Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Street Truck & Performance Forums > Street Trucks > Need for Speed!
Notices
Need for Speed! Explorer, Ranger, Mountaineer 4.0 - 4.6 - 5.0 Nitrous, Superchargers, Camshafts, Head Work, Stroker Kits... DRAG RACING. Explorers, Mountaineers and Rangers CAN move!
351 w swap
Reply
Thread Tools
Old 05-09-2012, 10:32 PM   #1
christopherjones
prince george, british columbia
96 xl
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
351 w swap
Know this may have been posted before on this swap, I'm going to attempt it this summer in one of my other explorers
Few questions for opinions or what none of the it can't be done. Unless there's a justifiable reason
1. Stock4r70 trans. Can it take it
2. Can Henson reprogram an expo 5l ECM to run the 351
3. To those who have attempted and read is. Would it work to use a set of shorties or huggers for exhaust or could a person build there own direct turndown bigger log style manifold just to get the gasses out.
4. If 4r is a no go can Henson delete the trans program to run a m5odr2
5. If expo ECM can't run the 5.8 then I'll use a 96 + ECM from a bronco
__________________
1996 xl 4door
97 +gt40p 5.0/4r70w
4406 manual shift /Manual front axle control
dual exhaust w bottles to be heard
http://www.youtube.com/watch?v=zSzHUWqXbIc
christopherjones is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-10-2012, 04:47 AM   #2
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
oil pan & trigger wheel?
Do you plan to build a custom oil pan yourself?
Does your 351W have a trigger wheel for OBDII?
2000StreetRod is offline   Reply With Quote
Old 05-10-2012, 05:43 AM   #3
boominXplorer
Elite Ranger
Virginia Beach, Va
boominXplorer's Avatar
00 4x4 Mounty
Vehicle Specs
Quoted: 191 Post(s)
1. Yes, 4r70 will take it and love it just as long as you at least give it a shift kit and if its not worn out already.
2. Not sure if he can but a 351 has a different firing order, you got to switch some plug wires around to make it work.
3. NO manfolds fit this swap, custom is the only way. The closest I can think to being bolt on is a FMS driver side header and a OEM 94-95 mustang for the pass side
4. This is all your own option as a 4r70 will still work
5. This is where it gets fun. If you want to keep the explorer pcm (more power ans adjust-ability with tune) you have to modify a few things.....
-Cam pos sensor-Need to adapt the oil pump drive to fit, needs 1" longer
-Balancer-The explorer balancer is 52oz and the 351 is balanced at 28oz. You need to either re-balance the assy or the explorer balancer so you have the trigger wheel.
Figure on tall valve covers will be in the a/c box without a doubt unless you have a body lift. The truck 351 oil pan will clear if you lift the motor 1" up, or you have to go custom. If you want to keep the explorer upper intake manifold you have to find a 351w gt40 intake which are HARD to find. It took me about 6 months to find one affordable. I have about 3/4 of the parts to do this swap, just waiting for the time to get the motor ready. There are a few other details that I do not know the extent of just because I have not put one in YET but that's most of the fun stuff there.
__________________
2002 F250 Crew Cab SB 7.3 Diesel 4x4 - 4" MBRP exhaust, AIH delete, SCT Livewire
2001 Ranger ext cab 4x4 - 5.0 swap, FMS headers, 4406, 4.88s, 5" lift with Coilovers, 3" body running 315/75/16 MTZs
2007 Ford Focus ST Black - FS Intake, SVT brakes F&R, Fiesta ST 17s
My eBay auctions
boominXplorer is offline   Reply With Quote
Old 05-10-2012, 09:10 AM   #4
christopherjones
96 xl
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I was under the assumption that the 351 share the same firing order as the HO 302 cam pos senso shouldn't be bad nor should dank trigger wheel as the newer 351 in broncos were obd2 and rocked out crank sensor
__________________
1996 xl 4door
97 +gt40p 5.0/4r70w
Old 05-10-2012, 06:34 PM   #5
2000StreetRod
Greenville, SC
Vehicle Specs
Quoted: 45 Post(s)
4 tooth trigger wheel
I believe the OBDII 5.8L engines have a 4 tooth trigger wheel while the 5.0L engines have a 36-1 trigger wheel.
(above photo posted by snoranger)
You will not be able to use the Explorer PCM with the 4 tooth trigger wheel. The 4 tooth trigger wheel is for OBDII compliance - the distributor determines the ignition timing.
Old 05-10-2012, 08:06 PM   #6
christopherjones
96 xl
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Right but should a person not be able to press the expo crank trigger in place of the 4 tooth.
Another question is the flex plate for a e4 the same size as a 4r
Reason I ask is because the flex plates are balanced to the crank so one cannot simply swap flex plates
Maybe the only route will be to rock out a m5 from a newer v6 f150 and run an external slave mod combined with dropping the notion of running edis on the 5.8. This maybe easier. I'm going to try lifting the front of the engine up a bit off the mounts and shimming forwards at the same time as dropping the tail stock of trans to get the oilman clearance required, either that or move the rack down into a beefed x member
__________________
1996 xl 4door
97 +gt40p 5.0/4r70w
Old 05-10-2012, 08:21 PM   #7
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quoted: 68 Post(s)
Already did it.
You also need to find a 94-95 Cobra crank pulley. They are almost the same diameter as the stock 5.0l pulley and will fit the 351 balancer.
Then you need to have the front of the balancer machined down about 1/4", so the pulleys will align.
__________________
94 limited: 4.0l, 5spd swap, 6" skyjacker lift, 35x14.5 thornturds, 4.56s. 5.0 swap started (94 cobra 5.0, zf 5spd, np205)
95 xlt: stockish (SOHC swap, 30,000miles and I blew up the 3rd 4r55e...now collecting parts for a Cummins swap.)
Cummins 4BT swap thread
Ranger bed trailer build
snoranger is offline   Reply With Quote
Old 05-10-2012, 08:35 PM   #8
christopherjones
96 xl
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Would maching dampner down. Not change the balance? Why would you need different pulleys. Outside overall pulley diameter won't matter if you using the same trigger it would just under/over drive accessories and I'll be running with out an a.i.r. Pump or an ad pump I'll be custom sizing belts. As far as front dress goes I ll be running a twin Efan like my current 5.0 so I don't need room for the mech fan allowing me to use the tall dress common to all fords ( with the exception of the 1 off explorers short dress )
Evans in front of rad from a newer body cougar in place of condenser fits perfect but that's steering away from the point of this thread
So it seems as thou I'll be forgoing edis and the auto in favor of a 5spd w distributor. Was hoping to use the parts off of my rotten 5l parts truck
Unfortunately here where I live if your vehicle was obd2 it has to stay obd2 in case you get pulled over for something and they issue a vi. Bc cops don't like it when people have toys
__________________
1996 xl 4door
97 +gt40p 5.0/4r70w
Old 05-10-2012, 08:41 PM   #9
techieman33
Topeka, KS
techieman33's Avatar
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
Get in contact with pufferfish, he may still have a lot of the parts you would need for the swap. And if he doesn't his threads have lots of good info in them.
http://www.explorerforum.com/forums/...d.php?t=335841
techieman33 is offline   Reply With Quote
Old 05-11-2012, 02:28 AM   #10
christopherjones
96 xl
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
http://www.summitracing.com/parts/MAA-77207D/
Would this work
__________________
1996 xl 4door
97 +gt40p 5.0/4r70w
Old 05-11-2012, 04:46 AM   #11
2000StreetRod
Greenville, SC
Vehicle Specs
Quoted: 45 Post(s)
hall effect outputs?
I couldn't find much information on the 77207D dual sensor assembly. It looks like it is designed to work with Mallory's ignition module that will accept various sensor inputs. Your 5.0L PCM expects a variable reluctor sensor signal from the 36-1 trigger wheel and a hall effect sensor signal from the synchronizer. I suspect the 77207D outputs hall effect sensor signal outputs for both the crankshaft and the camshaft. Also, the PCM requires 35 pulses per crankshaft revolution which probably is not available from the 77207D. You need to contact Mallory to find out more information about signal compatibility but I'm not optimistic.
Edit: According to my 1996 and 2000 wiring diagrams, sometime between those years the V8 synchronizer changed from a 3 wire hall effect sensor to a 2 wire variable reluctor sensor. The same is true for the 4.0L OHV V6.
Old 05-11-2012, 09:45 PM   #12
pufferfish
Baltimore
97 Mounty 5.0
Vehicle Specs
Quoted: 0 Post(s)
The crank trigger linked is only a crank trigger. You have the cam trigger to deal with too. I found one that did both and fit the but only looked to use it for the cam trigger, which, in theory would work. Never got to find out first hand though.
pufferfish is offline   Reply With Quote
Old 05-12-2012, 12:18 AM   #13
2000StreetRod
Greenville, SC
Vehicle Specs
Quoted: 45 Post(s)
cam & crank
Quote:
The Mallory Ignition 77207D FireStorm Dual Sync Sensor Assembly was available the end of last year for the 5.8L. It generates a camshaft and a crankshaft pulse: http://prestoliteperformance.com/npd...01D_77207D.pdf
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
a4ld to Manual M50D Swap How-to 94fourdoor Explorer & Ranger Transmissions, Transfer Cases, & Differentials 147 10-26-2015 05:28 PM
Explorer 5.0 Swap info detailed photos/wiring descriptions. Into non OBD2 veh crazyflights Under the Hood 35 05-07-2015 08:17 AM
HOW TO: 2001 Sport Cluster Swap for 1998 Explorer 1998Exploder Modified 1995-2001 Explorers 46 03-15-2013 09:40 AM
Engine Swap Ideas (Fun Thread) fiftyfordfloored Modified 1991-1994 Explorers 24 12-15-2007 07:54 PM
302 or 351? Kinserin Offroad Drivelines 3 05-09-2007 10:09 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
