Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Tow Rig Forum
Notices
Tow Rig Forum Towing, hauling, boats, campers, trailers etc... Trailer hitches, weight distribution, hitch ball, safety chains, tow bar and brake controllers. Discuss it all here!
Trailer wiring
Reply
Thread Tools
Old 05-08-2012, 09:45 PM   #1
slmdrngr
Monicello Arkansas
1996 Ford Explorer XLT
Vehicle Specs
(Original Poster)
Trailer wiring
I have a 1996 explorer, 4.0 OHV, auto trans, no receiver hitch or factory trailer plug harness, i bought a trailer T connector that goes in with the tail lights, but it does not work, i was wondering if maybe i needed one the setups that has the converter in it or what? I don't like pulling anything without the lights for obvious reasons, but i was wondering if anybody had any similar problems and how they fixed it or if anybody had any suggestions. Thanks in advance for any help, this has really been bugging me.
slmdrngr is offline   Reply With Quote
Old 05-09-2012, 06:11 AM   #2
MountaineerGreen
Towing Moderator
North East Arkansas
MountaineerGreen's Avatar
2012 F150 4x4
Vehicle Specs
Are you certain you plugged the T harness in the right spot? Have you used a test light or volt meter at the 4 flat connector? Are your tail lights working? What years of vehicle did the T harness say it would work on?
MountaineerGreen is offline   Reply With Quote
Old 05-09-2012, 11:11 AM   #3
slmdrngr
Monicello Arkansas
Vehicle Specs
(Original Poster)
I cant remember the exact years it said it would fit, i'm pretty sure my year model was in there tho, i haven't checked it with a meter yet, but i plugged it in and it fit perfect, i'm not sure where else it could plug in? Maybe im missing something, i had another connector that fit where the T connector fit, but the other side of my vehicles harness couldn't hook up, but it did not work either, I've gotta be doing something wrong. My taillights all work and reverse lights and such also work.
Old 05-10-2012, 06:00 AM   #4
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
The T harness should have plugged in on the drivers side if I remember correctly. Take a test light, clip the ground to the frame somewhere, probe the 3 shielded places on the 4 flat with your flashers on and parking lights on.
Old 05-10-2012, 05:18 PM   #5
slmdrngr
Monicello Arkansas
Vehicle Specs
(Original Poster)
I had it on the drivers side, which color is the ground? i haven't had a chance today, been chasing other engine issues today, thanks for the advice, when i do it, i just stick the prongs in each pin to test it right?
Old 05-11-2012, 06:10 AM   #6
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
I think it does connect on the drivers side, right under the tail light.
White is ground on those, yellow is drivers side, green is passenger side, brown is tail. If your taillights have separate stop/turn indicators, you may need a t harness with the converter built in.....
Old 05-11-2012, 08:14 AM   #7
slmdrngr
Monicello Arkansas
Vehicle Specs
(Original Poster)
you mean something such as the wiring with this setup?
http://www.ebay.com/itm/TRAILER-HITC...ht_3762wt_1037
I've been wondering if that's what i need or not
Old 05-11-2012, 05:59 PM   #8
slmdrngr
Monicello Arkansas
Vehicle Specs
(Original Poster)
I got no readings from any of the wires except when i had the parking lights on, the meter said overload lol, im not sure if i had it set right
Old 05-12-2012, 06:04 AM   #9
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
Sounds like you need to find the book on your multimeter and read up.
Old 05-13-2012, 09:25 PM   #10
slmdrngr
Monicello Arkansas
Vehicle Specs
(Original Poster)
well, its not mine lol, and there isn't a book to it currently, i'm not sure what setting it needs to be on when i'm testing
Old 05-13-2012, 10:54 PM   #11
buckwill
trona calif
1998 sport
Vehicle Specs
DC voltage the one that looks like a solid line and a dotted line, and the range that is the next step that includes or is higher than 12 volts,, must be higher, 9 volts will give u over range also the plug on upur vehicle that has an ex[posed pin is always the ground. your vehicle plug will have one exposed pin and 3 or 4 covered pins, in trailor side will be one covered pin(thats ground) and 4 or five open pins
__________________
if my memory was getting shorter would i know???,, disabled viet vet, retired navy,, 98 exploder sport sohc 4.0,, retired macinist,gas and steam turbine millwright,, ive arrested, stroked twice and i mispell lots,
buckwill is offline   Reply With Quote
Old 05-13-2012, 11:24 PM   #12
slmdrngr
Monicello Arkansas
Vehicle Specs
(Original Poster)
Thanks, i ill try this tomorrow, i figured the exposed as a ground, was guessing, i guess if i get any reading from the others at all ill know they work right?
Old 05-14-2012, 12:16 AM   #13
buckwill
trona calif
1998 sport
Vehicle Specs
just imagine, if exposed pin from vehicle chassis was hot if it bumped something,, it would blow,, so exposed from car side is always ground,, doesnt hurt anything see,, turn signal to left side; vontage flash on and off thats turn,,, right side flash off and on thats rt, turn,, they also brake,, tail is constant voltage if u turn your head light on so basically u have left turn and brake one wire,,, then rt turn and brake other wire,, then solid voltage is tail,, but on newer all electronic needs converter,, buck
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2010 XLT Trailer wiring question grubbyjeans 2007 - 2010 Explorer Sport Trac 0 02-09-2012 08:25 PM
Trailer Wiring Problem CPRchris Stock 1995 - 2001 Explorers 2 12-18-2011 12:33 PM
Trailer wiring, Lights WILL NOT GO OFF!!! clemguy95 Stock 1995 - 2001 Explorers 1 08-16-2008 02:18 PM
factory trailer wiring harness for 98 need by tommorow WannaXP8 Elite Explorer 911! 3 06-11-2004 10:12 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
