11 AM   #5
vipersinu2
The Big City of Orange City, Florida
vipersinu2's Avatar
97-03 4.0 exp 07 mount v8
Vehicle Specs
Quoted: 11 Post(s)
It's been a while. but I had my sohc on the engine stand, and the pan was surprisingly hard to pry off the only thing holding it on was some sticky RTV.
vipersinu2 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
You smoke cigarettes? FourXFred General Topic Polls 167 11-12-2011 09:12 PM
Anyone replaced their oil pan gasket? jdc28va Stock 2006 -2010 Explorers 3 03-02-2011 12:43 PM
2001 Ford Explorer with an oil pan gasket leak. mistermac 2001-2005 Explorer Sport Trac 1 08-22-2010 09:03 AM
fixing oil pan gasket leak @ rear of 4.0l while A4LD is out saxon Explorer & Ranger Transmissions, Transfer Cases, & Differentials 3 08-13-2006 10:03 PM
Chewed up 02 oil pan drain plug o-ring TPC11 Under the Hood 1 07-02-2004 09:17 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
