Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
98 Explorer 4.0 OHV engine swap from a 96 4.0 OHV? Will it work?
Reply
Thread Tools
Old 05-22-2012, 06:58 AM   #1
FLSnake
Bradenton, FL
97 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 98 Explorer 4.0 OHV V6 with a bad engine (lower end),
I have a donor vehicle, 96 Explorer 4.0 OHV V6.
I see some slight differences in the wiring harness from a quick visual inspection but the core engine looks the same.
Will they interchange? I have been told that 96/97 are the same and that 98-01 are the same?
Thanks
FLSnake is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-22-2012, 07:26 AM   #2
bilzy7
MA
98 Explorer XLT
Vehicle Specs
Quoted: 1 Post(s)
Worst case scenario, you have to swap tranny engine and wiring harness. I know only issue with the same engine being swapped with a newer version, is how the transmission is controlled by the computer.
__________________
1998 Explorer XLT 4x4 4.0 SOHC
bilzy7 is offline   Reply With Quote
Old 05-22-2012, 07:26 AM   #3
Sedition
Engine Repair Guy
Geelong, Australia
Sedition's Avatar
98 Explorer XLT SOHC
Vehicle Specs
Quoted: 40 Post(s)
Ok lets clear this up a little. Your title says that you currently have a SOHC V6 and you want to swap it for a OHV V6 is this correct?
__________________
98 XLT SOHC V6 Export - Busted tranny - Recently Rebuilt Engine For Sale
2002 Limited SOHC V8 - Bent Rod - Awaiting Repair
It's the all American SUV, I tell you w'hut....
Sedition is offline   Reply With Quote
Old 05-22-2012, 07:27 AM   #4
bilzy7
MA
98 Explorer XLT
Vehicle Specs
Quoted: 1 Post(s)
His thread title says SOHC that's right... I was going off the post, both are labeled OHV...
__________________
Old 05-22-2012, 07:28 AM   #5
bilzy7
MA
98 Explorer XLT
Vehicle Specs
Quoted: 1 Post(s)
I think he hit c instead of v on the keyboard, they are next to eachother. There is no S infront of the ohc.
__________________
Old 05-22-2012, 07:33 AM   #6
FLSnake
Bradenton, FL
97 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Sorry, was a typo in the title, they are both OHV engines, I edited the title to correct
Old 05-22-2012, 07:42 AM   #7
Sedition
Engine Repair Guy
Geelong, Australia
Sedition's Avatar
Vehicle Specs
Quoted: 40 Post(s)
In that case it would be a simple change over. I would take out the engine and wiring harness only leaving the gear box and aircon compressor in place. I would take the new wiring harness with the new engine and plug it strait into the rectangle plug in the firewall, that way you don't have to worry about different types of connectors for the same componants on the replacement engine.
Should be a nice easy job, Enjoy
__________________
Old 06-22-2012, 01:03 AM   #8
mp40
Washington State
96 sport 4.0 ohv
Vehicle Specs
Quoted: 0 Post(s)
Ah, I think that there might be a slight problem with this swap from the flex-plate side.
The 1990~1996 4.0 used a 6 bolt flywheel/flex-plate and the 1997~up 4.0 uses an 8 bolt flywheel/flex-plate. This can pose a problem from the converter side.
I think that it would be best if you obtain an 1997-up 4.0 for this swap it would be easier.
mp40 is offline   Reply With Quote
Old 06-22-2012, 12:30 PM   #9
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quoted: 68 Post(s)
Thats no big deal, as long as they are both autos (or both manuals). They only difference in the flywheel/flexplate is the number of bolts that attaches it to the crank. The flywheel attachment points are the same.
Just keep the flywheel/flexplate on the engine it came with.
__________________
94 limited: 4.0l, 5spd swap, 6" skyjacker lift, 35x14.5 thornturds, 4.56s. 5.0 swap started (94 cobra 5.0, zf 5spd, np205)
95 xlt: stockish (SOHC swap, 30,000miles and I blew up the 3rd 4r55e...now collecting parts for a Cummins swap.)
Cummins 4BT swap thread
Ranger bed trailer build
snoranger is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
96 Explorer 4.0 OHV V6 suddenly dies- changed relays 1karkrazyguy Stock 1995 - 2001 Explorers 0 12-14-2011 01:07 AM
97 OHV into a 95 Explorer 410Fortune Under the Hood 38 07-25-2011 08:39 PM
Will a 95 explorer 4.0 OHV fit a 98 4.0 OHV explorer? jwalk48 Stock 1995 - 2001 Explorers 2 03-15-2010 09:26 PM
HELP! 1993 4.0 OHV Engine SWAP steven32782 Modified 1991-1994 Explorers 8 04-07-2009 09:47 AM
98 Explorer 4.0 engine replacing bmx2guy Under the Hood 1 07-20-2007 07:15 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
