EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Modified 1995-2001 Explorers
Notices
Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap.
Speedometer not working after 1354 manual swap
Reply
Thread Tools
Old 05-20-2012, 08:57 PM   #1
newstylecustoms
Clayton, IN
1999 Explorer EB
Vehicle Specs
(Original Poster)
I just got my 99 back on the road after swapping to a Dana 44 TTB and 1354 manual transfer case. The ABS light is on as I assumed it would be since there are no sensors on the front wheels I am fine with ABS not working for now. The manual transfer case swap left was also completed. Is the speedo issue related to the ABS or T case or both? I was under the impression that the speedo worked off of the rear ABS sensor which is still intact. BTW the transmission shifts fine so it is receiving a speed sensor input.
Thanks in advance for any help.
__________________
1999 Explorer EB, Dana 44 TTB
1988 Ranger 5.0L, T5, bagged, linked
newstylecustoms is offline   Reply With Quote
Old 05-21-2012, 06:12 AM   #2
99SportX
Duluth, MN
'99 Sport
Vehicle Specs
The speedometer and PCM read an input from the ABS module. If your front sensors are gone, the only option it has for a signal is the rear sensor. The rear sensor is common to fail. You can check to see if it is failed by measuring the resistance of the sensor. The values are somewhere on the site. They typically fail either open or closed, I can't remember. Search around the site.
When the rear sensor failed in my dads 99 mounty, the ABS light was on and the speedo still worked. I can only assume the ABS was sending out the reading from the front sensors. We replaced the sensor and the light went off.
__________________
'99 Explorer Sport 5.0 AWD t-case with 2wd spindles (identity crisis)
'99 Explorer XLT 4.0 SOHC 4x4 for daily driver/off road use
99SportX is offline   Reply With Quote
Old 05-21-2012, 06:55 AM   #3
newstylecustoms
Clayton, IN
1999 Explorer EB
Vehicle Specs
(Original Poster)
That is good info thanks. The ABS light was on before the accident also so that could have been the issue all along. Why does the tranny still shift properly though, I thought it was all tied together?
Anyone use a VSS from the speedo output of the Tcase on a newer truck like this one. I have a sensor mounted in the t case to plug the hole, maybe I could use that as the input instead of the rear sensor. Then I could swap in a 9 inch with no problems.
Also the truck dies sometimes when coasting to a stop, I am assuming this is related to the speed sensor issue. Just pulled the code and it is P0500 VSS malfunction. Are there any other sensors that were in the factory tcase?
__________________
Old 05-21-2012, 11:50 AM   #4
Bronco89
Cleveland Ohio
98 Explorer
Vehicle Specs
I dont know much about how the system works, but I have a tid bit of info that might help you. Once when my ABS light was on, I pulled the fuse for it thinking the dash light would go off, and I dont care for ABS anyways. Well, the dashlight stayed on, but my speedo didnt work. Would be great for falsifying the odometer though...
Bronco89 is offline   Reply With Quote
Old 05-21-2012, 04:29 PM   #5
newstylecustoms
Clayton, IN
1999 Explorer EB
Vehicle Specs
(Original Poster)
I had a 96 F150 that would do the same thing when a certain fuse was pulled. I just am trying to figure out if there was another sensor in the tcase that I didn't know about.
__________________
Old 05-21-2012, 08:18 PM   #6
newstylecustoms
Clayton, IN
1999 Explorer EB
Vehicle Specs
(Original Poster)
Installed another rear ABS sensor I had laying around and now speedo works fine. Thanks for the help.
Anyone know how to make the 4wd lights stop flashing (I know I can take the bulbs out)?
__________________
Old 05-21-2012, 08:23 PM   #7
99SportX
Duluth, MN
'99 Sport
Vehicle Specs
I would install a 4x2 GEM module. The AWD V8 and 2WD V8 or V6 had them. It is located behind the radio bezel on the drivers side. When I swapped my V8 in on the sport I changed from a 4x4 to 4x2 (2WD, AWD) GEM.
__________________
Old 05-23-2012, 11:45 AM   #8
newstylecustoms
Clayton, IN
1999 Explorer EB
Vehicle Specs
(Original Poster)
Thanks, looks like I need a trip to the junkyard
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
a4ld to Manual M50D Swap How-to 94fourdoor Explorer & Ranger Transmissions, Transfer Cases, & Differentials 94 02-04-2013 08:21 PM
Electric 1354 swap BogFather Explorer & Ranger Transmissions, Transfer Cases, & Differentials 13 01-19-2009 03:42 PM
Non working Speedometer dbroncos84 Under the Hood 1 10-26-2008 09:19 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
